How to Unlock Phone Free with IMEI Number?
This phone unlock article can help you unlock phone free with imei number. You can see 4 different methods and choose the most effective one. For the most useful method, you can try AnyUnlock – iPhone Unlocker.
Author Avatar Joy Taylor Last Updated: Aug. 16, 2024
Read in: Read This Article in
Deutsch
AT&T placed my iPhone on the blacklist, and I’ve been unable to use it since. What can I try to get it to work again?
Are you having problems with your iPhone’s carrier’s network? If you answered yes, you understand the agony of carrier restriction. Is there a simple way, such as a free iPhone unlock service, to remove the network lock on your iPhone and allow you to use it on the network indefinitely? In fact, yeah! In this guide, we will walk through how to unlock iPhone free with IMEI number in 2024.
Before we get into how to unlock iPhone free with IMEI number, there are 2 things you need to perform. One is to locate your phone’s IMEI number and the other is to check the status of that number. Here are all the methods for getting the IMEI number on your iPhone or iPad, whether it’s locked, switched off, or not at all. Let’s get started!
Further Reading: How to Unlock iPhone to any Network by yourself >
Where to Find Your IMEI Number
Get IMEI Number
Get IMEI Number
To unlock iPhone free with imei number, first you need to find your IMEI number. The IMEI number is like a one-of-a-kind fingerprint that no one else has.
International Mobile Equipment Identity is abbreviated as IMEI. For security purchasing, it is an industry-standard shared by mobile carriers and manufacturers. Your IMEI is vital because you’ll need it for things like registration, support paperwork, and determining the history of a device for theft.
Method 1. Give It a Call
Calling *#06# is a quick way to find the IMEI number of your iPhone or cellular iPad. After you make a successful call, a screen containing your device details will appear.
Find IMEI Number via a Call
Method 2. Check Your Settings
Find IMEI Number via Settings
You can find your IMEI number on any iPhone by using the Settings app. Select Settings > General > About from the drop-down menu, and you’ll be able to discover the IMEI number with a little scrolling.
Method 3. Pop the SIM Tray Out
If you need your IMEI number, but your iPhone isn’t turning on, an iPhone 6s or later should have it printed in the SIM tray. All you need to do is take the SIM card out of the slot. The IMEI number can be located on the underside of the tray.
Method 4. Go to the Apple ID Website
Apple ID Website
Apple ID Website
If you don’t have your iPhone or iPad with you but require the IMEI number, there is still hope. You can receive device information via Apple’s website as long as the device is linked to your iCloud account.
To do so, navigate to appleid.apple.com in any browser. Then sign in with your Apple ID and look through the list of devices. Once you’ve located the device for which you require information, click the device name to get the IMEI number.
Check if Your iPhone is Blacklisted
After obtaining your phone’s IMEI, the next following step is to verify the IMEI’s blacklist status. This allows you to check that your phone is indeed carrier locked, but more significantly, it allows you to find out whether or not your phone has been blacklisted. If it turns out that your phone is blacklisted, you will be unable to unlock it until it is removed from the blacklist.
Check If Your iPhone Is Blacklisted
The best way to obtain these details is to utilize a third-party IMEI Checker. You can use the third-party tool to find information such as:
  • If your phone has been blacklisted (because it was reported as stolen or lost);
  • If your iPhone is locked to a carrier which is locked to the country from where your device  is registered (useful if you want to avoid international charges);
  • If your phone is still under warranty;
  • The status of your iPhone’s replacement and the expected purchase date;
All of this information is beneficial. In this case, the essential thing is to determine whether your phone is on a blacklist and which third-party IMEI Checker can do for you.
After obtaining the IMEI number of your iPhone, the next step is to unlock your iPhone for free using the IMEI number. You can choose to remove it yourself or contact your carrier to remove it. While each carrier has its own set of requirements for unlocking consumer phones from their network, they usually do not charge a fee.
Remove the SIM Lock by Yourself
If you can not find the IMEI number or you don’t want to contact the carrier to unlock the SIM lock, you must try AnyUnlock – iPhone Unlocker, which got a new function to help you remove SIM restrictions on your iPhone even without the IMEI number. It is safe enough to avoid taking risk of information leakage by providing IMEI to other unverified stores.
AnyUnlock is a powerful iPhone unlocking tool:
Steps to Unlock SIM Card Using AnyUnlock
Step 1. Free download AnyUnlock and launch it on your computer > Choose to Remove SIM Lock function > Tap on Start Now button.
Choose Remove SIM Lock
Step 2. Connect your iPhone to the computer > Confirm your iPhone information and jailbreaking status > Click the Remove Now button to continue if your iPhone has been jailbroken before. If not, take the on-screen steps to jailbreak your device by yourself.
Click Remove Now
Click Remove Now
Step 3. Follow the instructions to forget the Network on your iPhone > Tap the OK button to start removing.
Forgot This Network on iPhone
Step 4. Then AnyUnlock will start to remove the SIM lock.
Start Removing
Start Removing
Step 5. When the SIM Lock is removed successfully, you will see the interface below.
SIM Lock Removed Successfully
Unlock Phone Free with IMEI Number by Contacting the Carrier
As each carrier has its own set of regulations, you should also check to see if you’re qualified for an unlock.
What You’ll Need to Prepare
First, you need to prepare by making a list of some essential facts. The following are the most important points to remember:
  • The name under which your phone is registered to.
  • Your account number and phone number.
  • The phone’s IMEI number.
  • Your account’s security answers (if you’ve configured them for the carrier account).
  • (Optional) If you are in the military, provide evidence of service to expedite the procedure.
Unlock iPhone Free with IMEI Number in Simple Steps
After you’ve collected all of this information, you’ll be able to use carrier IMEI unlock free service for your iPhone. Below we have highlighted the steps you need to follow:
Step 1. Begin by contacting the carrier via live chat or by calling their support line. Explain to the customer representative that you want to unlock your phone from the carrier. Below are the numbers of top carrier providers:
Unlock iPhone with SIM Number
  • At&t IMEI unlock: 800-331-0500
  • Sprint IMEI unlock: 888-211-4727
  • T-Mobile IMEI unlock: 1-800-866-2453
  • Verizon  IMEI unlock: 800-922-0204
Step 2. The support person will ask for the information provided above to validate that you are the true owner of the unlocking phone.
Step 3. They will begin processing your unlock request after receiving the information you supplied and confirming that you own the phone.
Step 4. The carrier will send you an unlock code within the following 30 days. They will tell you how to enter this code and unlock your phone.
Step 5. After you’ve unlocked the phone, you can use a SIM card from a different provider.
You May Like: How to Unlock iPhone to Any Carrier >
Limitations for Unlocking iPhone Free with IMEI Number
Even though it may appear to be the most straightforward approach, requesting an unlock via your carrier has some limitations:
  • If you are not the phone’s original owner, the carrier will not accept your request.
  • The carrier may take up to 30 days to complete the unlock.
  • Each carrier has different criteria, but you must meet all of them to unlock the phone.
  • Your phone can only be unlocked by the original carrier.
That’s all! There are numerous options to unlock phone free with IMEI number. Among these solutions, AnyUnlock is the most excellent option because it will address your problem quickly. If you have any feedback or concerns, please comment below!
