Top 4 iPhone/iPad Unlock Software Review
Here are 4 Apple ID unlock software for you to remove iCloud lock from your iPhone iPad. Here we describe each of these tools in detail for you.
Author Avatar Joy Taylor Last Updated: Jul. 24, 2024
AnyUnlock – Best iPhone/iPad Password Unlocker
Free download AnyUnlock – iPhone Password Unlocker to unlock an iCloud locked iPhone without Apple ID or password. You can also check if the iCloud Lock is removed yet.
If you forgot your iPad password or entered the passcode wrongly 10 times, the iPad would be disabled. Then how to unlock an iPad without a password will become a big problem.
iCloud Activation Lock will be triggered when you enable Find My iPhone on your iPhone or iPad. Next time when you or other people seek to factory reset iPhone, erase data on iPhone, set up iPhone, or even turn off Find My iPhone, you’ll be asked to enter both Apple ID and password. Or if you forgot the Apple ID Email or password, you will be stuck on the iCloud Activation Lock screen.
iPhone iPad Unlock Software
So, if you’re looking for iPhone/iPad unlock software that can help you unlock your Apple ID so that you can use your iPhone, you’re in the right place. There are software to unlock an iPhone/iPad without Apple ID or password.
Below we will demonstrate the top 4 iPhone/iPad unlock software in 2023, so let’s explore them and simply pick the one meeting your requirements.
1. AnyUnlock – iPhone/iPad Unlocker [Safe & 100% Success]
Whether you’re locked out of the screen lock because you forgot your password or stuck on the iCloud Activation Lock interface. It can be tricky and complicated. At this point, I’m going to recommend a superhuman savior for you – AnyUnlock – iPhone/iPad Password Unlocker.
AnyUnlock is one of the most comprehensive iPhone Unlocker, its iCloud Activation Lock removal feature can help users bypass the activation lock without Apple ID and password, at the same time, remove screen lock, unlock Apple ID and retrieve encryption password of iTunes backup are no problem. Free get it now and follow the detailed guide to unlock your iPad and bypass iCloud activation on your iPhone/iPad. You can either unlock iPhone/iPad on Windows or Mac computer.
Features:
  • Unlocker for all passcode types, like numeric code, Face/Touch ID, etc. Get rid of the screen passcode on your iPhone and iPad
  • Bypass Activation Lock quickly without the Apple ID and password.
  • Remove the Screen Time passcode from your devices
  • Access the saved passwords on your iOS devices
  • Decrypt your iTunes backups
  • Recover the password for your iTunes backups
Pros:
  • Unlock with a relatively high success rate and no data leakage.
  • No skills are required, it’s simple to use.
  • Professional team with 7-year unlock experience & helped 100,000+ users.
  • 60-Day Money-Back Guarantee and 24/7/365 expert support.
Cons:
  • Your iPhone or iPad will be jailbroken before bypassing iCloud Activation Lock.
As you may be locked by a screen lock, you may also be locked by an iCloud Activation Lock. To solve these two problems separately, we have given two solutions. You can choose according to your needs
1. How to Unlock iPad without Passcode
Step 1. Free get AnyUnlock on your computer > Connect your device to computer with a USB cable > Select the Unlock Screen Passcode option.
Choose Unlock Screen Passcode
After unlocking the screen passcode, all the device data will be erased and the iOS system will be updated to the latest iOS version supported by your device. Please make sure you made a backup for your iPad.
Step 2. Click the Start button >  Enter Recovery mode on your device, then download the matched firmware > Tap on Download.
Get a Matching Firmware
Step 3. After the firmware is downloaded, click Unlock Now. AnyUnlock will unlock your iPad screen passcode automatically.
Tap on Unlock Now
Tap on Unlock Now
Step 4. After the recovery process on the iPad is completed, you will see the Screen passcode removed successfully as below.
2. How to Bypass iCloud Activation Lock
For Windows Users
Step 1. Free download AnyUnlock and launch on your computer > Choose the Bypass iCloud Activation Lock mode.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iPhone or iPad to the computer > Check the device information and tap on Start Now.
Connect Your iOS Device to the Computer
Step 3.  Then, you need to jailbreak your device to allow AnyUnlock to bypass for you. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4.  After that, you can view the basic info about your device. Then, please click Start Now button.
Bypassing iCloud Activation Lock
Step 5. When the iCloud Activation Lock is bypassed successfully, you will see the iCloud Activation Lock is bypassed successfully interface as follows.
iCloud Activation Lock Is Bypassed Successfully
For Mac Users
Step 1. Download and install AnyUnlock > Launch it and navigate to the Bypass iCloud Activation Lock page.
Click on the Start to Go On
Step 2. Connect your iPhone or iPad via a USB cable > Tap on the Start button > Click Start Jailbreak button and download the right jailbreak tool for your iOS device.
Download the Jailbreaking Tool
  • Once the iOS device has been jailbroken successfully, some functions will not available. The jailbreak will disable the cell phone call making, cellular data using, FaceTime calls making, and iMessage sending, etc.
