Top 9 Tools to Unlock iPhone Online [2024 Updated]
It’s common to get locked out of your iPhone if you forget your screen lock passcode or Apple ID credentials. What’s even more common is to have a carrier lock on your iPhone. Regardless of what type of lock your iPhone has, we have compiled a list of 9 tools to unlock iPhone online.
How can I unlock iPhone online? I want to change the carrier of my phone but have no way to do so. What is the most convenient aspect of unlocking an iPhone for free and using a different carrier?
While having an iPhone is a major flex, it gets pretty frustrating when its security features come in the way of you accessing your device. For instance, if you forget your lock screen passcode or Apple ID password, you have to go through several tricky steps to access your iPhone, losing your data in the process.
However, instead of putting yourself through the hassle of trying different tricks to unlock iPhone online, why not opt for third-party tools for this purpose?
In this article, we have put together 9 of the best tools to unlock iPhone online. So, let’s see what they are and how they work!
Here is a bonus tip about SIM unlocking: How to Generate SIM Network Unlock PIN Free Code to Unlock SIM Card? >
Can I Unlock An iPhone Online?
Yes, you most certainly can!
There are several tools designed specifically to unlock iPhones. The most common types of locks people usually struggle with are screen locks, carrier locks, and iCloud activation locks.
However, with so many tools and software available to unlock iPhone online, these minor issues are a thing of the past!
Therefore, learn about the 9 best tools to help you unlock your iPhone safely without losing your essential data.
Top 1. The Ultimate iPhone Unlock Tool – AnyUnlock [Easy&Safe]
AnyUnlock- iPhone Password Unlocker is an iPhone password unlocker that is an all-in-one tool to help unlock screen passcode, bypass iCloud activation lock, unlock SIM lock, and remove Apple ID. The best part about this software is that it gets the job done in a safe and secure way without the risk of a security breach or data leak.
AnyUnlock – iPhone Password Unlocker’s Key Features:
- It is easy to understand, and you use it without prior experience with the app.
- It requires only 3 easy steps to remove any kind of lock from your iPhone within minutes.
- AnyUnlock employs cutting-edge technology with a high success rate. You can be 100% sure that it will unlock your iPhone.
- No need of IMEI number. Your information will not be exposed or leaked.
You can now free get AnyUnlock on your computer to have a try!
Choose Remove SIM Lock
Pros
- Requires 3 easy steps to unlock your iPhone.
- Compatible with all iPhones and iPads.
- No tech knowledge is required to use the tool.
- Responsive technical support.
- Free trial version available.
Cons
- You need to get the premium version to avail exclusive features.
Here is a complete guide on unlocking SIM locks: How to Unlock SIM Card on iPhone>
Top 2. Official SIM Unlock
If you’re looking for a tool to unlock iPhone online without downloading any software, Official SIM Unlock is an excellent choice. It is a web-based tool that unlocks your iPhone from SIM lock with the help of your IMEI number. You simply have to enter the IMEI number, and it will unlock your device from carrier lock in any country.
Key Features
- Official SIM Unlock is so easy to use; it only requires one click to unlock your iPhone! Just enter the IMEI number, confirm payment, and voila: iPhone unlocked!
- With Official SIM Unlock, your iPhone remains unlocked even after you update the firmware.
- If you don’t know which carrier your iPhone is locked to.
- Unlike other iPhone unlocking services, Official SIM Unlock offers instant carrier unlock within 24 hours.
Official SIM Unlock
Pros
- Your iPhone stays unlocked even after a software update.
- It offers Google FRP removal also, apart from SIM unlock and carrier check services.
- You can check your iPhone’s eligibility status with this tool before unlocking it.
- It is a safe and reliable service.
Cons
- It takes around 2 weeks to carrier unlock your iPhone using the standard package.
- It is expensive.
