How to Switch from AT&T to Verizon
The choice of mobile carrier greatly affects user experience, pricing, coverage, and quality of service, so users who are unhappy with the current contract could be looking how to switch from AT&T to Verizon or vice versa. You can make the jump to a different carrier very easily and with a minimal interruption to your daily habits, but only if you learn everything there is to know about this possibility.
Download AnyUnlock – iPhone Passcode Unlocker for free and solve the problem of switching from AT&T to Verizon in one click.
Can AT&T iPhone be used on Verizon? The answer is absolutely yes. Verizon and AT&T are two of the top mobile carriers in the United States, and they both have very competitive offers for pre-paid and post-paid users. This is a market where customer loyalty is quite limited. And it’s not rare at all to see users switching between those two networks, sometimes multiple times within just a few years, while hunting for the best deal available at each moment.
While it’s not hard to learn how to switch from AT&T to Verizon, there are some technicalities you should be aware of if you want to ensure a completely smooth transition. That’s why it makes sense to gather as much information in advance of the move and conduct all the necessary preparations in time. In particular, you should be well-educated on how to switch phone carriers and keep your phone number on a different network.
Switch Carrier from AT&T to Verizon
This article might help you in this regard, as it contains an accurate and up-to-date explanation of the process of switching between these two providers. It provides guidance and makes an already simple task even less challenging for the average user.
What to do before Switch from AT&T to Verizon
Trying to switch from AT&T to Verizon is not a complicated task. But how do you get started? We’ve listed a few things to keep in mind for you next. Preparing before you switch carriers will make it easier for you.
- Check Verizon coverage. Verizon covers 70 percent of the country. It serves 27 states, covering 90 percent of the country. So, to ensure you have stable internet usage, you need to verify that your address is within Verizon’s range.
- Check your AT&T billing cycle.
- Make sure your AT&T phone is unlocked. For example, your phone should not be associated with any cases of fraud or theft; you should not have any carryover balances; your phone should not be active on other accounts, etc.
- Check if your AT&T phone number is available on Verizon. You can visit the Switch to Verizon page on the Verizon website, so that you can verify if your number can be ported from AT&T to Verizon.
Information You Need to Provide before Switching Carrier
If you have never gone through a change of this kind before, the first question to ask is what information do I need to switch from AT&T to Verizon without any delays or administrative issues? The point is that you will need to provide some personal data that will help the operator identify your account and execute the switch you are requiring. Below, we have listed some of the information you may need to provide:
- Your phone number
- A copy of the last bill
- A driver’s license
- A credit card
- Social security number
- IMEI number
- Phone Passcode or PIN code
Make sure that all the data you provide to the carrier is accurate since even a small error could prevent your request from being executed and cause an unnecessary delay.
How to Switch from AT&T to Verizon via Old Phone Number
If you are wondering “Can I switch from Verizon to AT&T and keep my number”, the answer is yes and the procedure is pretty simple. Most users of other networks are eligible to bring their number with them when they join
Verizon, with some exceptions based on geography, compatibility of the number, etc. Just need to follow 3 simple steps:
Step 1. You can visit the Switch to Verizon page on this operator’s official website to confirm that the number you want to use is indeed possible to port to this network.
Switch to Verizon and Keep Old Number
Step 2. Once you ensure this, you should contact the carrier directly either through the internet or in the store, and let them complete the procedure internally.
Step 3. After that, you will be issued a SIM card that corresponds to your old phone number and once you insert it into your phone you will be able to complete your transition. However, it might take some time for the number change request to be processed by Verizon and your AT&T number verified and ported, so you need to stay patient.
How to Transfer from AT&T to Verizon by SIM Unlocker
As mentioned above, the process of switching from AT&T to Verizon is a bit of a hassle, whether you want to keep your old number or not. Not only do you need to provide a series of the necessary information, but you also need to spend some time processing and waiting.
So, to help you switch from AT&T to Verizon quickly and easily,we higly recommend AnyUnlock, which is the most complete iPhone unlocker for you!
To switch your phone carrier to another one, please refer to the following steps:
Step 1. Download and launch AnyUnlock. Tap the Start Now button in Remove SIM Lock mode.
Choose Remove SIM Lock
Step 2. Check the device information, read the Terms of Use, and click Jailbreak Tutorial. After the jailbreak is complete, click Next, then Remove Now.
Click Remove Now
Step 3. Follow the on-screen instructions to prepare for unlocking, including turning off WiFi and reinserting the SIM card. Once ready, AnyUnlock will start removing the SIM lock on the iPhone. Minutes later, you’ll see the Removed SIM Lock Successfully page as below.
SIM Lock Removed Successfully
How to Switch to Verizon from AT&T via New Phone Number
But if you’re not willing to keep your existing phone number and would like to apply for a new one, no worries, you can do that easily.
Step 1. You can visit a Verizon retail store or the Verizon website to select a cellular phone and calling plan at first.
Step 2. Secondly, please provide the necessary information about Verizon to check your eligibility for services. This information includes your Social Security number and current address, which will be used to check your credit status. After the check, this will activate Verizon’s service.
Step 3. Finally, once Verizon’s service has been activated, you need to contact AT&T to cancel your current service. You can reach AT&T customer service at (800) 331-0500 or you can dial 611 from your AT&T phone.
How to find IMEI on Android?
In some cases, IMEI number could be printed on the SIM slot or shown in the About phone section of the Settings menu, but Android users also have an option to run the Phone app and dial *#06#.
How long does it take to switch from AT&T to Verizon?
Switching your mobile account from one carrier to another can usually be completed within 24-48 hours after you send the request. Your current mobile service should be unaffected during this time.
How to check device compatibility?
In order to check whether you can use your old phone with a different carrier, you should enter the IMEI number associated with your device into the appropriate field on the new carrier’s website.
Is it worth switching from ATT to Verizon?
When we are changing carriers, we definitely consider whether it’s worth it. But there’s no definitive answer to this, it depends on the situation
For example, AT&T and Verizon offer similar plans, and the price difference between the plans is only a few dollars, so saving $5 or $10 a month may not be worth switching carriers for you
However, if you live in a rural area, Verizon does offer better coverage, so if a better network experience is desired, then it’s worth it!
Final Thoughts
Mobile users should be free to choose the best deal available and shouldn’t stay bound to the same service provider forever. Since switching from AT&T to Verizon is really simple and there is little to no danger of losing any personal data, there is no reason to hesitate if you see a good offer by a rival carrier. Among the methods mentioned above, it is most recommended that you try AnyUnlock because you don’t need to wait. Also, it can help you bypass the activation lock and detect the phone status of the used iPhone.
Joy Taylor
