How to Speed Up Computer Startup
If your computer takes forever to start-up, there could be issues in your system. The following guide offers some of the ways for you to speed up your computer startup so you do not need to wait for long. Read on to learn more.
By Joy Taylor | Last Updated: Apr. 16, 2020
When you first booted-up your computer, how long did it take for you to get to the desktop? Probably a few seconds. As you store more data and apps on your computer, your machine starts to run slower and takes much longer to even start-up. If you are in this situation, we have a few methods for you to speed up your computer.
The following guide covers some of the common fixes that you can apply to your PC so it boots-up faster. All of the methods given in the guide are extremely easy to follow and these methods do not harm your computer in any way. If you are ready, here is how you speed up your computer’s start-up time:
How to Speed Up Computer Startup with Common Tricks
While there are a number of third-party apps available to help you improve your boot time, you may first want to give a try to the built-in methods on your computer to see if they bring any changes to the performance of your system.
In this section, we offer three easy to follow tricks for you to speed up your machine.
Trick 1. Change the BIOS Settings
BIOS is nothing but the blue screen that appears when you press the Del key when your PC is about to boot. While your system automatically sets values in the BIOS for you, you may want to tweak a few settings here and there to ensure your computer boots up faster.
Some of the things you can do are give priority to your main hard drive where your operating system is installed for boot-up. That way, your computer will not have to load all of the drives connected to your machine to find out where the operating system is.
You may play around with a few other options but make sure you know what you are doing so as to avoid any issues from occurring on your system.
Trick 2. Disable Hardware Components
It may be that a number of hardware devices are attached to your computer but you are not using them. If that is the case, you may want to temporarily disable all of those devices so your PC does not have to load them during boot-up.
When you disable a hardware device, your PC does not look for the device drivers and so you save a few seconds for boot-up. A device can be disabled using the Device Manager utility that comes preloaded on your Windows PC.
How to Speed Up Computer Startup - Disable Hardware Devices
How to Speed Up Computer Startup – Disable Hardware Devices
Trick 3. Install an SSD Drive
If you still happen to use a traditional HDD on your computer, it is time you switch to a faster Solid State Drive (SSD). An SSD provides much faster data transmission rate compared to an HDD and it is an item worth investing in. Once an SSD is installed, you will see a significant improvement in the startup of your computer.
How to Speed Up Computer Startup with Ashampoo WinOptimizer
While many of the optimization tasks can be done manually as shown above, there are a few tasks that either cannot be done manually or take too much of your time. These tasks involve cleaning up your system of any junk files and ensuring everything is properly set up.
Fortunately, there is an app called Ashampoo WinOptimizer that helps you with these tasks. The app automatically finds and removes junk files and provides you with a one-click optimization service for your PC. Some of the features worth checking out in the app are:
The app is definitely worth using for cleaning up your system to improve startup time. Download Ashampoo WinOptimizer on your computer and the following shows how to speed up computer startup.
Step 1. When the app is installed, open it on your PC by double-clicking on its icon on your desktop. Click on All modules and then click on One Click Optimizer in the app.
How to Speed Up Computer Startup with Ashampoo WinOptimizer - Launch One Click Optimizer
How to Speed Up Computer Startup with Ashampoo WinOptimizer – Launch One Click Optimizer
Step 2. Choose work mode on the following screen, leave the settings as is, and click on the button that says OK.
How to Speed Up Computer Startup with Ashampoo WinOptimizer - Review Options
How to Speed Up Computer Startup with Ashampoo WinOptimizer – Review Options
Step 3. You should be able to see what the app is doing in realtime on your screen.
How to Speed Up Computer Startup with Ashampoo WinOptimizer - Tasks Being Carried Out
How to Speed Up Computer Startup with Ashampoo WinOptimizer – Tasks Being Carried Out
Step 4. When the app has optimized your PC, it will show the following message.
How to Speed Up Computer Startup with Ashampoo WinOptimizer - Tasks Finished
How to Speed Up Computer Startup with Ashampoo WinOptimizer – Tasks Finished
That’s all there is to optimizing your startup time with the Ashampoo WinOptimizer app.
If it is taking too long for your computer to start-up, the above guide should help you resolve the issue so you can quickly get to your desktop. It also offers a third-party app for you to quickly and easily optimize your PC for a better boot time.