Top 3. iPhone IMEI
Another tool to unlock iPhone online is iPhone IMEI. It is a web-based tool that whitelists your iPhone in Apple’s servers, checks IMEI, and unlocks the carrier lock on your iPhone. The best thing about this tool is that you don’t have to jailbreak your device to unlock it, as all the procedures followed are totally legal and approved by Apple.
Key Features
- Unlike other iPhone unlocking services, iPhone IMEI offers multiple services, including IMEI checking, removing phones from the blacklist, and unlocking carrier locks.
- iPhone IMEI follows strict protocols when unlocking iPhones by staying in contact with Apple during the process.
- iPhone IMEI does not jailbreak your iPhone to carrier unlock it, which makes it a safe and secure choice.
iPhone IMEI
Pros
- It is a safe, secure, and reliable iPhone unlock service.
- It unlocks iPhone online without jailbreaking it.
- It offers free IMEI checking.
- It has a high success rate.
Cons
- It takes longer than usual to unlock iPhone.
- It is expensive and has a slow refund service.
Top 4. Doctor SIM
One of the most famous and reliable iPhone unlocking tools is Doctor SIM. It is an online tool that offers multiple services, including unlocking your iPhone from SIM lock, recharging your prepaid phone, checking the status of your iPhone, and checking the iCloud activation lock status.
Key Features
- Doctor SIM is compatible with most iPhone models and iOS versions. Therefore, whether you have an old iPhone or a new one, Doctor SIM will unlock it.
- The best thing about Doctor SIM is that it is that users from all around the world can use it to unlock their iPhones and check their status.
- Another feature that makes Doctor SIM better than the rest is its 99% success rate.
- Most iPhone unlocking tools have sky-high prices. Doctor SIM offers its services at the lowest possible rates.
Doctor SIM
Pros
- It supports almost all iOS and Android devices.
- It is easy to use and understand.
- It has been around for over a decade, so it’s safe and reliable.
- It has a strong global footprint with services available worldwide.
Cons
- It takes almost 7 days to unlock iPhone online.
Top 5. Cell Unlocker
When talking about iPhone unlocking tools, we cannot proceed without mentioning Cell Unlocker. It is an online tool that removes carrier lock and iCloud activation lock from your iPhones within a week. The best part is that you don’t have to download any heavy software on your PC; just visit the website, enter your IMEI number, network, and country, and unlock your iPhone in a smooth and hassle-free manner.
Key Features
- Cell Unlocker offers a 100% money-back guarantee if the carrier lock or iCloud activation lock is not removed within the specified time period.
- The iPhones unlocked using Cell Unlocker work globally and can be used with a SIM card of any network worldwide.
- Cell Unlocker is secured by Norton Antivirus, and with more than 600k satisfied customers, it is one of the safest and most reliable online services.
Cell Unlocker
Pros
It is compatible with networks in more than 180 countries.
It supports multiple payment methods, making it easy for users to unlock their iPhones from anywhere.
It has a 99% success rate with 4.9-star reviews.
It offers unlock codes with 96% accuracy.
Cons
- It takes 7 days or more to unlock your iPhone.
- It cannot unlock iPhones bought after January 2013 in the USA.
Top 6. Unlock Boot
If you’re looking to unlock iPhone online, you must give Unlock Boot a try. It’s an online unlocking service that not only removes the SIM lock but also checks IMEI and fixes underlying iPhone issues, like screen orientation, etc. It’s an easy and straightforward tool that only needs your IMEI number to carrier unlock your iPhone from any network worldwide.
Key Features
- Unlock Boot has a high success rate in unlocking iPhones from carrier locks in 3 easy steps.
- Unlock Boot can unlock iPhones and other smartphone models in over 15 countries.
- Unlock Boot’s customer service is famous for its prompt responses. They go out of their way to help you with your issues and ensure your satisfaction.
- Another feature that makes Unlock Boot stand out is its affordable price to carrier unlock iPhones.
Unlock Boot
Pros
- It is compatible with all smartphone brands.
- It has prompt customer service available 24/7 via email, chat, and phone.
