Ever been locked out of your SIM Card because of lost or forgotten SIM PIN on an iPhone? Don’t stress yourself about that as we reveal the various SIM unlock options for iOS devices here.
Hi, unfortunately, I forgot the PIN to the SIM Card on my iPhone. Although I’ve tried some PINs, it is not working. Currently I have just one last chance which I don’t want to risk. Please, is there anyone in the house that can help me remove the SIM lock on my iPhone?
I’m sure the above question raised by an Apple user will be shared by many people. Well, whether you purchased an iDevice locked to a specific carrier, or wish to remove the PIN locked to the SIM on an iPhone, this tutorial guide is for you. The guide contains the different ways to remove SIM lock from an iPhone. Check, and apply any of the procedures that suit you to bypass SIM lock on your iDevice.
SIM Lock can be described in two ways, which will be explained in the paragraphs below:
First Definition
Second Definition
To enable SIM Lock on your mobile device, precisely iOS smartphones:
Activate SIM Pin
Now you know what SIM Lock means and how to enable it, you may encounter SIM lock on your iDevice.
SIM Lock appears for the following reasons:
Regardless of how SIM lock happened, you can fix the issue conveniently from the comfort of your home. Read on to learn how this is done.
Below we have the different approaches to bypass SIM Lock on different network carrier. But before we get started, here are a few information you need to get ready, as your network provider may request for them:
Remove SIM Lock on your AT&T iPhone by following the instructions down here:
Step 1: Firstly, you have to note down your IMEI number by navigating to Settings > General and > About. Scroll down and copy IMEI underneath the PHYSICAL SIM section.
Step 2: Head to AT&T device unlock page, read through the terms and conditions. Once done, click on Agree, then fill out the form that follows.
Step 3: Next, a confirmation link with the will be sent to your email address. Click on the link to validate your unlock request (link is only valid for 24 hours).
Step 4: AT&T should respond to your request within two business working days. Use the information provided to unlock your device.
Note: Your unlock request won’t be processed if you haven’t completed your contract with AT&T.
Here’s the hassle free guide to bypass SIM on T-Mobile network on your iOS device:
Step 1: Head to the official website for T-Mobile Network and login your account using the correct details. Click on Accounts in the upper left corner of your screen to open your T-Mobile profile.
Step 2: Next, select your plan, and click on Check to confirm you are eligible to unlock the iDevice. If you are, but your device is yet to unlock, kindly connect with the customer support team. To do that dial *6, and hit the Send button.
With US Cellular, you can remove SIM Lock on your Apple and Samsung smartphones easily and quickly, so far you meet the preconditions of the network carrier. However, the process involved can be tedious as you need to call the corresponding carrier from time to time to check the status of your SIM unlock.
Here’s how to remove SIM lock on US Cellular iPhone:
Step 1: Dial 611 to connect with the corresponding US Cellular customer support team.
Step 2: Provide all the necessary details required, such as IMEI number, so your iPhone can be registered for unlocking.
Step 3: The team will check your device to see if it’s eligible for unlocking. Once confirmed, you will be asked to use another SIM card to complete the process.
This process usually takes up to 15 to completely unlock your iPhone.
If after applying the solutions above you still can’t remove SIM Lock from your iPhone, kindly resort to a professional iOS unlock tool. AnyUnlock is a top-quality iPhone unlocker programmed to bypass lock screen on iOS devices.
With this software, you can easily remove SIM lock on iPhone 6/7/8/X and later models without stress. AnyUnlock removes SIM lock for any carrier, whether US based or not. It’s simple to use and offers quality results as it removes SIM locks without compromising users’ data.
Stepwise Guide to Remove SIM Lock from Any Carrier with AnyUnlock
Step 1. Free download AnyUnlock on your Windows PC or Mac. Click on Remove SIM Lock on the home page.
Choose Remove SIM Lock
Step 2. Connect your iPhone to the computer and make sure your iPhone is jailbroken before clicking Remove Now to continue.
Click Remove Now
If your iDevice isn’t jailbroken, follow the on-screen instructions to jailbreak your iPhone on your own.
Step 3. Follow the on-screen instructions to Forget This Network on your iPhone.
Forgot This Network on iPhone
Step 4. AnyUnlock will start removing SIM lock as below.
Start Removing
Step 5. Once the SIM lock is unlocked, you will get the success page.
SIM Lock Removed Successfully
Here we have some frequently asked questions and the corresponding answers enhance your knowledge about the topic:
Are you tired of entering a PIN code each time to put on your iOS device? If so, you should consider deactivating the feature. Turning off the SIM PIN code request feature on your iPhone is pretty easy, and here is the simple guide to follow:
You can change the PIN code to the SIM Card on your iPhone from time to time without hassles. Check the illustrative guide given down here to do that:
SIM-Lock phones are safe to use, but with limitations. For instance, you cannot use another network carrier with the SIM-locked device. If you wish to use another carrier, then you have to complete your subscription with the source carrier.
With this comprehensive guide, you can remove SIM lock on any iPhone effortlessly. No payment required to use any of the techniques introduced in the article. Additionally, the techniques are easy to employ.
However, AnyUnlock is our best option to bypass SIM Lock on your iDevice. It does this excellently without compromising your data, or crashing the device. Try using it now!