  • Any reset or upgrade processing will lock this iOS device again.
Step 3. Once the jailbreak tool has been downloaded successfully, put your iDevice into DFU mode by following the on-screen instructions. Then the jailbreaking process will start. When your iPhone the jailbreaking process completes, click on Bypass Now to start the process.
Tap on Bypass Now to Start Bypassing
Step 4. Wait for a few minutes, and then you will see the iCloud Activation Lock is bypassed successfully interface. After iPhone restarting, the iCloud locked page will be removed.
Please DO NOT log into iCloud from the Settings on your iPhone iPad iPod touch or factory reset your device which will lock the device again.
2. DoulCi Activator – Remove iCloud Lock
What is so great about Apple devices is that they are fully loaded with security features. Sometimes, though, these security features turn out to be your enemies. Activation lock is one of the security options you will find on your devices, but if you buy a device and it has this lock on it, it becomes almost impossible to unlock your phone without the original owner.
Fortunately, you have DoulCi Activator available. It is a tool that allows you to remove the iCloud activation lock from your iOS-based devices. It does not require the original owner of the phone to be present. All you need to do is connect your device to your computer and fire-up the tool. It will then do what it needs to do to unlock your device.
This tool works with iPhone, iPad, and even iPod. This basically covers all the iOS devices out there.
DoulCi Activator - Remove iCloud Lock from your iPhone
DoulCi Activator – Remove iCloud Lock from your iPhone
Features:
  • Quickly unlock your iCloud locks
  • User-friendly app interface
  • Runs the activation server locally
  • You can use it offline as well
  • Supports all iOS versions
  • Works with all iOS device models
Pros:
  • High success rate
  • Runs on both Windows and Mac machines
  • Live support available to assist you
Cons:
  • The local server sometimes acts up
  • The software gets sluggish at times
  • Occasional crashes
3. OpenMyIcloud – Remove Activation Lock
One of the hardest things to unlock on an iPhone is the iCloud lock. If the original owner did not turn off Find My iPhone before selling the phone to you, your iPhone will get locked when you try to erase it. Fortunately, there are many tools out there to help you get rid of this lock from your phone.
OpenmyIcloud, as the name implies, allows you to open the iCloud lock on your iOS-based device. This tool works in conjunction with iTunes and helps you overcome the activation lock on your iPhone or iPad device. All this tool basically requires you to do is connect your device to your computer, click on an option in iTunes, and the tool unlocks your device for you.
The tool has been recently updated to ensure it can unlock all the latest models of the iPhone and iPad, and to support the newer iOS versions.
OpenMyIcloud - Remove Activation Lock from your iPhone
OpenMyIcloud – Remove Activation Lock from your iPhone
Features:
  • Unlock the iCloud lock on your device
  • Get rid of the lock-in about fifteen minutes
  • Support for newer versions of iOS
  • The tool runs on Windows, Linux, and Mac
  • Can be used offline without the Internet
Pros:
  • Unlock all the recent models of the iOS devices
  • Mimics the actual activation server to unlock your device
  • Causes no damage to your phone
Cons:
  • Requires you to do a survey before unlocking
  • Confusing tools
  • The free version only offers limited features
4. iCloud Bypass Tool – Get by the iCloud Lock
iCloud Bypass Tool is one of the tools that helps you to remove the iCloud lock from your iPhone and iPad devices. The good thing about this tool is that it supports all the firmware versions on your iOS devices. You do not have to be on a certain firmware to be able to unlock your device. Also, the tool is absolutely free and there is nothing you need to pay to use it.
When you download and launch the tool, you will see a couple of options on the main screen. These options are self-explanatory and so you should quickly know what they do. Depending on what lock you want to get rid of on your iOS device, you can click on an appropriate option on the app interface. It will then run the background task to remove the lock from your device.
There is a DFU mode guide as well in the tool to instruct you on how you can access this mode on your iPhone or iPad.
Icloud Bypass Tool - Get by the iCloud Lock on your iPhone
iCloud Bypass Tool – Get by the iCloud Lock on your iPhone
Features:
  • Remove the activation lock from your phone
  • Get rid of the passcode lock on your device
  • Works with any firmware version
  • Can be used with any iPhone or iPad model
  • Offers live support
Pros:
  • Regular tool updates so you can unlock newer devices
  • Easy unlocking steps
  • Modern interface
Cons:
  • Often fails to unlock the phone
  • Sometimes it freezes up during the unlocking process
  • Sudden closes
Also Read How to Backup Disabled/Locked iPhone >
With several iPhone unlock software available in the market, you can easily and efficiently remove any type of lock from your iOS-based device. If one app does not work, you can always try the next one and you might just get lucky.
Among them, AnyUnlock – iPhone/iPad Unlocker is a complete and powerful iPad unlocker tool. With it, you can bypass iCloud activation lock and unlock iPad without passcode with the easiest operation and the highest success rate. Just get AnyUnlock for free to try it>>
