How to Transfer Data from Android to iPhone After Setup [Updated]
Have forgotten to transfer data from your Android to iPhone when setting up the new iPhone 16? Don’t worry, there are solutions that enable you to transfer data from Android to iPhone after setup. So you don’t need to reset your device.
Author Avatar Joy Taylor Last Updated: Oct. 17, 2024
AnyTrans – Transfer Data from Android to iPhone after Setup
If you buy a new iPhone, how to transfer data from Android to iPhone, especially after setup? Don’t worry. Free download AnyTrans to move data from Android to iPhone after setup. Never reset your device. Existing data on your iPhone will not be erased. Supports all iPhone models, including iPhone 16.
Many Android users may plan to get a new iPhone, and the first thing to do when you get the iPhone is transfer data to it. However, if you have set up your device, it may be difficult to do that. The first question is: can I transfer data to iPhone after setup? Yes, of course. You can still transfer from Android to iPhone after setup. And here comes this article that aims to present you with specific guidance on how to transfer data like contacts, apps, photos, music, etc. from Android to iPhone after you have finished iPhone setup.
In this post, several methods will be mentioned to show you how to successfully transfer data to your new iPhone, like iPhone 16/15, after setup. Now, follow the below part to transfer data from Android to iPhone after setup.
Further Reading: You may also like this guide about data transfer – How Long Does It Take to Transfer Android to New iPhone >
Transfer Data From Android to iPhone After Setup without Reset
Most methods require resetting to move data from Android to iOS after setup, which may be frustrating and troublesome. So, how to transfer data from Android to a new iPhone without resetting? A professional transfer tool must be the best choice. It’s flexible to use transfer tools to move data from Android to your iPhone, you can do it anytime you want, even without resetting after setup. Here are two tools you can try:
#1. AnyTrans – Android to iPhone Transfer without Resetting
AnyTrans is committing to making great management on the iPhone. It can perfectly handle all your needs while using an iPhone, including transferring data from Android to iPhone, iPhone to iPhone, iOS to computer, managing iTunes/iCloud data, and more.
As an iOS setup assistant without resetting, AnyTrans helps you transfer files from Android to iPhone after setup. And the data transferred by it will never overwrite the existing data. Therefore, if you want to know how to transfer data from Android to iPhone without resetting, AnyTrans must be a good choice.
  • 1-click transfer data from Android to iPhone even after setup.
  • Transfer all data like contacts, WhatsApp, photos, music, etc.
  • Freely preview and select data to transfer. No resetting or overwriting.
  • Work well on all iPhone/iPad models and iOS versions.
Follow the steps below to transfer data from Android to iPhone after setup even without resetting:
Steps to Transfer Data from Android to iPhone After Setup:
Step 1. You can free download AnyTrans and start the transferring progress by following the instructions. Choose Phone Switcher > Choose Phone to iPhone > Click Migrate Now.
Choose Phone to iPhone on Phone Switcher
Step 2. Confirm your two devices > Click Next > Choose the data you want to move to iPhone and start the transfer.
Click Next to Continue
Step 3. With the assistance of AnyTrans, you can select categories that you want to move with a few clicks. What you need to do is choose the data that you want to transfer and tap the Next button to continue.
Select All Data on Android to Transfer
#2. PhoneTrans – Phone to Phone Transfer in Clicks
PhoneTrans is another professional phone switcher. It provides several options for data transfer from one phone to another. Some star highlights of data transfer of PhoneTrans you may concerned.
  • Quick Transfer – Transfer data from Android to iPhone selectively and wholly via Quick Transfer on PhoneTrans.
  • Phone Backup – More secure for your data, try Phone Backup to back up the data that matters on your phone.
  • Phone Restore – Easily get all the files you need from your backups.
All of them can provide you with a safe and quick way to switch phones from Android to iPhone. And all data types, like photos, music, contacts, etc., are supported by PhoneTrans. So if you want to know how to transfer Android to iPhone after setup, you can try PhoneTrans as well.
Follow the steps below to transfer data from Android to iPhone after setup:
Step 1. Free download PhoneTrans and install it on your computer. At the same time, connect both your Android and iPhone to the computer with USB cables.
Step 2. Run PhoneTrans on your computer. Choose Phone to Phone on the left side and choose Quick Transfer. Then tap the Start Transfer to the next.
Choose Phone to Phone - Quick Transfer
Choose Phone to Phone – Quick Transfer
Step 3.  Follow the instructions on the screen and you should go on selecting the data you want to transfer from Android to iPhone. Then tap on Transfer Now to start the transfer.
