How to Unlock iPhone with Voice
Do you know that you can actually unlock an iPhone with your voice? If not, this post is about to walk you through how that could be achieved. Read on to discover how to unlock your iPhone without a passcode via voice.
Author Avatar Joy Taylor Last Updated: May. 19, 2023
With the recent advancement in technology, unlocking an iPhone device without entering the corresponding passcode is one of the easiest tasks to execute, especially when you own an iPhone running on iOS 14 or later. However, many people find it challenging, mainly because they do not know the technique to follow in order to accomplish it.
If this is the same for you, then worry less, as you’ve made it to the right platform where all iOS hacks and updates are provided. This article is structured to focus on how to unlock an iPhone with voice.
Can I Use Voice to Unlock iPhone?
Yes, you can! With the integration of the voice control feature on iOS 14 and later versions, you can now unlock an iPhone without entering the passcode associated with it.
How to Unlock iPhone using Voice Control
The voice control feature is a recent advancement tucked into the iOS 14 and later version to help you connect and interact with your iPhone from some distance. You may decide to touch/tap, or not have any physical contact with the iPhone in order to use the feature, and be sure your device will follow suit.
Apply the instructions below to unlock your iPhone with the voice control feature by following the directions given below:
Step 1: Find the gear icon on your iPhone home screen, click on it and you will be directed to the Settings menu page.
Step 2: On the Accessibility screen, select Voice Control underneath the PHYSICAL AND MOTOR section. If you are just setting up voice control for the very first time on your device, you will be directed to a screen with Set up voice control as the initial icon. Click on the icon, and follow the instructions that come up to activate voice control.
How to Turn on Voice Control
Step 3: Now lock your iPhone by pressing the Side button. After that, proceed, and tap on your iPhone screen to wake the lock screen. Once done, kindly speak to your iPhone (say “Go Home”) to unlock with Face ID or Touch ID.
If that doesn’t work, just enter the corresponding passcode to unlock, and gain access to the device
How to Unlock iPhone without Siri or Voice
Asides from the voice control feature, you can also unlock your iPhone with an iOS unlocking tool, just as we’ve mentioned earlier. However, this time, you don’t have to interact with the device via speech. A simple yet effective software like AnyUnlock will help you remove the screen lock without stress.
The AnyUnlock software holds amazing features that removes screen lock, and other lock issues on iOS devices. It lets you remove Screen Time Passcode, iCloud Activation Lock, MDM, SIM lock, and more right from the comfort of your home.
  • One-stop unlocker – Digital password, Touch ID, face ID, etc., all can be easily unlocked with AnyUnlock.
  • Just a few steps – Still troubled by complicated unlocking steps? With AnyUnlock, you can unlock your iPhone with just a few button clicks.
  • Supports all iPhone models – Even if you are using iPhone 14, iOS 16, AnyUnlock can unlock it for you.
  • Not just an unlocking tool – AnyUnlock also has multiple functions such as removing restriction locks, unlocking iTunes encrypted backups, bypassing MDM locks, etc.
Now download and install AnyUnlock on your computer. Then follow the below-given steps to know how to unlock any iPhone using AnyUnlock without voice.
Step 1:  Run AnyUnlock on your computer. Use a USB cable to connect your iPhone to the computer. Click on Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2: Click on Start Now button. Then tap on Download to start downloading the appropriate iOS firmware according to the device.
Click Start Button
Click Start Button
Step 3: After downloading the firmware, click on Unlock Now button to start unlocking your iPhone. Wait until the process completes.
Tap on Unlock Now
Tap on Unlock Now
Step 4: Once, the process will complete, click on Done to go back to the main interface. Your iPhone will be unlocked.
FAQs
Learn more about the the topic by reading through the popular queries and answers searched by end-users:
How do I use Siri to unlock my iPhone with unresponsive screen?
Unlocking an iPhone with an unresponsive screen can be quite technical. Either you take advantage of an iOS unlock tool, which is the safest and quickest approach. Or alternatively, you reset the device remotely using the Find My iPhone feature via iCloud.com. Another cost-free technique you can employ is restoration via iTune, which can be complex if you haven’t connected the device to your computer in the past.
Can you unlock an iPhone without passcode or Face ID?
Yes, you can unlock an iPhone without providing the corresponding unlock details, whether Face ID, passcode, or Touch ID. There are several approaches to this, which include the restoration of the device via iTunes, or iCloud. Either of them would cause you to lose data. But if you don’t want such, then you can employ the services of a renowned iOS Unlocker like AnyUnlock.
Final Words
You don’t necessarily have to get in contact with your iPhone before you can unlock it. Our tutorial guide has shown the various ways to bypass locked screens on an iPhone without entering the passcode. Both techniques are simple and cost free. However, the AnyUnlock method is the best, as it quick and error free.
