How to unlock iPhone without swiping up? Luckily, you’ll get 6 methods to unlock iPhone without swiping up in this article.
AnyUnlock – iPhone password unlocker can unlock iPhone without swiping up and bypass face ID. Download it now to unlock your iPhone.
Apple did a great job integrating advanced security features such as Face ID, Touch ID, 4-6 numeric passcode, and more, into its system with the aim of protecting your device from unauthorized users. Although this seems great, users must always swipe up to unlock or bypass locked screens which is often stressful.
If you do not want to pass through this process, we have a simpler, and quicker technique you could implement to unlock your iPhone. In this article, we will discuss the various ways to bypass your Lock Screen without swiping up. Read on!
Swiping up your screen on an iOS device is a mandatory requirement for you to unlock it. The primary reason for that is to ensure that you truly want to unlock the device, so it doesn’t look like an unintentional attempt. Other reasons for swiping up to unlock an iPhone include:
Now you understand why you have to swipe up your iPhone before bypassing the Lock Screen. Let’s proceed to how to turn off the swipe to unlock feature?
Disable the swipe to unlock feature on your iPhone using any of the technique down here:
With the back tap feature, you can easily bypass the swipe up stage to unlock your iPhone. It works perfectly on iOS devices with the Face ID security feature. The feature has a simple mode of operation as it involves double/triple tapping the back of your iPhone, and positioning your Face to unlock it.
To enable back tap on your iPhone, follow the illustrations below:
Enable Backup Tap
Once done with the steps above, double tap or grime tap the back of your iPhone, and position your face appropriately to unlock without swiping up.
AnyUnlock is one of the groundbreaking software developed to bypass lock screens on iOS devices. This software features incredible tools that lets you unlock your iDevice at a remarkably high speed. It uses smart AI technology to analyze, and unlock your iPhone without compromising it.
The software is responsible for unlocking more than 5+ security lock features on iPhones. With AnyUnlock, you can bypass 4-6 digits passcodes, Face ID, Touch ID, ScreenTime password, and more with maximum convenience. It’s indeed one of the best screen lock solutions.
Except for Apple ID, it can help people remove or unlock iPhone/iPad activation lock, MDM lock, etc.
Here are some steps that you can go through to use AnyUnlock app on your computer.
Step 1. Free download and Install the AnyUnlock on your computer. Run the app on your computer, and choose the Unlock Apple ID option.
Click Unlock Apple ID from the Homepage
Step 2. Use a USB lightning cable to connect your iPhone to the computer, and then click on the Unlock Now button.
Click Unlock Now Button
Step 3. If your device is running iOS 11.4 and above. Check your device status and take the on-screen steps to turn on screen passcode and the two-factor authentication. Then tap the Continue button.
Check and Confirm Your Device Status
Step 4. Follow the on-screen steps to download. When the firmware is ready, click on the Unlock Now button to initiate the removal process.
Firmware Download Complete
Step 5. Wait for the unlocking process and set up to the device to complete the unlocking process.
Set up Your Device to Complete the Apple ID Unlocking Process
For folks with iPhone 8/8S and lower generations that support Touch ID, you can quickly unlock your device without swiping up your screen. All you need is to place one of your fingers on the Home button, and the iDevice will quickly read, and match your fingerprint with what it has on its system. If the biometric data matches yours, the phone will automatically unlock without swiping up your screen.
With AutoUnlockX, you can also bypass the swipe up gesture to unlock your iPhone. This tweak is entirely free to implement, plus works with all iOS models. You can follow the procedure below to activate the AutoUnlockX feature to unlock your iPhone without swipe:
Turn on AutoUnlockX
After completing the above, lock your device and try unlocking it without swiping up. Your device should unlock as required.
Limitations of Using AutoUnlockX
Another simple yet efficient technique to unlock your iPhone without swiping up is to activate the voice control feature. The feature uses speech recognition functionality to bypass screen lock so you have access to your device.
Here is the simple way to do that:
How to Turn on Voice Control
Now try unlocking your device without swiping up your screen. Your iPhone will immediately open without the swipe up gesture.
The switch control is another Apple feature you can use to tweak your device to unlock your screen without swiping up. What you are required to do here is to activate the feature and configure a new switch to unlock your iDevice.
Here are the instructions you have to follow to get this done on your iPhone:
Set Switch Control
Ultimately, unlocking your iPhone without swiping up your screen shouldn’t be a problem anymore. Our guide contains 6 official solutions plus an ultimate technique to bypass your Lock Screen without swiping up. All solutions are free to implement but the AnyUnlock method is the shortest. With just a few taps, you can unlock your iDevice for operation again.
