If your computer has become messy and you think it needs some cleaning, you can use any free computer cleaner app to do the task. The following guide lists some of the best computer cleaners you can use on your machine.
Over the time as you install more and more apps and files on your computer, your computer starts to become messy unless you regularly clean it with your cleaning methods. Earlier, users had to manually find and delete junk content from their computers. Fortunately, you do not have to do that any longer as there are now a number of computer cleaner software available in the market to do the task.
The main purpose of this software is to help you clean your computer of any unnecessary content so you have more memory space available as well as your computer works faster. If you have not used such software before, the following guide has some of the best computer cleaner apps that you can use on your computer.
If you are looking to thoroughly clean your machine of temp files, Internet files, cache files, and many other unnecessary files, Ashampoo WinOptimizer is your best choice. The app has a number of tools built into it that help you clean up various parts of your system.
Best Computer Cleaner #1 – Ashampoo WinOptimizer
With the Ashampoo WinOptimizer app on your computer, you can fix invalid entries in the Windows Registry, delete temp and other files to reclaim your memory space, and perform numerous other tasks with the click of a button to optimize your computer.
The app works like a charm on Windows PCs and helps users quickly get rid of unwanted content from their computers. You can’t go wrong choosing this app as your main computer optimization app.
One of the things that occupy a large amount of the memory space on your computer is preinstalled apps. These apps are also called bloatware and your operating system provider gives you these apps thinking you would use them. Unfortunately, that is not the case with everyone. Some users may not like these preinstalled apps on your computer.
Best Computer Cleaner #2 – System Mechanic
With the System Mechanic app, though, you can get rid of these apps from your computer resulting in a clean computer. The app helps remove many other type of clutter including unnecessary files, issues, Internet files, and so on.
It is indeed a good app to free-up your computer of any clutter.
AVG TuneUp consists of many small modules that help you fully clean up your Windows based computer. It identifies issues with your registry and fixes them, runs an automatic maintenance to ensure your computer continues to run optimized, and does many other optimization tasks.
Best Computer Cleaner #3 – AVG TuneUp
It also helps remove bloatware and junk apps cleans your disk of any unnecessary files, removes unwanted files from your browser, and does pretty much everything to ensure you have got no clutter on your computer.
BleachBit is an open-source app that helps you clean your system to free-up your precious disk space. It helps remove log files, junk files, Internet cache files, and many other types of files from your computer to speed up your computer and make more memory space available to yourself.
Best Computer Cleaner #4 – BleachBit
It even finds the junk files on your computer that you didn’t know existed. The app has a simple and easy to use interface that anyone from a novice to an expert can use to clean up their computers. If you are looking for a cleanup tool in the open-source category, BleachBit is the one to go for.
Comodo System Utilities claims to be an all-in-one solution to cleaning junk files and Windows Registry entries from your computer. One of the features in the app called safe delete ensures your important files do not get deleted while cleaning your machine.
Best Computer Cleaner #5 – Comodo System Utilities
One of the modules called Active Cleanup of the application runs in your background and ensures any issues are fixed as soon as they occur on your machine. It is indeed an intelligent app to have for cleaning up your machine.
If you have been looking for a good computer cleaner software for your PC, the above guide provides you with five of the best software to use to keep your machine clean of any junk content. We hope it helps you find a software that does the job for you.
