Even the best smartphone has to be eventually replaced, and it’s crucial to ensure full data continuity when switching to a new model. Ideally, data transfer to new iPhone should be fast and continuous, but in some cases the process just seems to drag on forever. This article explains how to avoid waiting too long for the data transfer by applying some smart tips that have been proven in practice.
Free download AnyTrans to transfer all data from iPhone/Android/Computer to your iPhone in just seconds, including contacts, messages, pictures, etc.
Every iPhone user knows that it’s possible to keep your personal data and all apps when upgrading to a new iPhone. If you have tried doing this with your devices, perhaps you were wondering why transferring data to new iPhone take so long and can this time be shortened. The truth is that a number of factors can affect the final transfer time, and in some instances, the process may even be interrupted and stopped by certain technical issues.
There is no point in spending hours just to transfer the content of your phone, especially since there might be an easy fix within your reach. If you are able to discover what’s slowing the process down, you might be able to alleviate the issue and ensure that your data is promptly conveyed. Alternatively, you could find a specialized software solution for data management that is compatible with the latest version of iOS and bypass the official data transfer method altogether. Either way, it’s important to know your options if you happen to get stuck on the data transferring step.
Bonus Tip: Check out this guide to Transfer Ringtones from iPhone to iPhone >
If you just bought a new iPhone 16 and tried to move the data from your old Apple device onto it, you might have experienced some unexpected delays. There are several reasons why this could happen, and it’s necessary to quickly determine which one might be causing the issue. Here are the most common factors that could affect the speed of transfer or block it all together:
Once you learn why transferring data to new iPhone takes so long in your case, you will be able to resolve the holdup and start using your brand-new device with full access to historical data.
No need to call customer service if your data transfer to new iPhone is not going as expected! There are a few possible solutions that you can try without anyone’s assistance, and one of them might turn out to be right for you. Here are five proven ways to fix data transfer issues between two iPhones that are suitable for all users regardless of their technical knowledge and phone model they have:
Having a broad-spectrum data management app on your iPhone can be a lifesaver quite often, particularly while you are switching to a newer smartphone. AnyTrans is one of the most reliable apps of this type. It has a feature that allows you to quickly transfer large amounts of data from iPhone to iPhone, as well as from Android to iPhone. With the incredibly practical and user-friendly Phone Switcher tool, sending all of your photos, text documents, songs, phone numbers, and even custom ringtones to a new iPhone won’t be a problem at all.
Here is how you can do it:
Step 1. Download AnyTrans to your computer and run it > Choose the Phone Switcher tab from the home screen > Select the iPhone to iPhone option from the menu, and click Migrate now.
Choose Phone to iPhone to Migrate
Step 2. Connect both iPhones to the computer using USB cables. Select the source device and target device > Click the “Next” button to continue.
Confirm New iPhone as the Target Device
Step 3. Select the categories of content (i.e. photos, contacts, etc.) and click Next.
Check Contacts Box to Transfer
Since both phones are connected to a computer with USB cables, strength of the Wi-Fi signal plays no role in this method. When you are using AnyTrans to import data, no fear existing data on the target phone might be wiped or overwritten, so this method is suitable for adding content to an iPhone that’s already been set up and used for a while. Additionally, AnyTrans can help you back up your data, retrieve your social media messages, and complete many other tasks that will improve the functionality of your iPhone and allow you to be more effective when completing various actions.
Sometimes you can significantly increase the speed of the data transfer if you update your old iPhone with the latest version of iOS, such as iOS 16. This action could remove software incompatibilities that were standing in the way of efficient transmission, and restart the transfer at normal speed.
If there are updates available at the App Store, make sure you install them and restart the device before trying to move data from that phone again.
Check for iOS Software Update
Loss of connectivity during the data transfer will halt the process and result in a delay that could last a long time. Users sometimes don’t pay attention to the status of the network connection and consequently conclude there might be a more serious technical problem.
Try to remember to cast a glance on your router or to check the notification bar on your iPhone and ascertain whether the internet connection is active or not. Even if there is some signal, low bandwidth could cause the data transferring to slow down to a crawling pace. This is one of the easiest problems to fix, and you can continue moving data after you ensured a stable and fast connection for the duration of the transfer.
How to Reset Network Settings
Physical proximity between your two iPhones is another factor you should keep in mind. This is especially important when you are moving data with the Quick Start app, which requires the devices to stay near each other while the connection between them is being established. Another important thing is to keep both phones charged so that one of them doesn’t lose power at a key moment.
Keep the two Devices Close
If Airplane Mode is active on your new iPhone, it might not be possible to copy data to it. This is another thing that’s really easy to check as the status of the device is clearly indicated by an icon in the notification tray. After changing the status of the Airplane mode, you should be able to immediately start transferring even if you haven’t restarted the device and iOS.
Turn on Airplane Mode
There are quite a few things that can go wrong with the default data-transferring process between two iPhones. Such issues can typically be resolved without professional guidance, and users are usually able to keep all their personal data, including multimedia files and contacts. It’s even more convenient to use AnyTrans software for this purpose, as it is generally faster than the native tools and capable of transferring literally anything you had on your old iPhone. This app can solve numerous technical issues and is a good utility that protects the functionality of your new smartphone.
