Whether you’re traveling or want to change your mobile phone network, you need to unlock Boost mobile phone first. It is not so difficult to do that. And we have discussed 2 methods on how to unlock a Boost mobile phone yourself free/paid. Let’s read on.
If your iPhone is locked to Boost mobile, you can free download AnyUnlock to unlock it by yourself. No technical difficulties. Only need 5 minutes, and then you can use your iPhone with any network carrier.
Are you planning on traveling in the near future? Do you want to change your mobile network provider? Are you giving your Boost phone away to someone? If yes, then you should unlock Boost mobile phone first. If you purchase a smartphone from your mobile network provider like Boost, your smartphone will probably come with a SIM or carrier lock. What does this mean? You cannot use any other network’s SIM on your mobile except Boost.
Service providers put a network lock on their smartphones to restrict their usage in certain countries or networks. But luckily, in this post, you can learn how to unlock a Boost mobile phone yourself free or paid.
Bonus Tip: Here are some other tips about SIM card unlock you may like.
Yes, of course. You can either unlock it by calling Boost customer service, or you can unlock it yourself using a third-party SIM unlocking tool. However, when using a third-party tool to unlock Boost phone, make sure it is authentic and reliable.
So, how to unlock Boost mobile phone? Just follow the 2 sure-shot methods below. Let’s see what they are and how they work.
If you’re looking for an easy yet instantaneous way to unlock Boost mobile iPhone, you can use a safe and reliable third-party iPhone unlocker like AnyUnlock. It is an unlocking tool designed for iOS devices, which can help you remove the SIM lock from your carrier-locked device within minutes. Besides, it is also capable of unlocking locked iPhone screens, iCloud activation lock, Apple ID, and MDM lock, among other features. And you can learn more about what AnyUnlock can do for you to solve how to unlock Boost phone.
If you want to unlock Boost mobile phone, just get AnyUnlock for free, and here is how to unlock a boost mobile phone yourself via AnyUnlock:
Step 1. Launch AnyUnlock on your computer and select Remove SIM Lock from the interface. Connect your iPhone to your PC, and click Start Now to start the SIM unlocking process.
Choose Remove SIM Lock
Step 2. Click on Jailbreak Now, and then agree to the terms of use before continuing.
Click Jailbreak Now Button
Step 3. AnyUnlock will display your device’s information. Click Remove Now to proceed with the SIM unlock process.
Click Remove Now
Step 4. Before the SIM unlock process, you must turn off the WI-Fi on your iPhone and remove and re-insert the SIM card. Click OK to continue.
Forgot This Network on iPhone
Step 5. AnyUnlock will start removing the SIM lock from your device. It might take a few minutes; therefore, do not unplug or use your device during it. Once the SIM lock is removed, you will get a notification for it.
SIM Lock Removed Successfully
And that’s how to unlock Boost mobile phone yourself using AnyUnlock!
How to unlock a Boost mobile phone yourself free? Calling customer service is a straightforward way to do that. However, it is not the quickest way, as it takes at least 2 working days for the network provider to send you the Boost mobile SIM network unlock pin to unlock your device. Moreover, your phone must meet some basic requirements to be eligible to let Boost mobile unlock phone.
Boost Mobile Website
You can only unlock Boost mobile phone if it falls on the following criteria:
If your phone successfully complies with these requirements, you can call customer service to request the Boost mobile network unlock code free. But if you want to unlock Boost phone before 12 months, you should use AnyUnlock to unlock it.
Here is how to unlock a Boost mobile phone in this way.
After getting the unlock code, let’s see how to unlock a Boost mobile phone yourself free.
However, as we mentioned earlier, it takes at least 2 working days for you to receive the Boost mobile sim network unlock pin. Therefore, if you’re in a rush and can’t wait for 2 days, you’d better go to the first method to unlock Boost mobile phone instantly and by yourself.
Although we have talked about how to unlock a Boost mobile phone, you may still be confused about the reasons for doing that. So there are several reasons why you should unlock Boost mobile phone:
With that sorted, let’s answer some common queries.
With the above methods, you can successfully unlock Boost mobile phone. And in this part, we would like to answer some related questions about Boost mobile unlock. Just go ahead.
Q. How long it takes to unlock Boost Mobile phone?
If you unlock Boost mobile via customer service, it will take around 2 working days. However, if you unlock it using a third-party tool like AnyUnlock, you can unlock it within a few minutes.
Q. What is the network unlock code for Boost Mobile?
When you request the customer service representative send you a network unlock code, you will receive it via text or email on your phone. It is an 8 or 16-digit number that carrier-unlocks your phone when entered.
Q. What is the mobile-compatible network of Boost Mobile?
Boost mobile supports T-Mobile, Sprint, and AT&T’s 4G/LTE and 5G networks.
Q. What network carriers can you use with Boost Mobile?
AT&T, T-Mobile, Sprint, and Verizon network carriers are compatible with Boost mobile.
It can be quite a hassle, especially if your phone is locked to Boost and cannot be used with other networks. But in this article, we have discussed easy ways to unlock Boost mobile phone in detail. And if you want to unlock a Boost mobile phone yourself immediately, trying AnyUnlock for free must be the best choice. Have you ever changed your network and got your phone unlocked? Which method did you follow, and how was the experience? Let us know in the comments.
