7 Ways to Transfer Data from Android to Android [Full Guide]
When you switch your Android phone from one to another, you may wonder how to transfer data from Android to Android. This post will brief several methods to help transfer files from Android to Android with ease.
Author Avatar Joy Taylor Last Updated: Feb. 26, 2025
Read in: Read This Article in
العربية
Due to constant development and innovation in digital technology, new mobile phones launch every day. Developers and manufacturers are upgrading phones with new versions of operating systems and the latest features. Thus, switching mobile phones has become an urgent demand for most people. This also means that users need to transfer files from Android to Android.
Nevertheless, many people do not know how to transfer data from Android to Android. Therefore, in this article, we will show you some simple but effective ways to help you transfer everything, like photos, videos, etc. from one Android phone to another. All Android brands and devices are covered, including Samsung, Huawei, Xiaomi, and more.
How to Transfer Data from Android to Android in 1 Click
What is the fastest way to transfer data from Android to Android? Then, you cannot miss DroidKit – Android Phone Toolkit, which offers a professional phone switch tool. With this tool, you can easily transfer all your Andriod data with a simple click, so it helps save lots of time and requires no skills. Below are the highlights of this Android transfer tool.
  • Transfer everything – It allows you to transfer all types of data, like photos, contacts, call logs, videos, SMS, music files, apps, etc.
  • Selective/Batch transfer – You can preview all data and choose what to transfer. Or, you can also transfer everything in 1 click.
  • Only minutes – It can transfer thousands of data within 3 minutes. You can get your data on your new device with no waiting.
  • 100% safe & confidential – It guarantees that all your data will not be leaked online or to anyone else. You don’t need to worry about data and privacy security.
  • Support all Android brands – It is compatible with all Android devices, like Samsung, Huawei, LG, Xiaomi, Oppo, etc. And it works well on Windows and Mac.
As DroidKit is a complete Android solution, it can also help you recover your lost data like messages and photos, unlock any Android screen locks, fix common Android system issues like black screen, bypass Google account verification, etc.
Now, just free download DroidKit and follow the steps listed below to figure out how to transfer data from Android to Android in 1 click.
Step 1. Open DroidKit on your computer. On the main screen, choose Android Mover in Data Manager Mode.
Choose Android Mover
Step 2. You need to choose the Android to Android mode on the next screen.
Choose Android to Android
Step 3. Then you should connect your devices to the computer. Once done, click on the Migrate Now button.
Click on Migrate Now
Step 4. You can select the data types and then click Next to transfer.
Select Data You Want to Transfer
Step 5. All you need to do is waiting for a while. Once DroidKit completes the data transfer, you can unplug the Android devices and find out the old Android device’s data which are already on the new Android device.
Data Transferred Successfully
How to Transfer Data from Android to Android via Google Drive
How to transfer data from one phone to another Android? The cloud storage service like Google Drive can also help you to do that.
Google Drive is a cloud-based file storage and synchronization app developed by Google. By creating a backup, any Android device can restore data from Google. This is an impressive feature as it allows you to sync data from one phone to another. Now let’s take a look at how to transfer data from Android to Android via Google Drive.
Transfer Data From Android to Android via Cloud Storage Service
Step 1. Create a Google Account
If you haven’t had a Google account for Android device, create one. Then download Google Drive and log in to your Google account.
Step 2. Sync data
Google Drive will automatically sync the data on your device. You can also manually sync Google Drive with your phone. This process can take some time, depending on the amount of data.
Step 3. Create Backup
Once the syncing is complete, different types of data will appear in its relevant folders like app history, call data, chats, photos, documents, videos, etc > Create a backup for the uploaded data. Again, the backup process will take a few minutes.
Step 4. Manage Drive
You can also delete useless data and edit the existing ones that are in Google Drive.
Step 5. Transfer
It is pretty simple to transfer data from Android to Android using Google Drive. All you have to do is download Google Drive on your new Android device and log in with the same Google account. Google Drive will have all your data that you can sync or download on your new device.
How to Transfer Data from Android to Android Wirelessly
If you don’t want to use a USB cable to transfer data, how to transfer all data from Android to Android? Near Field Communication (NFC) is a fast and easy way to transfer large files from one Android device to another. If you have NFC enabled on both Android devices and NFC supports Android Beam, then you can press the backs of them together and sync data from one phone to another. But before that, you need to check the settings first, and here are the steps.
