How to use Move to iOS? How to fix Move to iOS not working problem? What is the best alternative for Move to iOS? This guide tells you all the answers you need.
Move to iOS issues can’t be fixed? Try AnyTrans – the best Move to iOS alternative tool to directly transfer data from Android to iPhone (iPhone 16 & iOS 18 Supported ). Free Download it to have a try>>
Whenever Apple releases a new iPhone, there will be an increasing need for iPhone data transferring. If you are an Android (like Samsung or Huawei) user, and you want to switch to a new iPhone this time, the first thing you need to do is move data from your Android to your iPhone. Move to iOS app is the one that helps transfer content from your Android phone to your iPhone 15 for free.
In this post, you will get a full guide on how to use the Move to iOS app, and what to do if Move to iOS not working, and you’ll also get some Move to iOS alternative tools that help you move data with ease.
Move to iOS Issues
Please make sure both your Android phone and iPhone are under the same Wi-Fi network. Make sure your Wi-Fi is stable.
Before using the Move to iOS app to transfer data, clean your Android phone, and delete data you don’t need anymore.
If none of the above works, restart the transferring process and start over.
You can read this guide to learn more about how to fix the Move to iOS taking forever problem >
Make sure that your iPhone and Android phone are not disturbed by calls or other apps until the transfer finishes.
Restart your Android phone and your iPhone.
Make sure the Wi-Fi network is stable on both your Android phone and iPhone.
Forget all Wi-Fi networks on your Android phone and turn off the Smart Switch feature.
Connect your iPhone and Android to a Wi-Fi network, and put them in airplane mode.
If your Android Phone and iPhone don’t have enough power, the Move to iOS can be interrupted by a low battery.
You can read this guide to learn more about How to Fix Move to iOS Transfer Interrupted Problem >
Turn your Android to airplane mode, and off all background applications, to avoid calling in, and some notifications.
On your Android, from the Home screen, tap the App icon > Find and tap Settings > Under WIRELESS AND NETWORKS section, tap WiFi > Tap the menu icon at the upper right corner > Tap Advanced > Set Keep WiFi on during sleep to Always. If mobile data is enabled and you have this problem, it would be better if you disabled the Auto-connect option.
If method 2 does not work, go back to the Home screen on your Android and launch the Phone app > Dial the code *#0011#, and a screen will pop up > Press Menu > Tap WiFi > Find WiFi Saving and turn it Off > Reboot your phone.
To get more info please read on How to Fix Move to iOS Stuck Problem >
Read on How to Fix Move to Wi-Fi Keeps Disconnecting Issue >
Why does Move to iOS say unable to migrate? There are many reasons that are unable to migrate Android to iOS, such as the Android system version, and unstable Wi-Fi connection. Just check the solution below:
Go to this guide to learn more details on How to Fix Move to iOS Unable to Migrate Problem >
The most common reason why your device appears the move to iOS low battery warning is that using the Move to iOS app to transfer data from Android to iPhone can take hours, depending on the size of the files you’re migrating. So, if you don’t charge your phone in time, the transfer process will be interrupted because the phone’s battery is low. However, if the low battery alert still pops up after a full charge, here are fixes:
Go to this post to get more details on How to Fix Move to iOS Won’t Connect Issue >
Hi everyone! I’m a tech support rep for a large cell phone provider, and one of the most common questions I receive is how to transfer data from an Android phone to an iPhone. I suggest that customers use the “Move to iOS” app, but almost 90% of the time, the app encounters an error. I’m wondering if anyone on this subreddit has any tips for an alternative that works better than the “Move to iOS” app.
— A User from Reddit
We’ve heard many people complain that Move to iOS not working and want to find some alternative tools for the Move to iOS app. Is there a better app than Move to iOS? The answer is YES. Here we recommend the best Move to iOS alternative tool to you, you can have a try!
AnyTrans – iPhone Data Manager as an iPhone data manager, can help you fix the Move to iOS transfer failed issue. AnyTrans is committing to making great management on the iPhone. It can perfectly handle all your needs while using an iPhone, including transferring data from Android to iPhone, iPhone to iPhone, iOS to computer, managing iTunes/iCloud data, and more.
As a professional data management tool, AnyTrans can also help users back up, restore, manage, download, etc. This easy-to-use software will bring you more convenience when transferring data from Android to iPhone. Check its key features and free get AnyTrans to have a try.
Step 1. Just download AnyTrans and run it on the computer. Connect with your devices. Click Phone Switcher > Phone to iPhone > Click Migrate Now.
Choose Phone to iPhone to Migrate
Step 2. Confirm your two devices, and click Next.
Click Next to Continue
Step 3. Choose the content you want to move to your iPhone, and click Next to start transferring.
Select All Data on Android to Transfer
Move to iOS app is free & available in Google Play Store, and this app requires Android 4.0 and later and iOS 9.0, or above. Here are steps on how to use the Move to iOS app.
The whole transfer process can take a while, depending on how much data you’re moving to your iPhone. For me, it takes me nearly half an hour to get all data from my Android device to my iPhone. I’ve seen some people complain on Reddit that Move to iOS stuck at “Moving items into place.” It’s been sitting there for almost 2 hours now. The time may depend on:
Contacts, Message history, Camera photos and videos, Web bookmarks, Mail accounts, Calendars, Free apps.
How to Use Move to iOS
If you already finished your iPhone setup, you need to erase your iPhone and start over: Go to Settings > General > Reset > Erase All Content and Settings > Tap Erase > Enter your iPhone passcode > Enter your Apple ID password. Then follow the steps above.
With Move to iOS or the Move to iOS alternatives, you can automatically transfer your Android data to your new iPhone. You can also move your content manually instead. Apple offers you a full guide on how to manually move photos & videos, Mail, contacts and calendars, music, books and PDFs, Documents, and apps from your Android phone to your new iPhone.
If you have any other problems with the Move to iOS app, you can leave a comment below. If this guide is helpful, please share it with your friends. Last, don’t forget to try the great Move to iOS alternative tool AnyTrans. AnyTrans is more suitable for transferring all sorts of data. So just give AnyTrans a free try now>>
