OK, got it
Device changing and fear of losing TikTok drafts? This article will instruct you how to transfer TikTok drafts to another phone with ease. Because drafts are saved locally, they don’t sync with the device, yet there are ways of copying them either manually or with the help of a cloud drive. We will guide you through a step-by-step overview of how to keep half-completed clips safe.
Drafts in TikTok enable you to reserve half-processed videos for future editing. However, they don’t sync with multiple devices at once, and if you switch to a new phone, the drafts won’t be sent with the account. Thus, you may be stuck if you’ve put a lot of effort into making and refining the videos.
Fortunately, TikTok drafts can be moved to a new device without losing your precious work. This article will explain whether TikTok drafts sync and how they can be moved and saved in a step-by-step guide. The methods listed below address switching to a different device and keeping your TikTok drafts intact. Let’s explore how to transfer TikTok drafts to another phone!
TikTok drafts are stored locally on your device, meaning they do not sync across different phones or accounts. Drafts will not show up when you log in to your TikTok account on a different or new phone because they are not saved in the cloud of TikTok servers. This can be particularly problematic if you need to switch devices or back up the application’s contents.
Unfortunately, all drafts will be permanently deleted once you uninstall the TikTok app or reset your phone. To avoid losing your work, you need to transfer them manually before changing devices. There are several ways to do this, including saving drafts as private videos, using phone backup options for iPhone and Android, or manually recording and saving drafts before switching to a new phone. Let’s find out the best way on how to transfer TikTok drafts to a new phone!
One of the simplest methods of transferring TikTok drafts to a different phone involves saving them in private video format. This option guarantees that drafts will be accessible yet not displayed publicly. Here are the steps that need to be followed to save and transfer drafts:
Step 1: Open TikTok on your current phone and tap on your “Profile” icon at the bottom right. Once done, tap “Drafts” to view your saved drafts. After that, select the draft that you want to move and hit the “Next” option as if you’re going to be posting it but haven’t yet actually put it live.
Step 2: On the posting screen, tap “Who can watch this video” and then select “Only you” to make the video private.
Select Only You Option
Step 3: On the same page, tap “More Options.” Toggle on “Save to Device” to ensure a copy of your draft is saved to your iPhone or iPad. You can find the saved video in your Camera Roll for easy access.
Step 4. Tap “Post” to upload the video to your TikTok account as a private post. You can access this private video from the other device.
This method ensures your drafts are safely transferred, though TikTok may compress the video. Consider using phone backup or manually saving drafts before switching devices to retain full editing capabilities and high-quality video files.
If you need to transfer TikTok drafts to a different device, save them to Camera Roll and then move them to iCloud or Google Drive, a reputable option. This will keep them saved and accessible at any moment on the new device. Here are the steps:
Step 1: Go to your TikTok Profile. Go to “Drafts” and select the draft you want to transfer. Tap “Next,” then tap “More Options” below “Who can watch this video.”
Step 2: Toggle on “Save to Device,” then tap “Post” to save the draft as a private video on your iPhone.
Step 3: Locate the video and then tap the “Share” button. Once done, select “Save to Files,” then choose “iCloud Drive”. On another device, open “Files,” go to “iCloud Drive,” locate the saved draft, then download it to your Camera Roll.
Open iCloud Drive on iPhone
Step 1: Go to your TikTok profile and then “Drafts.” Choose the draft video you wish to transfer, tap “Next,” then tap “More Options”.
Step 2: Toggle to turn ON “Save to Device,” then tap “Post” to save the draft as a private video in your Gallery.
Step 3: Open “Google Drive,” tap the “+” button, then select “Upload”.
Select Upload on Android
Step 4: Navigate to “Videos” or “Gallery,” select the saved draft, then tap “Upload” to store it in Google Drive.
By saving your TikTok drafts to your Camera Roll and uploading them to iCloud or Google Drive, you can easily access and re-upload them on a new phone without losing your content.
If you’re looking for a direct solution to transfer TikTok drafts to a new phone, the solution of recording and saving them yourself is highly advised. This method involves screen recording the drafts and saving them in the video format that will be transferred to the alternate device. The procedures follow:
Step 1: Open TikTok Profile and then go to “Drafts.”
Step 2: Select the draft that you want to send, tap “Next,” and swipe downward from the top-right of the screen to open “Control Center” and tap the “Record” option.
Step 3: Have the draft play and screen record it. Tap the red record bar at the top of the screen and press the “Stop” option once done. Launch the application of the “Photos” and retrieve the video that has been recorded, and if required, trim the extra part of it.
Step 4: Share the video with the new iPhone via “AirDrop,” “iCloud Drive,” or any file-sharing option.
Step 1: Go to TikTok Profile and proceed to the Drafts section. Pick the draft you wish to transfer and tap “Next,” and finally, start “Screen Recorder” from the Quick Settings panel.
Choose Screen Recorder on Android
Step 2: Let the draft play while recording, then tap “Stop” once it’s fully captured. The recorded draft will be saved in your Gallery.
Step 3. Share your saved recording to a new device.
Manually recording your drafts ensures no quality is lost and your TikTok content is safely transferred to your new phone without relying on backups.
Drafts of TikTok are saved locally on the device and not saved within the account. They will be gone if you change the device and don’t move drafts, clear the application data, or if you’re uninstalling TikTok. You should avoid this and keep drafts saved in the Camera Roll or saved in iCloud Drive and Google Drive before changing the device.
There is no built-in option for posting multiple drafts at a time in TikTok. You will need to open each draft individually and tap the option of “Next,” configure the privacy options and post them separately. You might be able to streamline the process if you prepare multiple drafts and schedule them at once quickly.
You might be logged in to your TikTok account on several different devices, but drafts won’t be synchronized among them because they’re locally saved per device. Let us say that you need drafts on a different phone.
In that case, you need to transfer them manually by saving drafts to Camera Roll, uploading them to iCloud/Google Drive, or recording and transferring them.
Transferring TikTok drafts to another phone is essential to avoid losing your work when switching devices. Because drafts don’t sync with each other, drafts must be saved in the Camera Roll and be saved with iCloud or Google Drive. You may also use a device’s phone backup or record drafts yourself if you don’t need them synced with the internet. Through such processes, the TikTok video will not get lost, and it will be easy to keep working and releasing it further.