Select Android Data to iPhone
It won’t take a long term to move from Android to iPhone.
Transfer Data From Android to iPhone After Setup via Move to iOS
For the users who just switched from Android to iPhone, they may don’t know there has an app developed by Apple, namely Move to iOS, that enables them to transfer files from Android to iPhone when setting up their new iPhone. However, does this mean that you are not able to transfer Android to iPhone after setup? Of course not. Move to iOS app is still the solution available but you need to erase your iOS device first. In this part, we will show you the detailed steps to use Move to iOS after setup.
To transfer data from Android to iPhone after setup with Move to iOS:
Move to iOS enables users to move data from Android to iPhone at ease when setting up the new iPhone. After we have already set up the new iPhone, to use Move to iOS to transfer the data, we need to erase our setup at first, which is the key factor for successfully transferring data from Android to iPhone via Move to iOS after setup.
Step 1. Erase your iOS Device
  1. Open your iPhone > go to Settings app.
  2. Scroll down to the bottom and then click Reset option.
  3. Click Erase All Content and Settings.
  4. Click Erase Now option.
  5. Enter your Password and Apple ID password.
  6. Wait for the device to erase all the contents.
Restore iPhone Using Erase All Contents
Step 2. Enable Move Data from Android
  1. Power on your iPhone > insert your SIM card.
  2. connect the iPhone to WiFi > follow the onscreen guidance to set up your iPhone until the Apps & Data interface shows.
  3. select Move Data from Android option on Apps & Data interface.
  4. Download and run Move to iOS on Android > click Continue option.
  5. tap the Agree option to agree with the terms and conditions > click Next.
  6. Click the Continue option on your iPhone > then a digital code will appear on your iPhone.
  7. enter the code on your Android.
  8. select the contents like photo, video, colander, etc. you want to transfer.
  9. click Next to move the data from Android to iPhone even after setup.
Transfer Data via Move to iOS
Transfer Data From Android to iPhone After Setup via Email
If you have already set up your new iPhone, you are still able to use email and iTunes to move data from Android to your iPhone. However, such ways might not be as convenient as the above ways which enable you to transfer various data from Android to iPhone. For example, for mail, contacts, and calendars, you can take advantage of Emails like Gmail to transfer it from Android to iPhone. While for photos, video, and music, it is better to use iTunes to move it from Android to the iPhone which might be more effective and simple.
Here, I’d like to show you the steps to transfer data from Android to iPhone after setup. Follow the tutorial to learn the detailed information.
  1. Run your Android phone > Go to Settings.
  2. Find and click the Account option.
  3. Enable Gmail and sync features.
  4. Enable sync calendar and contacts.
  5. Click Sync Now to sync the contacts and calendar with Gmail account.
  6. Head to the Settings app on your iPhone.
  7. scroll down and choose the Mail option > click Accounts > click Add Account > choose Google Mail.
  8. Enter your Gmail account and password > click Next.
  9. enable Contacts and calendars > click Save option.
  10. After that, the contacts and calendars on your Android will be automatically synced with your iPhone device.
Transfer Contacts & Calendar via Email
Transfer Data From Android to iPhone After Setup via iTunes
How to transfer photos from Android to iPhone after setup? iTunes can help you. Transferring data from Android to iPhone via iTunes after setup is mainly used for data like photos and music. If you are mainly aiming to transfer photos and music from Android to your new iPhone, you can give this method a trial. Here is how to transfer data from Android to iPhone after setup via iTunes.
You can find the file folder that stores your photos on Android at first so as to make a preparation. Generally speaking, you can find your photo files by heading to DCIM > Camera.
  1. Connect your Android phone to the computer > create a new folder on your PC.
  2. transfer the photo files from Android to PC > disconnect Android to PC.
  3. Download and run the latest iTunes on your computer.
  4. connect your iPhone to PC > sync the photos with your iPhone via iTunes.
After reading this article, you may easily transfer data from Android to iPhone after setup. Move to iOS can help you transfer various data from Android to iPhone at once. However, when using it, you need to erase your setup at first, that’s the annoying point. If you don’t want to reset your device, AnyTrans is more suitable for transferring all sorts of data. So just give AnyTrans a free try now.
AnyTrans – Transfer Data Android to iPhone
Free download AnyTrans to transfer data from Android to iPhone after setup. All data types are supported, including contacts, messages, WhatsApp, photos, apps, etc. No resetting, no erasing. Most importantly, it supports all iPhone models, including the latest iPhone 16.
