some methods are listing in this post to show you how to transfer calendars from iPhone to Android. You can keep on reading and figure out the most suitable one for you to move calendars from your iPhone to Android.
Smartphones have made keeping track of our schedule easy, as the Calendar app enables us to add goals, reminders, tasks, or events to any date of the month. You don’t have to create your entire calendar from scratch if you want to switch from iPhone to Android phone or use both devices simultaneously.
There are several methods you can use to transfer your calendar from iPhone to Android in minutes and in this article we are going to take you through this process step by step.
Moving a calendar from an iPhone to an Android phone doesn’t require you to be tech-savvy, since you merely have to sign in to your iCloud or Google account and copy the calendar from one device to another. Here’s how to transfer a calendar from iPhone to Android.
It would be the most efficient way to transfer calendar from iPhone to Android using a transfer tool. Here in this part, PhoneTrans, which is a professional data migration utility, is recommended. You can switch your data from iPhone to Android with great ease using PhoneTrans. Also, it supports transferring data from iPhone to iPhone, Android to Android, Android, etc.
So let’s check out how to transfer calendars from iPhone to Android with PhoneTrans in detail.
Step 1. Download PhoneTrans on your computer and then connect both your iPhone and Android device to the computer with a USB cable.
Step 2. Launch PhoneTrans > choose Phone to Phone on the left panel > click on the Quick Transfer > tap the Start Transfer to go on.
Choose Phone to Phone – Quick Transfer
Step 3. Here will pop up a window, you need to choose the Calendar and click on Transfer Now to start the transfer.
Choose Calendar to Transfer from iPhone to Android
Minutes later, you will see there is a successfully transferred note.
Google has provided some quite superb services for most Android device users. That’s why you can transfer calendars from iPhone to Android with a Google account. And it would take just a few moments of your time to get your calendar from iPhone to Android.
Step 1. Go to Settings > Scroll down to Calendar.
Transfer Calendar from iPhone to Android via Google Account
Step 2. Tap on the Account > Choose Gmail > Enable Calendar.
Transfer Calendar from iPhone to Android via Google Account -2
If you never add any Google account to your iPhone, you should add one by clicking the Add Account. Also, if the button of the data is unable to click, you should re-log into your Google account by inputting your Google account passcodes.
Add Google Account
You can then sign in to your Google account from an Android device and start using the calendar that was previously only available on your iPhone.
Even though it has a few extra steps, the process of transferring a calendar from iPhone to Android with iCloud is as simple as moving a calendar with a Google account. You just have to follow these steps.
Step 1. Go to the Settings app and open the Passwords & Accounts menu to check if you are signed in to your iCloud account. Tap on the Add Account option if your iCloud account isn’t connected to the iPhone and proceed to give the device permission to sync the local calendar to iCloud.
Step 2. Use a web browser on your computer to sign in to the iCloud account you connected to your iPhone, click on the Calendar icon and choose which calendar you want to send to an Android device. You should then click on the Share option and check the tick box next to the Public Calendar option.
Step 3. Copy the link below the Public Calendar option and paste it to a new tab in your web browser. You will have to change the start of the URL from webcal to HTTP before hitting the Enter button to visit the web address you copied. The ics. file will then be downloaded to your computer.
Step 4. Go to the Google Calendar, then click on the Add Other Calendars icon next to the Other Calendars option and choose the Import option. Locate the ics. file you downloaded from the iCloud account and then click on the Import button. When done, you can proceed to sync the calendar you imported to your Android phone.
Besides cloud storage services there are several third-party apps that enable you to transfer calendars from iPhone to Android devices. However, using Google or iCloud is probably the fastest and easiest way to move a calendar from iPhone to an Android phone.
We hope that this article has helped you transfer calendars from iPhone to Android. Leave a comment and let us know.
Please enter a valid email address
