What to do if you bought a new iPhone and seek to transfer contacts to new iPhone without iCloud? Follow this guide to find the updated solutions, available for all iPhone models, including the latest iPhone 16.
Free download AnyTrans to 1-click to transfer contacts to your new iPhone without iCloud. No data will be erased during the process. It allows you to transfer contacts from iPhone to iPhone without iCloud as well as Android to iPhone. All iPhone models are supported.
When you get a new iPhone (like iPhone 16) the first thing to do is to transfer your important data such as contacts to the new iPhone. Usually, people back up their contacts to iCloud and then restore them to the new iPhone with the same iCloud account.
However, iCloud will erase all the data on your iPhone. And what should you do when you find there is no storage space in iCloud to back up all contacts on your iPhone? Don’t worry. This guide shows you 5 methods to transfer contacts to new iPhone without iCloud.
Transfer Contacts from iPhone to iPhone
We all know that restore the contacts backup from iCloud or iTunes will recover all content at the same time and the existing data on your iPhone will be erased. But with AnyTrans, a professional iOS data transfer tool, you can transfer contacts without iCloud or data loss. During the transfer process, no data will be overlapped or erased.
No matter whether you need to transfer contacts from iPhone to iPhone or from Android to iPhone, you can all use AnyTrans to make it via 3 simple clicks. No skills are needed. More importantly, you can also preview and select which contacts you want to transfer before initiating the process. So the storage will not be occupied by useless data. And for convenience, AnyTrans also offers a batch transfer mode to let you transfer all the contacts in 1 click.
In addition to contacts, photos, messages, videos, WhatsApp data, etc. can also be transferred using AnyTrans. All iPhone models and iOS versions are supported.
Now, Free Download AnyTrans on your computer, and then follow the steps below to transfer contacts to new iPhone without iCloud in simple clicks.
Step 1. Run AnyTrans on your computer > Click on Device Manager on the home screen > Connect your devices to your computer with USB cables > Click on the More option.
Click More
Step 2. Find the Contacts option at the left control panel > Select the contacts you want to transfer > Click on the To Device button to transfer the selected contacts to your target iPhone.
Select Contacts and Click To Device
One of the easiest ways to transfer contacts from the old iPhone to the new one is via Bluetooth. However, as you can only Bluetooth one contact at once if you have too many contacts to transfer, this is a time-consuming method. You also need to make sure a stable WiFi and Bluetooth connection. Then, let’s see how to transfer contacts from one iPhone to another via Bluetooth.
Send Contacts to new iPhone by Bluetooth
Another way to transfer contacts to new iPhone without iCloud is using AirDrop. What you need is to keep your two iPhones close and enable the AirDrop function on both devices. Here is how to transfer contacts from iPhone to iPhone without iCloud using AirDrop.
AirDrop Contacts from iPhone to iPhone
If your iCloud storage space is full, but you don’t want to spend money buying additional storage space, then you will definitely ask this question like most Apple users do: How to transfer contacts from iPhone to another iPhone without iCloud?
iTunes provides Apple users with convenient services to back up and restore mobile phones at any time. However, restoring iTunes backup will restore all data at the same time, and it is impossible to restore certain data such as contacts alone. If you don’t mind that, you can follow the steps below to transfer contacts to new iPhone without iCloud.
Transfer Contacts from iPhone to iPhone with iTunes
Further Reading: What Does iTunes Backup Include >
If you want to transfer contacts from iPhone to iPhone without iCloud free, you can consider using SIM card to transfer. A prerequisite for using this method is that you have previously saved the contacts on the SIM card. Then, you can directly insert the SIM card into the new iPhone, and then follow the steps below to transfer contacts to new iPhone without iCloud:
You May Need: If I Restore My iPhone Will I Lose My Contacts >
With the above methods, you may know the steps to transfer iPhone contacts without iCloud. In this section, we will show you briefly the specific steps to transfer contacts from iPhone to iPhone via iCloud. As you know contacts will sync between iPhones as long as you log in with the same Apple ID on your iPhones and the Contacts syncing option is turned on. Here are the detailed steps:
Sync Contacts to New iPhone via iCloud
Also Read: iPhone Contacts Lost after iOS Update >
That’s all about how to transfer contacts from iPhone to iPhone. No doubt that AnyTrans is the easiest and fastest way for you to transfer contacts to new iPhone without iCloud. Most importantly, it will not erase your device and supports all iPhone models. Without further ado, let’s free download AnyTrans to have a try! If you think this guide is helpful, please share it with your family and friends.
Free download AnyTrans to transfer contacts from iPhone to iPhone without iCloud. No data erasing and leakage. It can also help you transfer other data, like messages, photos, apps, etc. Covers all iPhone models, including iPhone 16.
