Are you tired of searching for how to unlock iPhone 12 in a hassle-free and quick way? If yes, then your search ends here! Discover the three effective methods here on how to unlock iPhone 12/12 Pro/12 Pro Max/12 Mini in just a few minutes. Make sure to follow the steps appropriately for better results.
How to Unlock iPhone 12
When it comes to unlocking an iPhone 12, you can simply use the screen passcode or Face ID to unlock it. But have you ever thought about how to unlock iPhone 12 without passcode or Face ID? Well, there has been the latest trend of late to find effective solutions on how to unlock iPhone 14/ 13/12 Pro/Pro Max without Face ID or passcode.
In this guide, we have compiled a list of all possible methods that you can get your hands on to get into your locked iPhone 12 without using your passcode or Face ID. Ranging from Apple’s default ways to top-notch iOS unlock tools in 2025, we have covered the highly reliable ways to help you unlock iPhone 12 without passcode or Face ID. These solutions also support the latest iPhone 14 and iPhone 12 models.
How to unlock iPhone 12 without a passcode or Face ID is one of the most common searches of iPhone users on the internet. If you are in the same category and looking for effective workarounds on how to unlock iPhone 14/13/12 Pro Max, then we have got your back. Refer to the top 5 methods below to help you unlock your iPhone 14/13/12 without Face ID or passcode!
How to unlock iPhone 12 is no longer an issue with the iPhone screen unlock tool that works excellently to unlock your iPhone in just a couple of minutes. Yes, you read that correctly!
If you are hunting for a reliable way to unlock your iPhone 14/13/12 without a Face ID or passcode, then you can try unlocking it by using AnyUnlock- iPhone Password Unlocker. This amazing iOS device unlocking tool works flawlessly to unlock iPhone screen passcode even without Touch ID or Face ID. And here are some of its key features:
Now, get AnyUnlock for free and follow the steps to unlock iPhone 12 without Face ID or passcode:
Step 1. Free install AnyUnlock and run it on your PC > Connect your iPhone 12 to the PC > Tap on Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Click Download to the iOS firmware package page for unlocking the passcode of your iPhone 12. Once the firmware is downloaded completely, tap on the Unlock Now option.
Tap on Unlock Now to Remove Screen Passcode
Step 3. When the recovery process is completed, you will see the Screen passcode removed successfully interface.
It was this hassle-free and quick to use AnyUnlock to remove the screen passcode from your iPhone 14/13/12. No other method in this list is as quick and straightforward as AnyUnlock to solve your issue related to how to unlock iPhone 14/12 Pro Max!
Another way to unlock your iPhone 14/13/12 without Face ID, passcode, or Touch ID is to restore your iPhone to Factory Settings. You can perform this action by following the steps below.
Unlock iPhone 14/13/12 by Restoring to Factory Settings
Once your iPhone restores to factory settings, it will restart. You can then set it up as new. Restoring your iPhone 12 to factory settings was this easy to solve your issue! If in case this method didn’t work, then you can try the next method.
If none of the above methods on how to unlock iPhone 12 works to fix your issue, then you can try fixing it by erasing your iPhone 12 via Find My iPhone on iCloud. Before opting for this method, make sure you have another iOS device such as an iPad or iPhone to help you rest the iPhone 12 without PC or passcode.
Unlock iPhone 12 via Find My iPhone on iCloud
Here are the quick steps on how to erase your iPhone via Find My iPhone on iCloud.
There is another way that can help you. You can reset and delete a locked iPhone without a computer thanks to the iOS 15.2 update. If your iPhone is running iOS15.2 or later, you can find this “erase iPhone” option on the “iPhone Unavailable” screen or the “Security Lockout” screen.
Steps of Use “Erase iPhone” to Unlock iPhone 12 without Passcode:
Click on Erase iPhone Option
Once completed, the iPhone will automatically restart.
The voice control capability is one of the accessibility features introduced by Apple in iOS 13. It enables you to use your iPhone/iPad hands-free. To unlock your iPhone, you don’t need to input a passcode; instead, you use your voice to deliver orders such as capturing screenshots, launching apps, setting alarms, and, well, more. It is a life-saving device for persons who have limited movement. But here’s an additional way you can attempt to unlock your phone.
Unlocking an iPhone with a passcode or Face ID is very easy and straightforward, and you don’t even need any tech skills to do that. So, if here’s how each of these unlocking methods works to unlock your iPhone 14/13/12!
Face ID allows iPhone 12 users to securely unlock their iOS devices, authenticate purchases, sign in to the apps, and more. All this can easily be done with just a glance. So, here’s how to unlock iPhone 12 with Face ID.
Unlock iPhone 12 with Face ID
It was this quick to unlock iPhone 12 with Face ID. You can simply turn on and off this feature by going to the Settings of your iPhone.
Unlocking iPhone 12 with a passcode is hassle-free and quick. Here’s how it works!
Unlock iPhone 12 with Passcode
Once you enter the passcode correctly, your iPhone 12 will be unlocked in a few seconds. Now, if you are hunting the ways to unlock your iPhone 12 without a passcode or Face ID, then refer to the next section of this guide.
Having learned how to unlock iPhone 12 without passcode or Face ID 2025, we’d like to introduce how to unlock iPhone to any carrier. This is usually needed when you buy a second-hand iPhone or you seek to use your phone in another country. You’re required to unlock the previous iPhone carrier in order to switch to the new carrier and enjoy new telecommunication and network services. In these situations, if you don’t want to contact the previous carrier and charge extra fees, AnyUnlock also provides with you the SIM card unlocking service.
Free get the latest AnyUnlock, take a closer look at its iPhone SIM unlocking functions and try unlocking your iPhone to any carrier on your own.
Choose Remove SIM Lock
By following this how-to guide, you can easily unlock your iPhone 14/13/12 without a passcode or Face ID. You can choose the method of your choice and get yourself served with the best results. But if you are looking for a method that can guarantee flawless results, then AnyUnlock is the highly recommended tool that will serve your purpose well. So, without having any second thoughts, opt for AnyUnlock now and experience the best iPhone unlocking results.
