4 Ways to Transfer WhatsApp from Android to Android [Updated]
When you change your Android phone, you may want to move your Whatapp account from one phone to another. In this post, we will discuss 4 different ways to transfer WhatsApp data from Android to Android.
Author Avatar Joy Taylor Last Updated: Dec. 29, 2022
The rapid development of technology has also accelerated the update of Android phones, and phone switching has become a common occurrence for people. And with that comes the growing need to transfer data and software from Android to Android. As one of the most widely used social software, WhatsApp data is undoubtedly the first thing people want to transfer because there are many precious memories and important information in it.
Transfer WhatsApp From Android to Android
So in this post, we will enumerate 4 proven ways to help you transfer WhatsApp from Android to Android, as well as a bonus tip for you to transfer WhatsApp from Android to iPhone. So please keep reading until the end.
Can I transfer WhatsApp from one phone to another?
The answer is definitely Yes! Then, how to transfer WhatsApp to new phone?
To transfer WhatsApp from Android to Android, some tools like AnyTrans and Google Drive are good choices. Below we will show 6 methods and detailed steps to teach you how to transfer WhatsApp data from Android to Android. If needed, just read on.
Besides, if you want to know how to transfer WhatsApp from Android to iPhone, a professional data transfer tool can solve how to transfer WhatsApp chats from Android to iPhone. For specific steps, please refer to the Bonus Tip at the end.
Transfer WhatsApp from Android to Android with Computer
If you want to know how to transfer WhatsApp from Android to Android without losing any data, then, AppTrans – App Transfer & Backup is exactly what you need. It is a professional App data transfer tool, which can move different Apps from phone to phone, or phone to computer, so that you can easily transfer WhatsApp to new phone with this software. Below are the specific features of AppTrans.
  • No WhatsApp Data is left behind – All WhatsApp chat history, including messages, photos, videos, and more, can be freely transferred between Android phones. You can take all your precious memories with you.
  • User-friendly – AppTrans simplifies the complexity, allowing you to transfer WhatsApp from Android to Android with just a few clicks. Even technical novices can use it easily.
  • No risk of data erasing and overwriting – AppTrans can merge conversations from two different WhatsApp accounts. Data on both your old and new WhatsApp accounts is kept as intact as possible.
  • Support a variety of Apps – In addition to WhatsApp, AppTrans also supports the transfer of other App data, such as LINE, Viber, Kik, and so on.
Apart from App transfer, AppTrans can also help you figure out how to backup App data and how to restore WhatsApp messages on new phone. Now let’s see how to transfer WhatsApp from Android to Android with AppTrans!
Step 1. Click the green button to Download AppTrans and install it on the computer. Once the installation is completed, you can launch it right away. Also, you should connect both of your Android devices to the computer.
Go to App Transfer and Choose Transfer to Phone
Step 2. Now you can see there are 4 options on the left panel. Choose App Transfer on the left and click on the Transfer Now button under the Transfer to Phone page to go on.
Click Transfer Now Button
Step 3. Then, choose WhatsApp to transfer. After choosing, AppTrans will ask you to set your Android Phone. Just follow the instructions on the screen.
Click on WhatsApp and the Next Button
Step 4. Once you finish setting your phone, tap on Transfer Now to start transferring your WhatsApp data. It won’t take a long time to complete the transfer.
Transfer WhatsApp Successfully
Transfer WhatsApp from Android to Android with Google Drive
Restoring WhatsApp backup using Google Drive on Android is another convenient way to transfer WhatsApp chats from Android to Android. You need to have a Google account logged in on your Android phone to perform this method. If you do not already have the Google Drive app downloaded on your smartphone, you should download it on your new and old phone.
Transfer WhatsApp via Google Drive
Follow these steps to transfer WhatsApp from Android to Android using Google drive.
Step 1. Create a WhatsApp backup on Google Drive under chat backup in the settings menu, choose to back up the media files or just the chat messages and the backup will appear on your Google Drive under backups.
Step 2. After downloading WhatsApp on the new Android phone, set it up. And then, you will be prompted to restore WhatsApp data over your Google Drive account.
