Easy Ways to Unlock SIM Card with/without Jailbreak
Is your iPhone not supporting any other SIM card than the previous one? This is because your phone is locked to a particular SIM card carrier. Read this post till the end to know how to unlock SIM card without jailbreak.
Author Avatar Joy Taylor Last Updated: Aug. 28, 2024
Sometimes you buy a new or second-hand phone that is locked to a particular network carrier without having a look at it. This is because you are getting good deals or discounts while buying the phone, and later on, you regret the same. In such conditions, you might be looking for some ways to unlock a SIM card locked phone.
Unlock SIM Card without Jailbreak
To unlock a phone, there may be reasons like, you want to use a network with cheaper tariff plans, the present network is not working well in your geographical location, you want to use an international SIM on your phone, etc. Due to these reasons, a user might wish to change the SIM card carrier.
Here, we are mentioning the 2 easy ways to unlock SIM card with/without jailbreak. These methods will help you to unlock a SIM card locked phone in a simple and quick way. Stay till the last word to figure out the steps to easily unlock an SIM locked phone.
Further Reading:
Can I Unlock My SIM Card Myself?
Yes, you can unlock a SIM card yourself. You can simply contact your SIM card provider company or use any third-party app for the same. While contacting your network provider is a time-taking process, turning to the SIM carrier may avoid jailbreaking your iPhone. Find here how to unlock a SIM card without jailbreak.
Unlocking a SIM from a particular SIM carrier allows you to use other carriers that have cheaper tariff rates. The most significant use of these SIM unlocked phones is while using an international SIM.
How to Unlock SIM Card without Jailbreak?
There are few ways using which you can get to know how to unlock SIM card without jailbreak. The most popular one is via using iPhoneIMEI.net. You simply need to go to its homepage and fill the required details.
The process is easy but it really is time-taking. To unlock your iPhone using this method can take approximately up to 5-7 days.
These steps will help you know how to unlock SIM card without jailbreak.
  1. Go to iPhoneIMEI homepage to unlock your iPhone. Click Unlock after entering the iPhone model and the network provider to which it is locked.
  2. Enter your iPhone’s IMEI number. Finish the payment by selecting Unlock Now. IPhoneIMEI will submit your IMEI number to the network operator and whitelist it in Apple’s activation database after successful payment.
  3. iPhoneIMEI will give you an email with the subject “Apple iPhoneIMEI” within 1-5 days “Thank you very much. It’s time to unlock your iPhone”. When you receive the email, simply connect your iPhone to a Wi-Fi network and enter any SIM card, and your iPhone should start working right away.
Bonus Tip. How to Unlock SIM Card with Jailbreak?
If you have used above given method, but didn’t find it suitable to unlock your SIM locked phone or don’t want to use it as it takes much time to resolve any issue. Then, you must use some other professional tool such as AnyUnlock – iCloud Activation Unlocker. AnyUnlock can help you unlock a SIM card locked phone. This is one of the most efficient and effective ways of how to unlock SIM card with simple clicks.
AnyUnlock can be used to unlock any kind of SIM cards, i.e., AT&T, Vodafone, Sprint, Verizon, etc. so that you can easily switch from one SIM carrier to another. The app is 100% safe and you can even use AnyUnlock to unlock a blacklisted iPhone.
Follow the below-mentioned steps to know how to unlock SIM card with jailbreak.
Step 1. Download AnyUnlock – iCloud Activation Unlocker and install it on your computer. Run the app and on the home-page click on the Start Now button.
Choose Remove SIM Lock
Step 2. Use a lightning cable to connect your phone to the computer, and check the device’s information thus displayed on the screen. If the given information is correct click on ‘Remove Now’, otherwise take the on-screen steps to jailbreak your device.
Click Remove Now
Click Remove Now
Step 3. On the next screen, you will find some instructions. Pull out of the SIM card and follow up the steps to disconnect your device from the Internet. Don’t remove the phone in-between, otherwise, you need to start the whole process again from the beginning.
Pull Out of SIM Card and Disconnect the Internet
Step 4. It will automatically start unlocking your SIM. Wait until the process is completed. Once the SIM card is unlocked, you can remove the phone and check it.
SIM Lock Removed Successfully
These are the two most prominent options when it comes to how to unlock SIM card without jailbreak. We recommend you to use AnyUnlock – iCloud Activation Unlocker to unlock a SIM card locked phone and use it with another carrier. It can work in just a few clicks without taking much of your time.
