5 Best iPhone to Android Data Transfer Apps
If you are looking for a great and effective utility to transfer data from iPhone to Android, you are in the right place. Here in this post, you can find out 5 recommended apps to help you complete data transfer from iPhone to Android easily.
joy Joy Taylor Last Updated: May. 26, 2021
Once you have switched to a new phone, you must wonder how can you transfer data from the previous phone to the new one. Actually, it is relatively easy to transfer data via iTunes and iCloud between iPhones. However, it may be a little bit bothering to switch from iPhone to Android or Android to iPhone.
In order to help the users to find the best suitable tool to fix the data transfer issue from iPhone to Android, this post aims to present you with the 5 best iPhone to Android data transfer apps. Now, keep reading this post to get to know these iPhone to Android transfer tools!
Google Drive
Google Drive is developed by Google which lets users easily store and sync their data like photos, contacts, etc. It also allows storing Google Docs, Google Sheets, and so on. More user-friendly is that it offers 15G free storage space for users to store their files. With it, you can share these files on different devices, both iPhone and Android.
Generally speaking, Google Drive is secure. As you need a Google account to log in to and then you can access the files you store. It is convenient because you don’t need to have many operations. What you need to do is to sync data with Google Drive on your iPhone, then log in to the same Google account on your Android and you could get those stored data.
Please connect both your iPhone and Android to Wi-Fi and charge them so as to transfer files from iPhone to Android smoothly.
Here are the specific steps on how to transfer data from iPhone to Android:
Step 1: Download and install Google Drive on your iPhone
Go to the App Store on your iPhone > search for Google Drive > download and install the latest Google Drive on iPhone.
Step 2: Sync your iPhone data via Google Drive
Run Google Drive on iPhone > enter your Google account and password to sign in > head to Menu > go to Settings > find and click backup option > choose the data you want to transfer > click Start Backup.
Step 3: Find the iPhone data on your Android via the same Google account
When you have signed in to the same Google account on your Android, you can access the iPhone data on your Android device.
Head to Settings on Android > choose Contacts option > click Account > click Add Account option to add Google account > log in with your Google account > enable Contacts option > click Save.
How to Move Data from iPhone to Android via Google Drive
If you want to view the synced contacts data, you need to undergo more steps.
PhoneTrans
Apparently, it is a little bit complicated to transfer data from iPhone to Android via Google Drive. It is particularly time-consuming when you never use the Google Drive app to sync data before since you may take some time to set up a Google account and learn how to back up and restore data on different phones.
However, PhoneTrans can offer you a more customer-friendly solution. With its Quick Transfer function, you can easily and directly transfer various types of data from iPhone to Android.
PhoneTrans: Phone-to-Phone Data Transfer
  • Transfer various kinds of data from iPhone to Android.
  • Select and migrate data from iPhone to Android as you want.
  • Keep old data on your target Android phone, 100% clean & safe.
  • Move data at a lightning-fast speed.
Now follow the steps below and transfer data from iPhone to Android with a few clicks.
Step 1. Download and open PhoneTrans on your computer > Choose Phone to Phone > Click on Quick Transfer.
Choose Phone to Phone - Quick Transfer
Choose Phone to Phone – Quick Transfer
Step 2. Connect and confirm both your iPhone and Android phones > Click on the Transfer button.
Connect your iPhone and Android
Step 3. View the types of data > Select types of data you’d like to transfer from iPhone to Android > Click Transfer to initiate the transferring process.
Select Any Data from Huawei to Samsung
AnyDroid
AnyDroid provides professional data management on Android devices which also supports transferring data from iPhone to Android device. You can easily transfer data with AnyDroid from your iPhone to a new Android device within a few clicks.
Furthermore, the Android Mover function in AnyDroid presents 3 options. To obtain data from iOS devices to a new Android device, AnyDroid can:
  • Directly transfer from iPhone to Android.
  • Restore data from iTunes backups to the Android device.
  • Restore data from iCloud to the Android device.
In the following part, you can get detailed steps to transfer data from iPhone to Android.
Step 1. Download AnyDroid on the computer and launch it while connecting both iPhone and Android devices.
Step 2. Choose the Android Mover on the left panel which will pop up 3 options here. Choose the way to get data from the iPhone.
Choose the Android Mover on AnyDroid
Step 3. Follow the instructions showing along. And hold on for a second, it won’t last for long. After several successfully processing steps, the data transfer from iPhone to Android will be completed.
Samsung Smart Switch
Samsung Smart Switch is one of the best transfer tools for Samsung users to transfer content from iPhone to your Samsung device. It enjoys several major features.
  • It is a tool designed by Samsung and offers only Samsung-targeted data transfer.
  • For iPhone to Android data transfer, it provides the users with various ways to move data. For example, you can transfer contents from iPhone to Android via USB cable, iCloud backup, or iTunes backup with Samsung Smart Switch.
  • It supports the transfer of various data like contacts, video, music, photos as well as many other data. In short, if you have switched from iPhone to Samsung Android phone, Samsung Smart Switch may be the best app for you to transfer contents from iPhone to Android with ease.
 iPhone to Android Data Transfer App - Samsung Smart Switch
iPhone to Android Data Transfer App – Samsung Smart Switch
Also, it’s quite convenient that you can use Samsung Smart Switch on Huawei, LG, HTC, LG, Sony, Lenovo, Motorola, PANTECH, Panasonic, Google(Pixel/Pixel2), etc. It supports lots of Android brand phones in the market.
SHAREit
SHAREit is an excellent app for sharing videos, music, and documents, etc. It is also a popular media player all around the world. As such a well-known app globally, it enjoys some powerful and comprehensive features.
Various features of SHAREit:
  • As a professional sharing app, SHAREit enables users to transfer various data to other devices, such as movies, music, image, and so on. With it, you can transfer videos, etc. to other devices without quality loss. That’s really amazing!
  • It is famous for its fast data transfer speed. Therefore, with it, you can transfer data from iPhone to Android at a fast speed.
  • It enables offline data transfer and enjoys high compatibility with other operating systems.
iPhone to Android Transfer App - SHAREit
iPhone to Android Transfer App – SHAREit
The Bottom Line
In this post, I have introduced the 4 best iPhone to Android Data transfer apps to you so as to help you fix how to transfer apps from iPhone to Android issue and fix other data transfer issues with ease. If you want to transfer iPhone data to a Samsung device, and then choose Samsung Smart Switch. If you prefer to transfer various data from iPhone to Android, Google Drive may be the best one. But we highly recommend PhoneTrans as the most effective app for data transfer from iPhone to Android. You can just download it and give it a try. Anyway, you can choose one of the tools in line with your needs. Hope this article can help you.
joy
