If your device is locked to a specific network or carrier, how to unlock iPhone without carrier? Our detailed and straightforward guide will help you unlock iPhone with/without SIM card from any network for free. All the exact steps are given below. Read them carefully.
Free download AnyUnlock to unlock iPhone without carrier or SIM card and use it for AT&T, Sprint, T-Mobile, Verizon, or other carriers on your own. Only 5 minutes are needed. Available for Windows & Mac.
Suppose you are looking to change or bypass your current SIM card and deal with different network SIM cards, but your device is locked for the current carrier. This means you will not use your iPhone with other carriers. So, how to unlock iPhone without SIM card? In this article, we are going to discuss in detail how to unlock iPhone without carrier. Just read on to find ways to unlock your iPhone now.
Various situations appear in front of us. Then we have to deal with different networks with different SIMs. If you are not using your current carrier, then your device may be locked. Now, I don’t need to worry about that. There are various solutions to unlock your device (iPhone). For example, you can choose to unlock your iPhone with a SIM Card, and another method is to unlock iPhone without SIM card or carrier.
Unlock iPhone with/without SIM Card
It is used most of the time to unlock iPhone without carrier because the user may change the location or not get proper network coverage from the current carrier. With the help of these 3 methods, you can easily unlock your iPhone. All detailed steps are going to help you out with this issue.
You may not want to spend too much time contacting the carrier to unlock your iPhone, since it is a time-consuming task. You need to find a professional and safe app like AnyUnlock – iPhone Password Unlocker to help you unlock your iPhone. It supports unlocking all types of SIM cards, such as AT&T, T-Mobile, Verizon, etc. Save yourself the hassle of contacting the carrier, and you can unlock your iPhone yourself at home. And don’t worry about data loss, the unlocking process is 100% safe.
Now, download the latest version of AnyUnlock and here is how to unlock iPhone without carrier via this tool:
Step 1. Launch AnyUnlock on your computer and click the Remove SIM Lock function on the homepage.
Choose Remove SIM Lock
Step 2. Connect your iPhone to the computer and confirm your iPhone’s information. And tap on the Remove Now button to start the removal procedure.
Click Remove Now
If your iDevice isn’t jailbroken yet, please take the on-screen steps to jailbreak your iPhone before unlocking the SIM card.
More reading recommendations: Proven Ways to Unlock SIM Card without PUK Code [2024]
Step 3. Connect your iPhone to the computer with a USB cable > Follow the instructions to “Forget This Network” on your iPhone.
Forgot This Network on iPhone
Step 4. AnyUnlock will remove the SIM lock automatically afterwards and when the process is completed, you can see the successful page below.
SIM Lock Removed Successfully
Though AnyUnlock will require you to jailbreak your iPhone to complete the unlocking process, no data will be lost, don’t worry about that.
What’s more, AnyUnlock also allows you to bypass iCloud activation lock on your iPhone and iPad without phone number in no more than 3 steps.
Various phases occur that we need to change our original carriers. It depends upon the changing the location, or current carriers cannot provide a good network connection on the exact location. Then the user needs to change or switch the carriers but, the major problem is with the iPhone.
It is much harder to switch carriers with the iPhone, but there is a way how to unlock an iPhone without a SIM card. For that solution, you need to follow all the very important steps to unlock your iPhone while not accepting SIM cards. Read all the steps and follow them carefully that are given below. Here is how to unlock iPhone without carrier.
Use iTunes to Backup iPhone to This Computer
Erase All Contents and Settings in Settings
Restore iPhone/iPad with iTunes
It will take time (A few minutes) to restore your previous backup from iTunes. The complete process depends upon the size of the file. The size of the file is huge, then it takes more time and vice-versa. After this is successfully done, then your device (iPhone) is ready to use.
If you still have a SIM card, it’s a lot easier. In this method, we need to ask for help from the current carrier. This is the very most straightforward method, and almost all recommend this method. This will work out most of the time to unlock the iPhone. But there are a few obstacles and I need to face some difficulties. Such As there will be a delay in the process. The complete process depends upon the reason that you placed it to the carrier provider.
Unlock iPhone with SIM Card
Suppose the reason is real and genuine that this will work so efficiently. But there may be some conditions you need to know in advance.
After unlocking your iPhone, we will teach you all the ways to check that your iPhone is locked or unlocked. The simplest way is to call the current carrier. If you are not able to check your iPhone lock status, then you need to follow all the methods that are given below. You can choose any one method to check the status of unlocking your device (iPhone). All techniques are very simple. Let’s discuss all methods one by one.
This is the best way to check if your iPhone is unlocked or not. You just need to call your current carrier after talking to the actual customer service rep. After that, you can talk to them regarding the iPhone’s status. Allotting the correct information that your carrier asks is related to the verification as a real user of the iPhone. For your help, we are placing all famous carrier customer support contact numbers to make your way easier.
For the verification, you need to provide these kinds of details to your current carrier provider below:
Check the IMEI Number
Tap on the Cellular Option
Tap on the Cellular Data Network Option
Replace the Current Carrier SIM Card
Dial Any Number
Of course we can. AnyUnlock can help you unlock your device quickly and easily. Of course, not only can you seek help from third-party software, you can also contact your mobile phone operator and ask them to help you unlock your device.
The answer is no, you cannot unlock your carrier by jailbreaking it. A carrier lock is a special software code used by the phone carrier to prevent the device from being used by another carrier. So when you want to switch to a different carrier, you must first unlock your iPhone using the code provided by your current mobile phone carrier.
After reading this article about how to unlock iPhone without carrier, all issue has been resolved. We mentioned all the methods to unlock the iPhone, as we highly recommend you give AnyUnlock a try, as it is the quickest and easiest to unlock iPhone without SIM card or iPhone. No matter which carrier you are using to unlock your device. The detailed process to unlock the device with all carriers is described above, read it carefully and resolve your issue legally and professionally.