Step 1. Open settings on your devices, find and select the Wireless and Networks option.
Step 2. Then, choose Share and Connect.
Step 3. You will see the NFC option. Turn on this feature.
However, if your device doesn’t support NFC, you can transfer data from Android to Android by reading: How to Transfer Files Between Android Devices Wirelessly >
How to Transfer Everything from Android to Android [Samsung]
How do I transfer everything from Samsung to Samsung? If you are using Samsung devices, you can use Samsung Smart Switch to transfer data. It can help you transfer multiple data between two Samsung devices. And you can also choose to use a USB cable to transfer or transfer wirelessly. Here is how to transfer data from Android to Android by using this tool.
Transfer Data with Smart Switch
Step 1. Open Smart Witch on both Samsung devices.
Step 2. On the old device, click on Send data, while on the new device, click Receive data.
Step 3. Next, you can select the Cable or wireless transfer option.
Step 4. Now you can choose data, and then click on the Send button to transfer to the new Samsung device.
How to Transfer Data from Android to Android via Google Account
Every Android device comes with built-in official Google apps that require users to set up their Google account. But maybe you don’t know that Google account can also help you solve how to switch data from Android to Android. This is because setting up a Google account automatically saves the data on your phone. And this is a useful function as it migrates all relevant data from one device to another. Therefore, just read on and follow the steps below to transfer data from Android to Android with Google account now.
Transfer Data From Android to Android via Google Migrate
Step 1. Set Up Google Account
Go to your mobile phone settings > Accounts > Google > Add the credentials of your Google account.
Step 2. Select Data
Then you will have different options to sync such as app data, calendar, contacts, docs, drive, Gmail, Google fit, etc. This allows Google to sync the selected mobile phone data with your Google account.
When you select app data, remember that Google does not transfer all the app data, but many modern apps do support Google syncing.
Step 3. Sync Data
Now, click on the “Sync Now” option. This process will take a few seconds.
Once you set up the same Google account on the new Android device, it will automatically sync the previous phone’s data to the new one.
How to Transfer Data from Android to Android via Bluetooth
Bluetooth is an old-school way to transfer data from Android to Android, but you can’t deny that it is indeed useful. You can move different types of files with it, including ringtones, songs, videos, photos, text messages, call history, contacts, etc. However, you should note that if you have too many files to transfer, it may take a lot of time, and you should also keep the Bluetooth connected. The following is how to transfer everything from Android to Android via Bluetooth.
Transfer Android Data via Bluetooth
Step 1. Pair Devices
Switch on Bluetooth on both devices and pair them. Once the two Bluetooth connections are established you can transfer data from one device to another.
Step 2. Share Files
Whether it is photos, songs, videos, or any other file, select the data and tap on “Bluetooth” in the “Share” options. Select the paired device and tap on “Send”.
Step 3. Receive Files
Allow the other Android device to receive the incoming files. In this way, you can exchange data between Android devices.
How to Move Data from Android to Android via Data Transfer Apps
In addition to the above methods, there are still millions of apps available on the Google Play Store to help you solve how to sync data from one phone to another. With these tools, you can easily transfer contacts, messages, music, notes, photos, video apps, and more. Some of the top transfer apps for Android are ShareIt, Send Anywhere, AirMore, etc. So now, let’s see how to transfer data from Android to Android using these apps:
Transfer Data From Android to Android via Data Transfer Apps
Step 1. Launch Program
Download a transfer app and open the application on both your devices.
Step 2. Select Files
Select the data you want to transfer. Make sure both devices are connected to Wi-Fi.
Step 3. Send Files
Now send data from the previous device and select the new device to transfer.
Step 4. Receive Files
A notification or prompt will appear on a new device asking for permission to receive data. Tap on “Receive”.
Wait for the data to transfer to your new device. In this way, you can shift days from one Android to another.
Transferring data from one device to another seems tricky and stressful. But you do not have to be a tech freak to perform such simple tasks. With the methods mentioned above, anyone can learn how to transfer data from Android to Android easily. And we highly recommend you try DroidKit for free first because it is the fastest and easiest method, and it supports all Android devices. So, get ready to shift to a new Android device without the fear of losing any data!
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
