Have you forgotten the password to your iPhone notes and now require access? You must have searched a lot about how to get into locked notes on iPhone, but let your forage end here. This guide will underline various methods on how to unlock notes on iPhone without password.
Free download AnyUnlock to access a locked iPhone or iPad without a password.
I forgot the password for my locked notes. How can I reset the password?
Apple Notes is an outstanding application for iPhone, iPad, and Mac users and allows you to create notes using a password. However, there could be instances where you locked some of your private notes, and now you do not remember your Apple Notes login credentials anymore. It is entirely normal not to remember your password anymore. So, please do not panic, as we have the solution here for you.
Access iPhone’s Locked Notes
Your iPhone will allow you to set a different password for your notes than your iCloud credentials. Nonetheless, if you do not remember your Apple Notes password, you can reset the notes password, but Apple can’t assist you with recovering it. Again, do not panic, read further to know how to unlock notes on iPhone without password.
Further Reading: How to Recover Data from Locked/Disabled iPhone without Backup >
how to unlock old notes on iPhone forgot password? If you are searching for ways to unlock notes on iPhone, read further to know about the two ways on how to unlock a note on iPhone.
Keep in mind that resetting a password will not eliminate or change the password for the notes that have been locked before using a previously set password. If you wish to remove a password from a note, enter the password first and open the note. After which, move ahead with the reset process. Follow the steps mentioned below to reset the password for the Notes application on any iPhone and iPad.
Step 1. Open the “Settings” application from the Home Screen of iOS, go to “Notes.”
Open Settings and Choose Notes on iPhone
Step 2. Tap on the Default Account option and access the details.
Step 3. You will see a “Password” Option. After tapping on it, you will notice the “Change Password” option. You can change your password if you know the previously set password. Also, the other choice is “Reset Password.” Tap Reset Password to reconfigure the password for all your notes.
Reset Password
Step 4. Enter your Apple ID password and tap on “OK” to confirm the new password. When the password is reset effectively, any recently protected notes inside the Notes application will use the recently set password.
Recently set password
If you have connected Touch or Face Id to Apple Notes or recently accessed one of the secured notes using the features, you can recover data from your notes without much of a stretch. It permits you to open old notes without worrying about losing your data effortlessly. The accompanying steps can assist you on how to remove notes lock without password.
Step 1: Open the Notes application on your iPhone and open the secured Note that you need to recover.
Step 2: Either tap on the “Lock” icon or the “View Note” area. When a dialogue window prompts for a password, lay your unique finger impression on the Touch ID button to open it. However, if your iPhone has the Face Id feature, use it to unlock the note.
View Note
Step 3: Once opened, copy the note’s content and tap on “Back” to exit from the protected note on your iPhone > Go to the “Create Note” option to paste the copied content.
Create a Note
Step 5: Now, paste the copied content in a new note. Repeat the above steps for every locked note you would like to recover.
First, let us understand how you can lock notes on your iPhone or iPad. You can lock any note in the Notes app using a straightforward method. Your phone will ask you to set the password once you bar from public access for the first time. As soon as you have set the password, every one of the notes will be accessible using a similar password. What’s more, if your Mac supports Touch ID, you can open them using it. Therefore, if you don’t know how to lock your iPhone notes, let us look at the steps mentioned below.
Step 1: Start the “Notes” application > Tap on one of the notes to open it.
Open One Note in Note App
Step 2: Tap the button at the upper right corner of the screen.
Click on the Upper Right Corner Button
Step 3: In the pop-up, tap “Lock,” signified by a padlock icon. This icon will be beside the “Scan” and “Pin” options.
Tap on Lock
Step 4: Enter a password (and repeat it on the Verify line). If you need to, you can likewise type a password hint as an update. If you need to open notes using Touch or Face Id, swipe the button to turn it on > Tap on “Done.”
Enter a Password
Step 5: The lock has now been added to this note. However, it’s not password-protected just yet. To hide this note, tap the new lock symbol at the highest point of the screen. Your phone will hide the content with the message “The note is locked.”
AnyUnlock – iPhone Unlocker is one of the professional unlock apps you can use to get rid of the passcode from your iOS-based device. It allows you to remove the passcode without entering it in just a few easy clicks. All you need to do is select your phone, choose the option that lets you remove the passcode, and it will take care of everything for you [iPhone 13 supported].
What’s more, AnyUnlock can also help you to bypass the iCloud activation lock, remove MDM lock, SIM lock, etc easily.
The following are the steps on how to use this app to remove the passcode from your iPhone.
Step 1. Free Download and install AnyUnlock on your computer. It works well both on Windows and Mac computers.
Step 2. Open AnyUnlock when it is fully installed on your computer > On the main screen, click on Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 3. Once your iOS device has been recognized successfully, please click Start Now button to download the matched firmware.
Click Start Now Button
Step 4. When the firmware is downloaded, click on the Unlock Now button to start unlocking your iPhone.
Tap on Unlock Now
Step 5. The following message will appear when the passcode is removed from your iPhone.
You can now start setting up your iPhone as a new device.
Regardless of whether your note has a picture, scanned documents, or a list of essential data, it’s not difficult to protect it with password protection.
Step 1: Start the Notes application.
Step 2: Tap the note you need to see.
Step 3: If you have a Touch or Face Id enabled, open the note that way.
Step 4: Once you have viewed the hidden note, you need to lock it again to keep it protected.
The Notes application entails a security feature that permits clients to protect the content of their data. Secured notes are end-to-end encrypted utilizing a user-provided passphrase. You will require the password to view the notes on iOS, iPadOS, macOS devices, and the iCloud website.
If you can’t unlock Notes with Face ID, check if it’s enabled under **Settings > Notes > Password**, ensure Face ID is working properly, and update your iOS if needed. Some notes may require a password instead of Face ID. Restarting your device may also help.
This article has given you the methods on how to open locked notes on iPhone without password. Use these techniques to save and store your thoughts and data in the notes application securely.
