Are you facing trouble in unlocking your iPad? If yes, then you will find this article helpful. Here you will learn about how to unlock ipad passcode without restore using different methods. So, ensure that you read the article till the end.
How to unlock iPad passcode without passcode without resetting? Just free download AnyUnlock to unlock iPad passcode in simple clicks. No skills required, you can unlock iPhone even at home. Supports all iPhone models.
In order to secure your iPad from unauthorized access, you may choose to lock it by creating a long and strong passcode. Surely it does enhance the security of your device, but a lot of times, a “difficult-to-remember” passcode makes it challenging to recollect.
Unlock iPad Passcode without Restore
With time or when in a hurry, you are most likely to forget the screen passcode completely. Things get worse when you repeatedly enter the wrong passcode, and you get locked out of your iPad. In such a scenario, it is natural to panic.
But not anymore! If you are unable to get inside your iPad and looking for how to unlock iPad passcode without restore, consider this article as help. In the coming parts of this article, you will come to figure out several solutions that will help you in unlocking your device. So, let’s begin!
If you have forgotten the passcode or you have entered a wrong passcode several times on the iPad, it will be disabled due to security reasons. In such a case, you are left with no choice but to perform an iOS restore. As it is by far the only official way to unlock an iPad, it is impossible to unlock iPad password without restoring.
Moreover, there are certain disadvantages of unlocking an iPad by restoring it. One is that you will end up erasing all the existing settings and data of your device. It means you will lose all the pictures, videos, messages, etc; the other disadvantage is that restoring an iPad is an extremely complicated task and you may face iTunes won’t restore issue sometimes. It will take some time, and the worst consequence is a blank device with no previous data at all. Even if you use iTunes or Find My iPad, restoring the operating system would end up deleting all your crucial data. However, if you have maintained a backup of your important files on a computer or an external storage device, you restore disabled iPad without losing data or losing everything.
Now, you may wonder how to unlock iPad passcode without restore. Thankfully, there are some effective methods by which you can remove passcode from iPad without restoring. So, now let’s check out the ways one by one.
The first way to resolve the issue of how to unlock iPad passcode without restore is to bypass the iPad passcode through iCloud. For most issues related to Apple devices, iCloud is one of the effective tools to fix the issue. Even if you don’t have a laptop, you can still unlock your iPad without restoring it via iCloud.
For this method to work, you will be required to link your device to the iCloud account. Then, enable the Find My iPad option by visiting icloud.com. Here are the steps to remove your iPad passcode via iCloud.
Select the Erase iPad Option
Further Reading: How to Fix iPhone Restore from Backup Stuck >
If the above-mentioned method fails to unlock your iPad, you would require an advanced tool that will help you with how to unlock iPad passcode without restore. Since there are many third-party iPhone/iPad unlock tools available in the market out there, you can’t afford to take a chance on random software. It might end up erasing all your data.
Thus, the best way to remove passcode from your iPad without restoring is to use AnyUnlock. It works as a professional iPhone unlocker to unlock the iPad if you have accidentally disabled it after entering too many wrong passcodes. With just simple clicks, you will be able to use your device normally.
Step 1. Download and launch AnyUnlock on your PC. Connect your iOS device to the PC through a cable. From the main interface, select the Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. AnyUnlock will auto-detect your device. Tap on the Download button to get matching firmware. If not, please manually enter your iPhone into recovery mode.
Get a Matching Firmware
Step 3. When you see the Download Complete page, click on the Unlock Now option.
Tap on Unlock Now
Step 4. Wait for a few minutes, you will see the removed successfully page as below.
That’s it! In mere 4 steps, your iPad will be unlocked. Isn’t it fast?
If you fail to bypass the iPad passcode via iCloud, then you can consider using Siri. It is a voice recognition system launched and developed by Apple. Here is how you can use Siri to fix the issue of how to unlock iPad passcode without restore.
Open the World Clock App
Tap on the Plus Icon
Click on the Share Option
Select the Create New Contact Option
The last option you can consider to bypass the iPad passcode is by taking support from Apple service. After several failed attempts of putting the wrong passcode or forgetting your passcode completely, your device will be disabled.
According to the solution provided by Apple support, you’ll have to erase your iPad settings. It will delete your data, including the passcode as well. Thus, make sure you take a full backup of your iPad before you decide to go with this method. Here’s how you can remove the password.
You can go with any of the methods mentioned above to unlock your iPad. However, using AnyUnlock is a hassle-free way to remove the passcode from your device. With this, you’ll have an answer to how to unlock iPad passcode without restore.
