Learn about iPhone and Android car crash detection feature, how to activate it, and the simple guide to fix it should you discover that it stops working.
Car Crash Detection is one of the smartest innovations integrated on any smart device. Although introduced on Google Pixel years before now, it’s one of the latest features tucked into the latest iOS models, precisely the iPhone 14 series.
With this feature, your device can track and send signals in case of any car crash. Apart from that, there are several other incredible qualities which will be discussed here in this article. Additionally, we will look at how to activate, and deactivate Car Crash Detection.
However, before going into the aforementioned information, let’s check how Car Crash Detection works. Without further ado, let’s get started.
The Car Crash Detection feature is programmed to send signals to a car driver 10 seconds before a car crash occurs. Should the driver not respond to the notification, a car crash notification is automatically forwarded to contacts on the emergency list. The notification contains crucial reports about your location, time of accident,
The Car Crash Detection system is a safety feature designed to send notifications before and after a severe car crash occurs. This feature works using smart AI to track the speed, sound wave, and air pressure of a moving vehicle so as to alert the driver of a possible crash 10 seconds before occurring. Should the driver fail to connect with the report, your device automatically sends signals to contacts on your emergency list. This signal helps the respondent track the location of the accident.
Turning on/off the car detection feature on your iDevice, Google Pixel, and Apple Watch is no big deal. This part of this article explains the how-to guide for each of these devices. Apply the procedure accordingly.
The Car Crash Detection feature should be active by default. However, if it isn’t, you can enable it by following the instructions below:
Turn on/off Car Detection on iPhone
If after enabling the feature you detect that Car Crash Detection isn’t as effective, you should consider turning it off. Here is how to describe the Car Crash Detection feature:
On your Apple Watch, you can activate the Car crash detection function by following the stepwise guide below:
To disable car crash detection,
If you own a Google Pixel, you can enable the Car Crash Detection festoon without hassles by implementing the step-by-step guide below:
How to Turn on/off Car Detection on Pixel
If after trying car crash detection you don’t find it worthy of the hypes, follow the guide down here to disable it on your Pixel phone:
Should the Car Crash Detection feature fail to work on your iDevice, we advise that you fix your device using an iOS system repair tool. PhoneRescue for iOS is one of the most effective software you can rely on to do this for you.
This software fixes over 50 iOS system errors including the failed car detection issues you are experiencing on your iPhone. PhoneRescue repairs your iDevice without compromising your data, or crashing the system.
Stepwise Guide to Fix Car Detection Failed on iPhone Using PhoneRescue.
Step 1. Free download PhoneRescue for iOS. Then, launch PhoneRescue on your computer and choose “Repair iOS System” mode.
Choose the Repair iOS System Mode
Step 2. After connecting your device, please choose one mode to repair your device. The standard mode can fix most iOS system issues. But it will erase all data on the device. But it will erase all data on the device. Please think twice before launching the operation. We suggest that you go to the “Standard Mode” only if the “Advanced Mode” fails.
Select the Advanced Mode to Fix Your Bricked iPhone/iPad
Step 3. And then, please follow the 3-step instruction in the window to enter “Recovery” mode.
Put Your iOS Device into Recovery Mode
Step 4. After entering “Recovery” mode, please check your device info. To repair the abnormal operating system, please click “Download” button to download the firmware for your iOS device.
Click Download to Get Firmware
Step 5. After downloading firmware package, PhoneRescue will repair your iOS device to normal automatically. Please don’t unplug your device before the iOS repairing process is finished.
Repair the iOS System Issue
Step 6. Minutes later, when the repairing process is complete, you will see the iOS repairing completed page.
iOS Repairing Completed
You may also be interested in knowing how to fix iPhone black screen.
Not all iOS models, and Android brands have the car crash detection feature integrated into their system. Here are just a few that supports the feature:
The Car Crash Detection feature is programmed to detect the following types of car crashes:
Activating or deactivating the car crash detection feature on your iPhone, Google Pixel, Apple Watch, or Android smartphones shouldn’t be a challenge with this guide at your disposal. Implement the corresponding guide for the device you own.
