If your iPhone has been stolen and you are not sure if it can be used by the thief, or if you found a locked iPhone, you might want to know how to unlock a locked stolen iPhone. In this post, you will know how your stolen device can be used by whoever took your phone.
iPhone provides many types of passcode for you to choose from: 4-digit or 6-digit numeric code, custom numeric code, custom alphanumeric code, Touch ID, or Face ID. No matter which kind it is, AnyUnlock iPhone Unlocker can unlock iPhone passcode for you in a single click.
It is a relief to have your phone back, and many people have experienced losing their phone. According to statistics, 249 phones are stolen every day in London, and 9 out of every 10 victims of stolen phones will take action to recover their phones. If you are lucky enough to recover your stolen phone, but don’t know how to unlock it, it may make you feel confused and helpless. In this article, we will explore how to unlock a stolen iPhone, helping you to safely and effectively recover access to your device.
When someone steals your iPhone, the first thing that they are going to do is guess your screen passcode so they can access the phone. They will most likely start with a simple passcode such as 000, 1234, 6666, 8888, and so on. This is the most basic thing they will do to get into your phone.
In case they succeed in entering the correct passcode, they should have access to your iPhone and all the contents stored on it. However, if they fail to enter the correct passcode, your iPhone will remain unlocked.
Your iPhone only offers a certain number of attempts for entering the incorrect passcode. If the thief exceeds this limit, your iPhone will get disabled. A disabled iPhone requires even further steps and certain verifications for it to be unlocked. This is something they will not be able to do without the help of the original owner.
What that basically tells you is that you should always keep a complex passcode as your iPhone’s screen passcode. This way, if anyone ever steals your device, they will not be able to guess the passcode and as a result, they will not be able to use your iPhone.
The biggest problem after recovering a stolen iPhone is that it cannot be unlocked. AnyUnlock is an iPhone unlocker that focuses on iOS system passwords. After multiple updates and iterations, it is equipped with the most advanced unlocking algorithm to ensure successful unlocking within three minutes.
Whether it is because you forgot your password, facial recognition failed, or you encountered an activation lock problem. AnyUnlock can help you unlock quickly.
With advanced technology, you can safely unlock without an Apple ID or password, and quickly restore your iPhone to use.
Main Features of AnyUnlock
How to unlock a locked iPhone with AnyUnlock:
Step 1. Free download AnyUnlock on your computer > Connect locked iPhone via USB cable > Click Unlock Screen Passcode. If you need to remove Apple ID, click Unlock Apple ID.
Choose Unlock Screen Passcode
Step 2. Download a matched firmware before unlocking.
Get Matching Firmware
Step 3. Once the firmware is downloaded, click Unlock Now to start the unlocking process.
Tap on Unlock Now to Remove Screen Passcode
Step 4. Wait for a minute, and the screen passcode was removed successfully.
If the Find My iPhone has been enabled, the Activation lock will be activated once someone factory reset the locked iPhone. AnyUnlock can also help you bypass the activation lock, and you can check some detailed steps to bypass the activation lock on iPhone or iPad.
If your iPhone gets stolen and the thief tries to erase iPhone with the iTunes, your phone will get locked when it is erased. This erased iPhone will then keep prompting for the original owner’s iCloud password. If that password cannot be entered, the phone remains locked.
That very issue has actually given birth to many iPhone unlocking websites. There are dozens of sites out there that help you remove the so-called iCloud activation lock from your phone. IMEI24 is one of these sites and it allows you to remove the activation lock from your iPhone for a small fee.
Use IMEI24 to Remotely Unlock An iPhone
To use the site, you can just open the site in your browser, enter your iPhone’s details, make a payment, and your iPhone will be unlocked in a few days. Someone who has stolen your iPhone can actually use that site to get rid of the lock from the device. They can then use the phone without worries of any locks.
To prevent that from happening, you can actually do one thing. You can mark your iPhone as lost with Apple and Apple will blacklist your phone. This way it will become a bit harder for the thief to get your iPhone unlocked.
IMEI Unlock SIM is yet another website that helps you to remove various locks from your iOS-based devices. Since a stolen iPhone could have mostly only one type of lock which is the activation lock, this site offers you that unlocking service as well to get rid of the lock from your phone.
Unlock An iPhone with IMEI Unlock SIM
A thief can access this site using their browser and enter the stolen iPhone’s IMEI or serial number. They can then go ahead and make a payment for the unlock. In about five to ten days, the service can remotely unlock the iPhone making the phone available free to use by anyone.
