If you encounter difficulties on transferring data from Android to iPhone and Move to iOS gets stuck on preparing while transferring your data to a new iPhone, there are certain actions that could fix the issue and allow you to continue with the data transfer.
Getting a new iPhone is a happy moment. If you are changing from Android to iPhone, Move to iOS is a tool that is commonly used to transfer all apps and data files to the new iPhone. However, there is a known issue where Move to iOS becomes stuck during the preparation stage and never progresses past a certain point.
Besides, some Move to iOS may stuck on transferring, calculating time remaining, or stuck on 1 minute. Here in this post, we figured out 5 solutions to fix Move to iOS stuck on preparing first.
Fix Move to iOS Stuck on Preparing
It depends on the volume of data that has to be transferred and the internet connection, in some cases taking several hours. But, the exact duration of this step is difficult to predict.
Stay patient and occasionally check on progress, but if the screen remains the same after multiple checks, check the methods below to fix Move to iOS stuck issue.
If you have been interrupted during the process of transferring data from an Android to a new iPhone by a failure of Move to iOS to complete the preparation stage, you have several simple options at your disposal. Depending on the root cause of the problem, one of those options could remove the obstacle and allow you to successfully move your personal data.
The first thing to do when you encounter any software glitch with a new iPhone is to restart your device. This action could potentially eliminate any elements that could be cluttering the memory or blocking Move to iOS from performing its core tasks. To restart an iPhone of the latest generation, just follow the standard procedure for turning the device off and turning it back on:
Restart Your iPhone
To make sure Move to iOS transferring smoothly with Wi-Fi, try to turn off the Smart Network Switch. When the Smart Network Switch is on, Android may use cellular data, not Wi-Fi.
Turn off the Smart Network Switch
Since Move to iOS requires uninterrupted access to the web to complete the transfer, its failure to advance past the preparing step could be caused by an unstable internet connection. To ascertain whether this might be the case, you should check your Wi-Fi router and perhaps try using another web-based application on the phone. If you determine that internet access was in fact interrupted, you can fix the problem by reestablishing the connection and restarting Move to iOS after that.
Access your WiFi Network’s Information
Switching on Airplane mode on your iPhone could help get you unstuck from the preparation step. This simple trick can save you from having to install third-party software, which makes it the preferred solution when it works. Executing this command is very easy – find this feature in the Settings menu or in the App Library, and tap on it to activate it.
Turn on Airplane Mode on your iPhone
If you have a lot of apps active while you are attempting to move data from Android to iPhone, the process might slow down to a crawl due to a lack of RAM memory. Shutting down all of those apps is highly recommended if you are having trouble completing the transfer. You can use the App Switcher feature to find all the apps running in the background and close them with a single tap.
Sure, there is an alternative to move to iOS. With an effective data management tool, it is capable of transferring data from an Android phone to an iPhone. AnyTrans is one of the best iPhone transfers. Moving data between phones with different operating systems is very easy with AnyTrans and doesn’t require any special skills. Just follow the instructions precisely and you will be able to bypass the issue with Move to iOS very elegantly.
Step 1. Download AnyTrans to your computer, launch it, and connect both smartphones to the computer through USB ports.
Step 2. In the main menu of AnyTrans, select the Phone Switcher feature > Select Phone to iPhone > Tap on Migrate Now.
Choose Phone to iPhone on Phone Switcher
Step 3. Specify the source and target device.
Add your Android Phone and iPhone and Click Next to Go on
Step 4. Click Next and then pick categories of data that will be transferred to the iPhone.
Select Files You Want to Transfer
Android phone owners who are switching to iPhone shouldn’t worry about problems with Move to iOS. Even if they run into an issue with this application, several available fixes are very easy to execute. By checking the internet connection and freeing up RAM memory, you can often resolve the impasse, and if all else fails you can always turn to third-party software like AnyTrans.