- It offers fast, easy, and legal services.
- An unlocked iPhone will work with any network worldwide.
Cons
- The website is not user-friendly.
- It takes more than a week to unlock your iPhone.
Top 7. Apple iPhone Unlock
Apple iPhone Unlock is another innovative web-based tool designed specifically for iPhones. It helps remove SIM lock from iPhones 4 to 14 and also offers network checking and iCloud activation lock disabling services in just a couple of steps. The best part about Apple iPhone Unlock is that it provides instant carrier unlocking services within 24 hours.
Key Features
- While most SIM unlockers take up to a week to work, Apple iPhone Unlock offers instant unlocking for several carriers within 24 hours.
- Apple iPhone Unlock has a team of skilled and certified technicians to deal with various Apple products.
- Apple iPhone Unlock offers robust security while unlocking your iPhone, ensuring complete privacy and no data leaks.
- Apple iPhone Unlock is a web-based tool; therefore, you don’t need to download any heavy software to unlock your device.
Apple iPhone Unlock
Pros
- It offers a live tracking system to track your order’s progress.
- It works with mobile networks around the globe.
- It unlocks your device within 24 hours.
- It has quick, easy, and secure service.
Cons
- It does not disclose the complete fee when placing an order.
Top 8. Direct Unlocks
When looking for an iPhone unlocking service, we usually opt for tools that unlock your iPhone as fast as possible. And Direct Unlocks is just the service for that; it unlocks your device in less than 24 hours! Besides SIM unlock, it also offers iCloud activation lock removal and FRP bypass.
Key Features
- Direct Unlocks is compatible with all iOS, iPhone, and Android versions.
- Most iPhone unlocking tools take up to 2 weeks to unlock iPhone online. Direct Unlock gets the job done in under 24 hours.
- Direct Unlock permanently unlocks your iPhone without affecting the warranty.
- Direct Unlocks offers its users a safe and secure service, ensuring complete privacy and zero risk of a security breach or data leaks.
Direct Unlocks
Pros
- It is compatible with all iOS versions.
- It offers iCloud activation lock removal for iPhones and FRP bypass for Samsung devices.
- It requires 3 simple steps to unlock iPhone online.
- It works in more than 20 countries.
Cons
It takes several days to refund the money.
Top 9. Mobile Unlocked
The last tool on our list of iPhone unlocking tools is Mobile Unlocked. It is a remote service that uses your IMEI number to remove the SIM lock from your iPhone. Plus, it also offers to check IMEI for free and has a live online tracking system to keep track of your orders and their progress.
Key Features
- Offers remote unlocking with just your IMEI number.
- Permanently unlocks your iPhone, even after a software update.
- Provides quick delivery within 24 hours.
- Has an online tracking system for users to check their order’s progress.
- Safe, secure, and trusty iPhone unlocking tool.
Mobile Unlocked
Pros
- It permanently unlocks your device without affecting its warranty.
- It unlocks your iPhone within 24 hours of placing the order.
- You can track your order with its live tracking service.
- It is cost-effective as compared to other iPhone unlocking services.
Cons
- Its customer service is unresponsive.
Frequently Asked Questions on Unlock iPhone Online
1. How should I choose a reliable unlock service?
When choosing an online iPhone unlocking service, it is best to look at the user reviews and ratings. The service is reliable if the reviews are reasonable; otherwise, you should not provide your IMEI number to unauthentic resources.
2. Is online unlocking iPhone safe?
Online unlocking iPhone is safe only if you choose the proper channels. For instance, iMobie AnyUnlock is a safe and reliable tool with high ratings and positive reviews.
Choosing the right service to unlock iPhone online is essential if you want to remove the carrier lock, screen lock passcode, or iCloud activation lock. We have mentioned 9 of the best tools to unlock your iPhone safely and securely. But if you want to know directly the safest and most convenient SIM unlock service, after our test, there is no doubt that it is AnyUnlock! So why not try AnyUnlock first?
Joy Taylor