This is one of the many services out there that help people remove the activation locks from their devices. While this is definitely a great service for the occasions like when you buy a second-hand iPhone and you cannot contact the original owner to unlock the phone, it is not a good thing for someone whose iPhone has just been stolen.
If you mark your iPhone as lost with Apple and Apple blacklists the phone, there is less likely that the thief will be able to unlock your device. Blacklisted iPhones are extremely difficult to unlock, if not impossible.
One of the ways for someone to enter your locked iPhone to some extent is to use the iOS recovery mode. This mode comes built with your iOS device and you can use it to repair many features on the phone. This mode is mainly used to restore the iPhone using Finder or iTunes. If you have ever had issues with your phone before, you have likely used this method to repair your device.
Unfortunately, if the thief knows how to use this iOS recovery mode, they can actually erase your device including all the content you have ever stored on it. They can then try to get into your device and use the phone like it is theirs.
However, they will not be able to do that. That is because the phone will require the user to enter the original owner’s Apple ID details. If they fail to do that, the phone will remain locked. If you are curious about how this procedure works, the following shows the procedure step-by-step.
Step 1. Launch the Finder if you are on Mac or launch iTunes if you are a Windows user.
Step 2. Connect your iPhone to your computer using a USB cable.
Step 3. Depending on what model you have, use one of the following key combinations to enter the recovery mode:
Enter recovery mode on your iPhone
Step 4. Find your iPhone in Finder or iTunes. You will get a prompt that asks if you want to restore your device. Click on the Restore button to restore your iPhone.
Restore An iPhone in Recovery Mode
If your iPhone or iPad is stolen, you can quickly take the following steps to prevent data loss or other unnecessary trouble.
1. Use Find My iPhone/iPad
Activate Lost Mode: Use the Find My app on another Apple device or visit [iCloud.com] to activate Lost Mode. This locks your device with a passcode and displays a custom message with your contact number on the lock screen.
Track your device: If your device is online, you can see its location on a map. If it’s offline, you can see its last known location.
Play a sound: If your device is nearby, use the Find My app to play a sound to help locate it.
2. Protect your data
Erase your device: If you think you can’t recover your device, use the Find My app to erase all data from your device. This will prevent the thief from accessing your personal information.
Change your Apple ID password: This will prevent anyone from accessing your iCloud data or using other Apple services from your device.
Update your account passwords: Change the passwords for other accounts that are accessible through your device, such as email, social media, and financial accounts.
If you are lucky enough to find your phone, be sure to set a strong password, as we mentioned above.
By the end of the article, we collect a list of frequently asked questions about unlocking a stolen iPhone. No matter if you found an iPhone or your iPhone was stolen, you’d be suggested to keep reading to learn more about this topic.
You can use Apple Lost Mode to lock a stolen iPhone if you lost iPhone and want to lock it to avoid privacy loss. Lost Mode allows you to lock your device and others can’t access your personal information. The thief has no access to any features on your iPhone.
To turn on Lost Mode:
Enable Lost Mode for Your Device
Normally, someone cannot unlock your iPhone without a passcode. However, they can factory reset your iPhone and unlock it using the above method or some iPhone unlocking tools. Also, it is possible to unlock a found iPhone with the same methods.
If you turned on Find my iPhone earlier, iCloud Activation Lock can protect your iPhone furtherly. Also, you can set up Lost Mode to protect your personal information and track your device in Lost Mode. And Lost Mode allows you to display a custom message about how to contact you on your device screen.
If you found your lost iPhone when you already activated Lost Mode, how can you unlock it? You can unlock a lost iPhone that is reported stolen by turning off Lost Mode:
You can first contact the previous owner through the information if the owner turned on Lost Mode. If you can’t find the owner after trying the methods, or you bought a second-hand iPhone but can’t contact the previous owner, you may try to unlock the iPhone with the above methods legally.
In conclusion, whether you have accidentally encountered or purchased a locked iPhone, it is crucial to handle the situation legally and responsibly. This article explores various methods to unlock a stolen iPhone. Among the available tools, AnyUnlock stands out for its simplicity and effectiveness. It provides a reliable solution to unlock a stolen iPhone, and besides that, it also supports the following features:
Download AnyUnlock now to unlock your iPhone safely, reliably and quickly. It is a trustworthy choice!
