Is your mobile phone is locked to a particular network carrier? Don’t worry. Here we will discuss the best ways to unlock a network phone via SIM unlock chip.
Free download AnyUnlock to unlock your network-locked phone from any carrier. No need to use chip unlock.
This is likely that you bought a SIM card that was locked to a certain carrier and that you would like to unlock the phone so that you can switch SIM carrier and use it with a different network provider. Most of the time, a phone is network locked if you acquired it via a network carrier firm offer. You can use a SIM card unlock PIN or a SIM unlock chip to unlock a network locked phone and use it with any other network carrier. It is one of the easiest ways to unlock a network locked phone by yourself.
SIM Unlock Chip
You can unlock a SIM card or network locked phone in many ways. Here, we have mentioned some of the ways to unlock a network locked phone. Stay with us till the end to unlock a SIM locked or a network locked phone.
Chip Unlock is when you unlock a network locked phone using a small chip to get rid of its limitations, you can also refer it as SIM unlock chip. Normally, a SIM unlock chip has to be wrapped around a regular mobile SIM. By preventing communication between the device and the actual SIM card, the functioning of the SIM will be changed. This allows you to utilize a locked device on a different network carrier of your preference.
It can be one of the best solutions for you when your phone is locked to a particular network carrier, and you want to unlock it without taking the issue to the network provider company.
You can use SIM unlock chip to unlock a network locked iPhone, so that you can use it other network carrier which offers tariff at a less costs.
Use SIM Unlock Chip
To insert a SIM unlock chip in an iPhone follows the below-given steps.
If you can’t find a suitable SIM unlock chip to unlock an iPhone that is locked to a SIM or network carrier, then you can give AnyUnlock a try. This iPhone unlocker helps you unlock a network locked phone in just a few clicks by yourself. As one of the most helpful SIM unlock services, AnyUnlock can help you unlock iPhone to any carrier such as AT&T, T-Mobile, Telstra, Vodacom, and other carriers. Besides, as a complete iPhone Password Unlocker, it can also help iOS users get rid of screen lock, Apple ID, iCloud Activation Lock, and other iOS passwords by yourself.
Follow these steps to unlock a network locked iPhone using Anyunlock.
Step 1. Free download and install AnyUnlock on your PC. Open the app and select the Remove SIM Lock option. Click Start Now after plugging in your iPhone with a USB cord to the computer.
Choose Remove SIM Lock
Step 2. Then your screen will show the information from your iPhone. Select Remove Now by clicking.
Click Remove Now
If you haven’t yet jailbroken your iPhone, follow the on-screen instructions before attempting to unlock your SIM card.
Step 3. Follow the on-screen steps to pull out of SIM card and disconnect the Internet. Click on “OK” after carefully reading the instructions.
Pull Out of SIM Card and Disconnect the Internet
Step 4. Your iPhone will begin to be unlocked by AnyUnlock. Wait until your phone gets unlocked.
SIM Lock Removed Successfully
If you wish to use the phones with another network carrier, they may be very difficult to use if they are locked to that network provider. One of the simplest ways to get around a phone’s network lock is using an unlock chip, but if you don’t want to use one, we advise using AnyUnlock. In a matter of simple steps, it may assist you in unlocking a network carrier.
