If you are having a SIM failure issue on your iPhone and don’t know how to fix it, we’ve got you covered. Check out these 7 foolproof methods to fix iPhone SIM failure issues.
The SIM failure alerts on iPhone means that your iPhone doesn’t detect any SIM card or there is something wrong with the SIM card. Some people use factory reset to solve this problem but it’s time-consuming and the data loss risk is frustrating. Is there any way to fix SIM failure on iPhone quickly without data loss? Yes, this post will introduce the causes for iPhone SIM failure and 7 proven ways to make your SIM card run well.
You may also like: What to do when iPhone says no SIM
Various reasons may cause SIM failure issues in iPhones. Here are some that are the culprits in most cases.
Now considering these causes of the iPhone SIM failure issues, let’s move forward and see 6 easy ways to fix the issue.
Below are 6 easy methods to fix the SIM failure problem on your iPhone. Let’s check them one by one.
The first and the most convenient method that can fix your SIM failure issue is to restart your device. It is the simplest method that refreshes the system and removes most of the system glitches.
To restart your iPhone, here’s what you need to do.
Step 1. Press and hold the power button with either of the Volume buttons in iPhone X, 11, 12, 13, or later versions. If you have any other model, then just press the power button. A turn-off slider will appear.
Restart iPhone
Step 2. Now what you have to do is to drag the power off slider to the right and wait until the device shuts down.
Step 3. Once the device has turned off, press and hold the power button again until you see an Apple logo.
If your device becomes unresponsive or frozen at any point, then try Force Restarting the device. The process of force restarting an iPhone differs with different versions. So here we have explained them separately for your ease.
iPhone 8 or SE (2nd generation or later):
iPhone 7 or 7 Plus:
iPhone 6 or older:
If even restarting your phone doesn’t solve your issue, then move on to our second method and see if there’s any problem with your SIM tray.
You can encounter the SIM failure issue if there’s any dust in the SIM tray or if the SIM is not properly inserted.
So just take a SIM ejector and remove the SIM tray of your device. Clean it with a clean cloth and insert it again. Make sure that you place your SIM correctly in the tray and that it is properly closed.
If you are still facing the issue, then there’s a chance that your SIM card is locked. Let’s see how we can unlock it with a trustworthy tool, AnyUnlock.
Check the SIM Tray
SIM lock is offered to protect your SIM from unauthorized use. But the opposite can occur in some cases. If you forget your SIM lock pin, then even you won’t the ability to use it once you restart your device or insert the SIM on another device. In this case, you’ll see a “SIM not Valid” prompt on your device. This is the time when you have to unlock your SIM before you can use it. But how to do it? With AnyUnlock, of course. It is an all-in-one iPhone unlocker for various iOS devices and its advanced technology provides one of the highest success rates on top of a user-friendly interface. Let’s have a look at what AnyUnlock is, and then we’ll see how we can unlock our SIM using it.
Now download AnyUnlock and let’s see how we can unlock our SIM with AnyUnlock in a stepwise manner.
Step 1. Launch AnyUnlock on your computer and connect your device to the computer using a connection cable. Select “Remove SIM Lock” from the opening interface and hit “Start Now” once the software detects your device.
Choose Remove SIM Lock
Step 2. Now to remove the SIM lock, you need your device to be jailbroken. Click on the “Jailbreak Now” option and follow the instructions provided by the tool to jailbreak your device.
Click Jailbreak Now Button
Step 3. Once you have successfully jailbroken your device, click on the “Remove Now” option.
Click Remove Now
Step 4. Follow the on-screen instructions to set your device, and then hit “OK.” AnyUnlock will start removing your SIM lock. Pait patiently until it’s done.
Start Removing
Step 5. Finally, you have successfully removed your SIM lock. Click on the “Done” button, remove your device, and make calls all around the globe.
SIM Lock Removed Successfully
The SIM failure may also be caused by a faulty iOS system. Then you can try to repair your iPhone system with AnyFix. It does well in repairing kinds of system issues from iPhones and help you out of trouble. To fix SIM failure on iPhone, you can check the following steps.
1. Download and install AnyFix.
2. Run AnyFix and choose System Repair.
AnyFix System Repair Option
3. Choose Device Bug and go to the repair mode page.
AnyFix System Repair Device Bug
4. Choose Standard Repair and follow the instructions to finish the system repair.
AnyFix Standard Repair
When the repair is completed, you can check your SIM again and see if it works.
If a new update is available from the service provider, then your device may not support the old version. But if you update your carrier settings, then the SIM failure issue is immediately resolved in this case.
Update Carrier Settings on iPhone
For updating your carrier settings, here are the steps you need to follow.
This resolves most of the cases, but if you are still having the issue, then upgrading your iOS system might do the trick.
An outdated operating system of your iPhone device sometimes causes the SIM failure issue. So you have to update the iOS system to get rid of this annoying issue.
Here is a step-by-step guide on how to update your iOS system.
Upgrade iOS
If even upgrading your iOS system doesn’t resolve the SIM failure issue, then try contacting the Apple Support team.
After trying the above 5 methods, you can get rid of your SIM failure issue in most cases. But if you are unlucky enough to still experience the same issue, then it’s better not to interfere anymore. Try contacting the Apple support team and explaining your problem to them. They’ll find the best solution possible and guide you to it.
So that’s it, guys. Now you don’t need to worry about any SIM failure issues on your iPhone. Use these 7 easy methods, and you’ll get your device working in no time. And if the issue is due to the SIM lock, then nothing is more reliable and safe than the first-class iPhone password unlocker, AnyUnlock. Also, you can have a try on AnyFix for any system-related problems that make your SIM fail. If you found our article helpful, share it on social media, and don’t forget to leave your feedback in the comments section below.