Step 3. Select the restore option to restore your WhatsApp data on the new Android phone and this process will take some time as it will restore the entire backup.
[Video Tutorial] Restore WhatsApp from Google Drive to Android
Also, you can refer to video below to know how to restore WhatsApp backup from Google Drive to Android phone:
Transfer WhatsApp from Android to Android with Local Backup
WhatsApp has a built-in chat backup feature that allows you to backup all WhatsApp data including messages, calls, media, etc. This feature makes WhatsApp transfer Android to Android a lot easier, because as long as you have backed up your WhatsApp data before, you can solve how to transfer WhatsApp data from Android to Android by using your backup.
Transfer WhatsApp via Local Backup
Now, follow the simple steps to learn how to transfer WhatsApp from Android to Android using local WhatsApp backup.
Step 1. Open the WhatsApp setting menu > Tab on chats and calls > N-type on chat backup > You will see a backup option and details of your last backup created on WhatsApp.
Step 2. Tap on the backup option. WhatsApp will start creating the backup for all your messages, calls, and media. The backup process will take a few minutes.
Step 3. After backing up, delete the WhatsApp account from the existing phone and Download WhatsApp on your new phone. Then, enter the details of your WhatsApp account.
Step 4. After setting up, WhatsApp will automatically give you an option to restore the WhatsApp backup > Allow WhatsApp to restore the data. This process will take some time.
Transfer WhatsApp from Android to Android with Number Feature
If you want to know how to transfer WhatsApp messages from Android to Android, you can try to transfer by changing the number feature. If there is any chance that you will also get a new number for your new phone, then this method is for you. WhatsApp lets you change the registered number on the app, allowing you to transfer your WhatsApp data to the new device.
Transfer WhatsApp via Number
To learn how to transfer WhatsApp to new phone, follow these steps:
Step 1. Attach your new SIM to the old android phone and make sure it is operational. Then, open WhatsApp on your old device and go to its Settings > Accounts > Change Number.
Step 2. Once you add both the new and the old phone numbers in the respective fields, a one-time generated code will be sent to your new phone number. Enter the code to verify the switch.
Step 3. Go to WhatsApp Settings > Chats > Chat Backup. And then, create a backup on Google Drive or the local storage.
Step 4. Enter the SIM in the new Android phone and install WhatsApp. After finishing all steps, launch WhatsApp and restore the backup to get all the data.
Bonus Tip. Transfer WhatsApp Android to iPhone with AnyTrans
In addition to switching from Android phones to new Android phones, people also switch from Android phones to iPhones. Therefore, how to transfer WhatsApp chats from Android to iPhone is also a big problem for people after switching phones. For these people, we highly recommend a professional data transfer tool: AnyTrans – iPhone Data Manager.
AnyTrans supports transferring all WhatsApp data including messages, photos, videos, and more. And it also has ultra-high compatibility and can work well even on the latest iOS system version. Most importantly, AnyTrans guarantees absolute security and confidentiality of your data and privacy. In addition to transferring WhatsApp from Android to iPhone, transferring data from iPhone to iPhone can also be achieved through AnyTrans.
Here is how to transfer WhatsApp from Android to iPhone.
Step 1. Download AnyTrans on the computer > Connect both Android phone and iPhone to the computer via USB cables.
Step 2. Click on Social Messages Manager > Choose WhatsApp to Device > Click Transfer Now button > Check your devices and click Next.
Click on WhatsApp to Device
Step 3. Follow on-screen instructions to back up and set WhatsApp > Click Next > The transfer process will start automatically.
Transferring WhatsApp to iPhone
Being the most popular messaging app around the world, WhatsApp has become an essential part of our everyday lives. Therefore, it is essential transfer WhatsApp to new phone. By comparison, among the above methods, AppTrans is undoubtedly the easiest way to transfer WhatsApp from Android to Android. And the transfer speed and security of it far exceed those of other methods. So, download AppTrans to switch from one android phone to another without losing WhatsApp data! Moreover, it also helps you to transfer, backup and restore other apps between Android, iOS and computers.
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
