Several great ways to transfer data from Samsung to Samsung were listing in this post. Keep on reading and find out the best way for you to complete transferring data between Samsung devices.
All Samsung phones, regardless of the model offer a broad range of ways to exchange data between them. Sending all your contacts from your old Samsung phone to a new one or sharing your favorite songs with a fellow Samsung user isn’t going to take more than a few moments of your time.
Although the Samsung Smart Switch app is often recommended as the most efficient way of transferring data between two Samsung devices, it is far from being the only method you can use to get photos, videos, audio files, text messages, or contacts from one Samsung phone to another. Also, sometimes Samsung Smart Switch would go wrong without warning.
We’ve shortlisted several easiest ways to send data from one Samsung phone to another that enable you to share different types of files between two Samsung devices. So, let’s take a look at what you can do to transfer data from Samsung to Samsung.
All Android phones are equipped with the Bluetooth feature that enables them to send or receive data from devices they are paired with. However, this data transfer method can be painstakingly long which is why it is ill-suited for sending large media files.
Bluetooth can either be enabled from the Settings app or directly from the phone’s notification shade. You just have to tap on the icon in order to enable this feature.
Locate the files you want to send to another Samsung device after you enabled the Bluetooth function, and tap on the Share icon next to that file.
Your phone will display the list of devices within its Bluetooth range and you should select the Samsung phone to which you want to send the file. A pop-up message will appear on the screen asking you if you want to accept the transfer, so you should just tap on the Accept button to start the data transfer process.
Both devices must remain within the Bluetooth range for the transfer to be successful, since taking one of Samsung smartphone out of the range will abort the transfer.
All the company’s models come with several built-in features that enable you to perform the task of transferring data between two phones quickly and efficiently. Accordingly, they are compatible with a broad range of third-party apps that allow for transferring data from one to another.
PhoneTrans is exactly what you are looking for to transfer data from Samsung to Samsung. With its Quick Transfer feature, you are expected to selectively transfer more than 10 types of data according to your needs, involving contacts, messages, photos, music, etc.
Download the latest version of PhoneTrans and take the following steps to transfer data from Samsung to Samsung in minutes.
Step 1. Open PhoneTrans on your computer > Choose Phone to Phone > Click on the Quick Transfer button.
Choose Phone to Phone – Quick Transfer
Step 2. Connect both your Samsung devices > Confirm them as the source device and the target device > Click on the Transfer button.
Connect Both Your Samsung Devices
Step 3. View and select the types of data you’d like to transfer > Click on Transfer Now icon to transfer data from Samsung to Samsung.
Transfer Data from Samsung to Samsung
Even though this method can be limiting in terms of the size of files you can send from one Samsung phone to another it is arguably the easiest to exchange files between two smartphones. It is also worth noting that this method works if you have one or more email addresses.
Open Gmail or any other email app you are using on your Samsung phone and create a new email. You can decide if you want to send the email to the same address you’re currently logged on to or another one.
Tap on the Attachments option and locate the files you want to send from one Samsung phone to another, but keep in mind that you may not be able to send files larger than 25MB via email. After you send the email that contained the files you wanted to share, you can open the email app on the device to which you wanted to transfer data and download it.
An app like AnyDroid enables you to share various types of data between two Samsung phones using the same WiFi or cables. To transfer data from Samsung to Samsung via AnyDroid, you can take a few minutes to follow the steps below.
How to Transfer Photos from Android to Android – Step 2
Download AnyDroid on your computer > Connect both your Samsung phones with the computer using cables.
Choose Android Mover > Click on the Android to Android mode.
You can then choose if you want to transfer audio files, pictures, videos, or apps and choose the data you want to send to a second Samsung phone.
The Near Field Contact option offers a simple and quick way to exchange all types of data between Samsung phones. This means that you can send contact lists, videos, or photos from one Samsung device to another effortlessly. However, this method will only work if you can put both devices next to each other.
Transfer Data Using NFC
Make sure that the NFC feature is activated on both phones. You can do this by opening the Settings app, and then tapping on the More Settings option. Locate the NFC feature and tap on it to toggle it on.
Put the backsides of both phones together, and hold them like that until you hear the sound that indicates that two devices are now connected.
Locate the data you want to send on your phone and the device will display the Touch to Beam feature on the screen. Tap on it to start the data transfer. Once the process is completed you will get a notification that files were transferred successfully.
Exchanging different types of data between two Samsung phones is easy even without the Smart Switch app. Using the NFC or Bluetooth features is probably the fastest way to get a file from one smartphone to another, although WiFi file transfer apps can also be used for the same purpose.
However, you should bear in mind that transferring large files is going to take a long time regardless of the method you choose and you must ensure that the connection between devices is stable.
Did you find this article helpful? Leave a comment and let us know.
Please enter a valid email address
