3 Ways to Make Windows 8 Computer Faster
Windows 8 computers are not known to slow down. However, if yours has slowed down, the following guide offers three tips for you to speed up your Windows 8 PC. Read on to find out what the speed improvement tips are.
By Faye Clarke | Last Updated: Apr. 17, 2020
While Windows 8 based computers do not usually slow down, sometimes things go weird and you may face a slowdown in the performance of your computer. If that is the case, the first thing you will want to do is investigate the cause of the issue. Then, find out what are the methods to get around the issue on your PC.
To help you out with your task, here we have put together a guide that shows how to speed up a Windows 8 PC using three easy ways. None of these methods require you to run any commands or build apps. These are simple and easy to implement methods for you to increase the performance of your system.
Let’s check them out:
How to Speed Up Windows 8
Although the tips given below are easy to use and they do not harm your computer, you should know what you are doing to avoid any unexpected outcomes. With that out of the way, here are the methods to speed up a Windows 8 PC.
Way 1. Manage Startup Apps
Startup apps are the main reason why most computers run slow. When you add an app to the startup list, your computer launches the app as soon as you boot your computer. While this may not affect the performance if you only have a few apps in the startup, issues start to occur when your startup list is quite large.
Disable the unwanted apps from the startup apps list
Therefore, it is advised that you do not keep a lot of apps in the startup list. It will help save resources on your machine that you can use for your other tasks. You can always launch any app that is not in the startup list by simply clicking on the app icon on your desktop. So removing an app from the list does not affect the app functionality at all.
Way 2. Change Power Settings on Your Computer
Your Windows 8 computer comes with multiple power options. Each option has its own advantages and disadvantages. For example, choosing the power saving mode will save your battery power but it will have a negative effect on the performance of the computer.
Configure power options to improve performance
If you want your Windows 8 computer to run faster, you can choose the High performance power option. It will use more of your power but it will provide you with better performance. If you are not happy with it, you can always change it to something else from the Control Panel on your PC.
Way 3. Clean the Cache of your System
Cache files are created by various applications to quickly serve you the content you are looking for on computer. However, storing a lot of cache files on your computer is not a good idea as it takes away your valuable memory space and slows down your computer.
Fortunately, there is an app to help you deal with the ever-increasing cache files on your computer. It is called Ashampoo WinOptimizer and it allows users to get rid of all the cache files at once on your computer. All it takes for you to clean cache is to click a button and you are all set.
The following is how you do it:
Step 1: Go to the Ashampoo WinOptimizer website and download and install the app on your computer.
Step 2: Launch the app on your computer, select Maintain system in the left sidebar, and choose Drive Cleaner from the right panel.
Use Drive Cleaner to get rid of unwanted files from your PC
Step 3: The following screen will list the type of files to be deleted from your computer. Click on the Delete now button to continue with the process.
Delete unwanted files from your computer
Step 4: Wait for the app to clean cache from your computer. When it is done, you will see the following message on your screen.
Drive Cleaner completed its task
You have successfully removed the unwanted cache files from your Windows 8 PC.
It is common for a PC to slow down as it ages and the above guide will teach you how to deal with it and speed up your Windows 8 computer. We hope it helps you improve your computer’s performance so you can do more in less time.
Faye Clarke Twitter Share Facebook Share
Member of iMobie_Inc, an enthusiastic fan of Apple and Jazz music, always ready to offer advice and solutions to any iOS & Android related issues.
