Switching from one Android smartphone to another isn’t an issue when you have the right data transfer app at your fingertip. Our team has researched the net and handpicked the best apps to transfer data from Android to Android without compromising quality.
Android devices can store data like photos, videos, music, and more all in one place- the internal memory. While this is great, you may have challenges trying to move the data from one Android phone to another, in case you are considering changing your smartphone.
For this reason, Android data transfer software was established. With this software, you can migrate content from one Android smart device to another without stress. There are lots of these tools online, but this post will introduce the best 11 data transfer tools to use in 2024. Keep reading!
Designed with fantastic data transfer functions, DroidKit should be your best choice if you are looking for a professional tool to migrate content from one Android to another without hassles. It moves several types of data smoothly between your Android phones with high accuracy and precision.
This software ensures the safe migration of several gigabytes of content within the shortest possible time. DroidKit transfers data like videos, documents, music, ZIPs, photos, and more with high quality without compromising your system.
DroidKit tops our list as the most ideal data transfer solution because of the quality results over time. The software is simple to install and it can be operated by users of all levels, whether tech-savvy or not. You can use it with any Android OS, and it integrates well with Windows and Mac.
Now, just free download DroidKit and follow the steps listed below to figure out how to transfer data from Android to Android in 1 click.
Step 1. Open DroidKit on your computer. On the main screen, choose Android Mover in Data Manager Mode.
Choose Android Mover
Step 2. You need to choose the Android to Android mode on the next screen.
Choose Android to Android
Step 3. Then you should connect your devices to the computer. Once done, click on the Migrate Now button.
Click on Migrate Now
Step 4. You can select the data types and then click Next to transfer.
Select Data You Want to Transfer
Step 5. All you need to do is waiting for a while. Once DroidKit completes the data transfer, you can unplug the Android devices and find out the old Android device’s data which are already on the new Android device.
Data Transferred Successfully
Here is another cool data transfer app to use in 2024. Samsung Smart Switch creates an avenue for you to move data from your old Android phone to another. Though it was established by Samsung, it works for any Android model.
Samsung Smart Switch offers a quick way to transfer content like videos, contacts, documents, and more between Android devices. The interactive interface and other advanced features make it one of the best options to invest in. This app works for all Android OS, from the older down to the latest ones.
Run Samsung Smart Switch
Pros
Cons
LG Mobile Switch is a powerful data transfer tool built by LG to help Android and iOS users export content across devices. This app transfers data via wired and wireless connections. It supports data such as photos, messages, call logs, audio, and many more. Using this app, you can transfer data on any LG mobile device with minimal stress. This lightweight content transfer tool helps you move data freely and quickly.
Transfer Data via LG Mobile Switch
Pros
Cons
With Phone Clone, you can also transfer data from Android to Android conveniently without compromising quality. This Huawei-designed app transfers data seamlessly at a high speed. It doesn’t matter whether you are moving to an older device or a new one, this app is a great option.
Phone Clone app moves data like photos, apps, contacts, messages, calendars, call logs, recordings, and more. You don’t need a data connection or USB cable to migrate data via this app. Also, there’s no premium subscription required for you to use this app. It’s completely free to use.
Launch Phone Clone
Pros
Cons
Xender is an intuitive data transfer app that supports the smooth migration of content from one phone to another. It exports data from Android to Android, Android to iOS, and iOS to iOS. You can also use it to handle data transfer from mobile to computer system.
This app transfers photos, videos, messages, apps, and more, across multiple devices. With Xender, you can move content within four devices simultaneously. No cable or internet connection required to use this app, just ensure both phones aren’t far from each other, establish a connection and you are good to proceed.
Xender
Pros
Cons
Here is another app for managing data across mobile devices and Android to Android isn’t left out. ES File Explorer moves resources such as photos, videos, and more from one Android smart device to another. Besides data transfer, this tool also comes with many additional functions such as cloud storage facilities (Dropbox, SkyDrive, and more), system cleaner, recycle bin manager, and many others.
End-users can also rely on this program for compressing and decompressing ZIP files with minimal hassles. ES File Explorer is a very useful Android utility to own because of the great features it holds.
Transfer Data via ES File Explorer
Pros
Cons
Bluetooth File Transfer is one of the oldest data transfer apps designed for you to manage data between mobile devices, including iOS, and Android. It transfers data from Android to Android, and other operating systems. You can also use it for mobile to computer data migration.
This app ensures all data is shared securely. Bluetooth File Transfer copies data such as messages, photos, contacts, etc., with ease. Also, it’s responsible for cutting, deleting, zipping, and unzipping files. The interface is easy to understand, so anyone can navigate.
Transfer Data via Bluetooth
Pros
Cons
Another great app that offers excellent data transfer services is Send Anywhere, as it allows you to migrate over 10+ types of content across mobile devices. It ensures the safe transfer of data from Android to Android, and other mobile operating systems. Thanks to the built-in 256-bit encryption security feature tucked into it.
This app permits you to send files of any size without tampering with the quality. Send Anywhere handles data like videos, documents, etc. It’s also a nice option for data backup options. With this app, you can easily save store data outside your mobile internal storage.
Send Anywhere App
Pros
Cons
AirDroid is another file transfer software you must have at your disposal if you are looking for a professional tool to move data smoothly from one Android smart device to another from the comfort of your home. This software connects your source and target devices for data transfer operations via wireless connection and it takes a few minutes to successfully move all data between both devices.
With this software, you can transfer several types of data, from photos to contacts, videos, documents, and more. AirDroid also handles screencasting operations, as it lets you mirror your mobile screen on a larger surface like Smart TV and PC. You can also use this software for data backup and synchronization purposes.
Top Android WiFi Transfer – AirDroid
Pros
Cons
For folks looking for a simple way to migrate data from Android to Android, SHAREit is a great option to invest in. With this app, you can share virtually any type of Android data at a remarkably high speed. It’s a well-known app with capability to send over 20 MB of data per second without quality loss.
Besides Android to Android transfer, SHAREit is also cool for managing data across iOS devices. You can also use it to stream your favorite music. SHAREit offers a simple way to link your source and target devices via wireless connection.
Top Android WiFi Transfer – SHAREit
Pros
Cons
Zapya is the last data transfer to try out in 2024. The software offers excellent data transfer speed across your Android devices. It also supports content transfer on iOS, Mac and Windows operating systems. With this software, you can link multiple devices and share data simultaneously without stress.
Transfer Data via Zapya
Pros
Cons
Data transfer from Android to Android smart devices just got easier with the apps above. We’ve handpicked the best apps to transfer data across Android phones. Just select the one that suits your budget, and project requirements. In case you have any suggestions, kindly use the comment section to air your view.
