How to unlock an iPhone without passcode? Here are the unlocking solutions ff you forgot your iPhone passcode.
Your iPhone is secured with a passcode that you chose during the iPhone setup process. This passcode is what you need to enter each time you want to unlock your device. This is basically the key to your phone without which your phone remains locked. If you ever forget the passcode of your iPhone, your iPhone will not let you in. Everything on your phone will become inaccessible and you will be stuck on the iPhone lock screen.
Free download AnyUnlock to unlock your iPhone when you forget your passcode.
If that ever happens, you might want to look for ways to do it when you forget your iPhone passcode. Luckily, you are not out of options. There are some methods to unlock your phone when you have forgotten the passcode. These methods do not use the traditional passcode method to get into your phone and so they work without a passcode.
If you don’t have the time to go through lengthy procedures to unlock your locked iPhone, then you are going to need to use a third-party app to unlock your phone. One of the apps you can use to unlock the screen passcode on your iPhone is AnyUnlock – iPhone Password Unlocker. As the name suggests, this app allows you to remove almost all types of locks from your device. All you need to do is plug your device into your computer, run the app, and it will help remove the lock that your phone has on it. Check what else it can do for you below.
Steps to Unlock an iPhone if Forgot Screen Passcode:
Step 1. Download and launch AnyUnlock on your computer. Connect your iPhone to the computer, wait until AnyUnlock has detected your iPhone, and click Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Click Download to get the iOS firmware downloading page, this is for unlocking the screen passcode.
Get a Matching Firmware
Step 3. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now
Step 4. And when the recovery process is completed, you will see the Screen passcode removed successfully interface.
iPad Unlocked Successfully
1) All the existing content and settings on your device will be erased once the removal process is completed, please make sure you’ve made backups of your device.
2) After unlocking, your iOS system version will be updated to the latest version.
3) If Find My iPhone on the device is turned on, you need to enter the iCloud account password to set the phone after unlocking.
If you have access to a computer, you can actually use many methods to get rid of the passcode lock from your device. However, if you are at a place where you cannot access a computer, or you simply do not wish to use a computer to unlock your device, you are still in luck.
There is actually an official method to unlock your passcode-protected iPhone without using a computer. This method uses your iCloud account on the web to get you access to your iPhone. Once you are in your account, you can remotely perform an action on your iPhone. This action will wipe off all the data on your phone and reset it to the factory settings.
That might sound a bit too technical but you can do it pretty easily with the instructions below. Keep in mind that this procedure will erase all your data stored on your device. If you have backed up your data with iTunes or iCloud, then you should be able to restore those backups and get back your data.
Erase the iPhone from iCloud
Like Android devices, your iPhone also comes with recovery mode to help you in situations when you cannot enter normal mode. With this mode on your iPhone, you can connect your phone to the computer and use iTunes or Finder to restore your device.
Restoring your iPhone with iTunes or Finder basically installs a clean version of the iOS operating system on your phone. Everything that you have stored on your phone gets deleted but you can restore a backup later on if you need access to your old data. You will want to use this method when your phone will not let you enter the main screen and you cannot recall the passcode.
Restore the iPhone
The following shows how you can use this method to unlock your iPhone when you cannot remember your passcode.
iPhone 8 or later: press the Volume Up button and let it go, press the Volume Down button and let it go, press and hold down the Side button until recovery appears.
iPhone 7 or 7 Plus: Press and hold down both Top (or Side) and Volume Down buttons together. Release the buttons when you see recovery mode.
iPhone 6S or earlier: press and hold down both Home and Top (or Side) buttons at the same time. Your iPhone will enter recovery mode.
Once your iPhone is restored, the passcode will be reset. You will be able to get into the device without entering a passcode.
Most iPhone users use iTunes or Finder on their computers to make full backups of their devices. If you are one of those users, you have likely created at least one backup of your iPhone with these tools. In this case, you can actually restore the backup on your iPhone and that will unlock your device for you.
Restoring a backup only requires you to connect your device to your computer. You can then restore any of your backups on your device. Many users have multiple backups and you are free to restore any of those backups on your iOS device.
When you restore your backups, all the existing data on your iPhone will be deleted. If you have added any new files to your device after creating the backup, those files will be gone from your device so keep that in mind. This procedure will only restore the files that you backed up in your backup file.
Choose A Backup to Restore on iPhone
If you factory reset your iPhone when forgot the passcode, you can request a new 6-digit passcode after reset. Here are the steps:
By the way, here are some common 6-digit codes that you may try when forgot your passcode:
Do not panic if you have forgotten your iPhone’s passcode. The above guide tells you what you should do if you ever forget the passcode for your iPhone. It walks you through various methods to remove the lock from your phone and use it as normal. We sincerely recommend you download AnyUnlock and have a try now!
