iPhone is not only a stylish accessory but also a reliable fortress for safeguarding your valuable personal information. Among its many security features, the activation lock is especially popular with users. Keep reading, and you’ll find out many interesting things about the activation lock of the iPhone.
If you forgot Apple ID and password to activate iPhone, just free download AnyUnlock to solve this problem. It allows you to bypass activation lock even without entering Apple ID or password. All you need to do is click on the buttons. And the activation lock removal will complete in only a few minutes.
What Is Activation Lock on iPhone/iPad/Apple Watch
If you’ve ever lost or had your iPhone stolen, you know the feeling of panic and vulnerability that comes with it. But fear not, because Apple’s got your back with Activation Lock.
Now, what exactly is Activation Lock, and how does it work to protect your devices?
In this article, we’ll explore everything you need to know about Activation Lock, including its purpose, functionality, and how to remove it if necessary.
So let’s start with a closer look at what Activation Lock means for your Apple products.
Further Reading: Bypass iCloud Activation Lock for Free>>
Activation Lock is a significant security feature added to all Apple devices running iOS 7 and above. It was introduced to provide a strong layer of protection against unauthorized access to the device.
The feature is handy in situations where the device is lost or stolen. Because even if the thief tries to erase the device remotely, the Activation Lock will still protect it. This makes it almost impossible for anyone without your Apple ID and password to access it. This feature could be the key to recovering your lost or stolen device and potentially saving you from a lot of hassle and stress.
But you may be wondering how this outstanding feature works. Let’s answer this simple question now.
When Activation Lock is enabled, it binds the device to the owner’s Apple ID and requires the correct login credentials to unlock it. This means that even if the device is wiped clean or restored to factory settings, it will remain locked until the valid login credentials are entered.
To enable Activation Lock on an Apple device, users must sign in with their Apple ID and turn on the “Find My” feature. Once enabled, the device will lock when the “Find My” feature is activated from another device using the owner’s Apple ID and password.
Now the question arises, how can we remove the Activation Lock once it’s enabled? Here we go with the answer.
Yes, removing Activation Lock from your iPhone, iPad, or Apple Watch is possible. However, removing the lock varies depending on whether you have the password for the associated Apple ID. You can easily disable the lock from the device settings if you have the password.
Go to the device Settings > Apple ID > Find My and toggle off the Find My iPhone.
Now’s the time you’ll be asked for your Apple ID password.
Disable Activation Lock
It is essential to understand that any unauthorized attempt to remove an Activation Lock is against the law and may result in criminal prosecution.
But sometimes unforeseen circumstances can arise, such as forgetting your Apple ID or password, purchasing a second-hand iPhone, or encountering a stuck Activation Lock screen.
In such cases, you may need to bypass the Activation Lock without a password.
Let’s see how to do it.
Is it possible to remove the Activation Lock without using an Apple ID/password? Yes, without a doubt. AnyUnlock – iPhone Password Unlocker is a professional tool for bypassing iCloud Activation for your locked device.
It can help you unlock various types of locks on your iPhone or iPad as a complete iOS password unlocker. You can quickly bypass iCloud Activation Lock with AnyUnlock even if you don’t have an Apple ID or password.
Free install the lastest version of AnyUnlock to give it a try!
Step 1. Get the AnyUnlock and installed it on your computer. Then click on the Bypass iCloud Activation Lock from the main interface.
Step 2. Connect your iPhone to the computer. And hit the Start Now button to process forward.
Connect Your iOS Device to the Computer
Step 3. Please follow the Jailbreak Tutorial to jailbreak your device since there is no direct jailbreak tool for the Windows system in the market currently. If your device is jailbroken successfully, please go back to the software and click on the Next button to continue.
Jailbreak Your Device
Step 4. After that, Confirm your device information and disconnect your device from Wi-Fi and turn off cellular data and click on the Bypass Now button.
Confirm Your Device Information and Start Bypassing
Step 5. Wait until the process is finished. When the iCloud Activation Lock is bypassed successfully, you can see the page below.
iCloud Activation Lock Is Bypassed Successfully
It is important to note that this method may come with some limitations. Effects of jailbreaking, locking your device after resetting, and restrictions on supported iOS versions are some potential issues you may encounter. That’s why we always recommend contacting Apple’s support and following their account recovery process to ensure a safe and reliable solution.
Step 1. Free get AnyUnlock on your Mac > Connect your iPhone with Mac > Choose Bypass iCloud Activation Lock and Start Now.
Step 2. Now, please click the Start Jailbreak button if your device hasn’t been jailbroken yet. Follow the on-screen Jailbreak Tutorial to jailbreak your device.
Start to Jailbreak Your Device
Step 3. When your iPhone is jailbroken, tap on Bypass Now.
Tap on Bypass Now to Start Bypassing
Step 4. Wait the bypassing process finished, and you will see the interface below.
Please DO NOT log into iCloud from the Settings on your iPhone iPad iPod touch or factory reset your device which will lock the device again.
Before we end our discussion, let’s briefly look at some of the frequently asked questions about Activation Lock.
Checking the Activation Lock status is crucial when determining if a device can be used or sold. And you need to know your IMEI number to check the iCloud activation lock status. Enter this number on some online iPhone IMEI checker, and all the related information will be shown. You can check the iCloud activation lock status from there.
Activation Lock and iCloud Lock are often used interchangeably, but they are not the same.
Activation Lock is a security feature introduced by Apple in iOS 7 and later versions. It is designed to prevent unauthorized access to an iPhone, iPad, or iPod touch if lost or stolen.
But iCloud Lock is a broader term that refers to any iCloud-related security feature. This can include Activation Lock and other features like Find My iPhone/iPad/Mac. All these allow the owner to locate, lock, or wipe the device if it is lost or stolen.
To remotely lock your device, you can use the Find My app on an iPhone, iPad, or Mac or your iCloud account on a computer. In either of these, once you have entered your Apple ID and password, select your device from the list and click on the Lost Mode/Lock.
You’ll need to enter your password again for confirmation, and then you can lock your device remotely.
Activation Lock is Apple’s way of ensuring no one messes with your precious iPhone, iPad, or Apple Watch. In this article, we’ve gone over various aspects of Activation lock, like “What is activation lock,” how it works, and how to remove it usually, as well as using AnyUnlock.
AnyUnlock allows you to remove the iCloud Activation Lock with the simplest operation and the highest success rate. Simply download AnyUnlock for free to give it a try.
