“Anyone else switching from iPhone to Samsung for the first time? What will you use to transfer contacts onto the S22?” – A user asked on Reddit. This post will show you how to transfer contacts from iPhone to Samsung in some proven ways.
Due to the system limitations of iOS and Android, iPhone contacts are saved on the phone without saving on the SIM card. Samsung contacts can be saved on both the phone and the SIM card. In this case, it’s hard to transfer contacts from iPhone to Samsung directly using the SIM card. Like transferring photos from iPhone to Samsung, how to transfer contacts from iPhone to Samsung is also frequently asked by some users. Here we will introduce 6 useful ways to transfer contacts from iPhone to Samsung 2024.
Droidkit – Android data transfer provides an ultimate way to migrate contacts, photos, messages and more content from iPhone to Android. It helps to transfer contacts from iPhone to Samsung directly. No complicated steps are required and a one-click transfer is available.
With this tool, you can quickly transfer all your contacts in seconds without any hassle. And you don’t need to worry about device compatibility, because DroidKit supports all iPhone and Android devices, such as Samsung, Motorola, Huawei, etc. You can also learn more about DroidKit below.
Now you can get DroidKit for free and follow the steps below to see how to transfer contacts from iPhone to Samsung with simple clicks.
Step 1. Launch DroidKit on your computer. Click the Data Manager option. Then, choose Android Mover mode.
Choose Android Mover
Step 2. You need to select the iPhone to Android mode to continue.
Choose iPhone to Android
Step 3. Now connect your two devices to the computer and click the Migrate Now button.
Click on Migrate Now
Step 4. You need to choose the data types to transfer. Here you can only choose Contacts. Click Next to start transferring.
Select Data to Transfer
Step 5. Please wait for a while until the transfer process is completed.
Data Transferred Successfully
Google Drive is a cloud service that serves a similar purpose to iCloud, and it provides an alternative route for copying your iPhone contacts. If you decide to import your contacts to a Samsung phone via Google Drive you will first need to save the contacts to iCloud, and download the Google Drive app for iOS to the iPhone. With those conditions met, you just need to follow a simple and logical procedure. Just read on to learn how to transfer contacts from iPhone to Samsung via Google Drive.
Step 1. Run the Google Drive app and open the menu, then choose Settings.
Step 2. Choose Backup, then scroll all the way down and tap Start Backup.
Step 3. After your contacts are saved to Google Drive, use the Samsung phone to log in to the same account and download the contacts.
If you don’t want to use computer to send contacts from iPhone to Samsung, you can consider Smart Switch. It is a feature available on newer Samsung Galaxy smartphones that facilitates easy data transfers with a USB cable or wirelessly. It can be used to easily transfer contacts from an iPhone to an Android-based device, without any loss of data. The transferring procedure is very simple and here is how to transfer contacts from iPhone to Samsung.
Step 1. Open the Smart Switch app on the Samsung phone and choose Receive Data.
Step 2. Select the iPhone as the source of the data.
Step 3. Give permission to the iPhone to trust the Samsung device.
Connect iPhone and Samsung
Step 4. Select the contacts you want to move to another phone and tap Transfer.
Since all the data from your iPhone is regularly backed up to iCloud, this online service is another location from which it is possible to transfer contacts from iPhone to Samsung. But how do I import contacts from iCloud to Samsung? While you can’t directly access files saved in iCloud from a Samsung, you can export them as a .vcf file and then download them to the new phone. Just follow the steps below to transfer contacts from iCloud to Samsung.
Step 1. Sign in to your iCloud account and choose Contacts.
Step 2. Select all contacts that you want to be transferred by clicking on the icon next to them.
Step 3. Choose the Export vCard option to save the .vcf file to your computer.
Step 4. Copy the .vcf file with contact data to your Android phone.
Step 5. From the internal storage of the Samsung phone, choose Import contacts from vCard.
Some users may ask: How to transfer contacts from iPhone to Samsung without iCloud? Then you can try another tool called iTunes, which most iPhone users rely on for data backup and other tasks. With a data syncing feature in iTunes, it’s possible to copy all the contacts from iPhone memory and transfer them to a Samsung phone. You can read the step-by-step guide below on how to transfer contacts from iPhone to Samsung using iTunes.
Step 1. Install iTunes to your computer and connect the iPhone with a USB cable.
Step 2. Turn off contact syncing in iCloud and run iTunes.
Step 3. Click on the Device icon, then on Info, and then select Sync contacts.
Step 4. Choose Google Contacts as the destination and confirm this choice.
Step 5. Open your Google Account from the Samsung phone and enable the Sync contacts option.
How to transfer contacts from iPhone to Android? If you just want to transfer a few contacts, you can also mail them to your Samsung or other Android phone. But this method is not suitable for those who have too many contacts to transfer, because it will take lots of time. You can read the instructions below to learn how to transfer contacts from iPhone to Samsung quickly in this way.
Step 1. Open the Contacts app on your iPhone and choose the contact you want to transfer.
Step 2. Scroll down and select the Share Contact option.
Step 3. It will give some options. Choose Mail to send the contact.
Step 4. On your Samsung phone, open the email and then open the vCard file.
Step 5. Now you can save your contact to your device.
Learning how to transfer contacts from iPhone to Samsung is a valuable skill in case you need to change phones in the future. With several simple ways to perform this task at your disposal, users can feel at ease and switch between phones seamlessly while accessing the same contact list regardless of the phone they are currently using. If you want the easiest and fastest way to transfer your data, DroidKit must be your best choice. You can free download DroidKit to have a try. Please share this post with others if you find it useful.
