What to Do When Oneplus Switch Is Not Working
Isn’t your oneplus switch not working properly to transfer the data from your One Plus device to other? Here are some detailed options that can help you to transfer data from one device to another.
Author Avatar Joy Taylor Last Updated: Aug. 28, 2024
You can easily transfer data from your previous OnePlus phone to a new OnePlus phone or other using OnePlus Switch, including media files, like audio, video, photos, documents, etc. among other things. Data Transfer across Android and iOS devices is also supported by the OnePlus Switch. But what if your OnePlus Switch not working properly and you need to transfer the data from one device to another? Then you have to look for some other OnePlus Switch alternative that can help you transfer the data to a required device.
Here we have mentioned a few ways that you can use to easily transfer the data from one phone to another just by a few clicks only. Go through the below-given options to find a suitable way to transfer the data.
When you want to transfer any file from your OnePlus phone to another device and found OnePlus Switch not working. There is no need to go here and there, just read this content till the end to get some best alternatives for it.
Here is a list of some OnePlus Switch alternatives that you can use to transfer data from one device to another.
Oneplus Switch Alternative – Android Data Manager
When it comes to alternatives to OnePlus Switch, then AnyDroid is undoubtedly the most comprehensive and convenient of them all. It not only helps you transfer data from Android to Android and from iPhone to Android, but also supports transferring data to computers, etc.
  1. Preview and transfers all types of data from Android to Android with great ease.
  2. Transfer files from Android to Android quickly. According to statistics, AnyDroid can send 1.7 GB of files from Android to Android within 1 minute.
  3. Designed by an Apple certificated developer and it is now also Norton and McAfee secured. You have our guarantee that it does no harm to your devices and accidents like information leakage or data loss would never occur.
Now, Free Download AnyDroid to your computer firstly, then do the following steps.
Step 1. Connect your iPhone and Android phone to computer via USB cables > Choose Android Mover > Click the Android to Android mode.
Choose Android to Android
Step 2. Check the file categories you want to transfer > Click on Next button to start transferring files from Android to Android.
Choose Photos and Click Next
Step 3. After selecting, the transfer process will start automatically. Minutes later, you’ll see the Transfer Completed page.
Android to Android Transfer Complete
Oneplus Switch Alternative – Samsung Data Transfer
One of the most simple ways to fix OnePlus Switch not working is to use Samsung Data Transfer, as it is the most secure app to transfer the data from one device to another. It can transfer the data from your Android phone to your iPhone and vice-versa. Samsung Data Transfer is capable of transferring the media file along with any other data type.
Step 1. At first, you must download and install Samsung Data Transfer. Click on the icon and start the app. Connect your phones to the computer from which you want to transfer the data.
Step 2. When the Samsung Data Transfer recognizes your device, select the files you want to transfer from one device to another.
Choose Data to Transfer
Step 3. Click on the “Start Copy” button to start transferring the data.
Click Start Copy Button
Any kind of disconnection of devices may hinder the data transfer process.
Oneplus Switch Alternative – Coolmuster Mobile Transfer
Coolmuster Mobile Transfer is an advanced OnePlus Switch alternative data transfer tool that works on both Android and Apple phones. You can transfer data between iOS and Android devices. You can transfer any type of data like images, videos, music, etc. from Android to iOS and vice-versa.
Here are some of the steps that you can follow to transfer a file.
Step 1. On your computer, download and install Coolmuster Mobile Transfer. Run the app and use a USB lightning cable to connect the phones to your computer.
Connect Phone to Coolmuster Mobile Transfer
Step 2. Select the data that you want to transfer from one device to another.
Step 3. After selecting the required data, click on the “Start Copy” button to start transferring the data from one device to another.
Oneplus Switch Alternative – MobiKin
You can try using Mobikin Transfer for transferring data from one phone to another if your OnePlus Switch not working. As it is a third-party app, it will not stop working and has no restrictions for any operating system. It can transfer any kind of data from Android to iOS and vice-versa.
Step 1. Download and Install the MobiKin Transfer and launch it on your computer. Meanwhile, connect both the phones to the computer using a USB lightning cable.
Connect Your Phone to Mobikin
Step 2. After connecting both the phones to your computer, it will automatically detect your devices.
Step 3. Select the data that you want to transfer from one device to another and tap on the “Start Copy” button.
Click Start Copy to Transfer Data
Make sure the connection remains established. Once the entire selected data is transferred, you can disconnect your device.
Here we have discussed some of the best alternatives if your OnePlus Switch not working. You can use any of the above-mentioned data transfer tools to transfer the data from one device to another. And in the comparison of these tools, you can see that AnyDroid is not just a replacement for OnePlus Switch, it has many other features, including managing the whole data of Android, transfer iTunes library to Android, etc. So, please download and try it out!
