If you have forgotten your Restrictions passcode and are wondering about how to turn off Restrictions on iPhone, read this tutorial to find an answer.
Whether you can recall the passcode or you cannot, there are methods to help you reset the passcode and regain access to the feature on your iPhone. You will need to use the method that fits your situation and you should be able to set a new passcode for the Restrictions feature on your iPhone.
If you want to turn off restrictions mode without passcode, just free download AnyUnlock to 1-click remove restrictions password locked iOS devices in minutes.
The following guide explains what a Restrictions passcode is, how to reset it when you know the passcode, and how you can turn off Restrictions on iPhone when you don’t know the password.
If you are aware of the current passcode for the Screen Time feature on your iPhone, you have a relatively easy way to reset the passcode. It is because you can enter the passcode and authorize yourself to reset or change your passcode. It is something you cannot do when you have forgotten the passcode.
Resetting the Restrictions passcode in newer versions of iOS basically means resetting the Screen Time passcode. It is because the feature has been renamed in newer iOS updates and Screen Time is what you are going to see in place of Restrictions on your newer iPhones and iPad devices.
For iOS 12 and above users, as we mentioned above, the Restricted Mode is moved to another section called “Screen Time” in “Settings”. In this part, we will show you how to disable Restricted Mode in iOS 12 and above.
Step 1: Go to “Settings” > “Screen Time”on your iPhone.
Step 2: Tap “Content & Privacy Restrictions” option.
Step 3: Turn “Content & Privacy Restrictions” option off.
Turn off Content & Privacy Restrictions
How to Turn Off Screen Time on iPhone/iPad
Further Reading: How to Hack Screen Time on iPhone >
It is pretty easy to reset the Restrictions passcode when you know the passcode. However, things become a little tricky when you cannot recall the passcode. Fortunately, some methods can help you with this. Have a look at them.
The two methods above will erase content from your iPhone. If you don’t want to lose anything, AnyUnlock – iPhone Password Unlocker is your choice. As a professional code management tool, it provides some efficient ways to remove passcodes. If you want to know how to turn off restrictions on iPhones but don’t know the password, you may give it a try. You can even use it to manage all the passwords effortlessly after unlocking Restrictions.
Step 1. Download AnyUnlock on your computer and run it while you connect your device to the computer. Then choose the “Unlock Screen Time Passcode” function.
Choose Unlock Screen Time Passcode Mode
Step 2. Click on “Unlock Now” to start the unlocking journey.
Click on Unlock Now
Step 3. AnyUnlock backs up your iPhone in case of data loss and encrypts this backup. Please remember the code.
Unlock Screen Time Passcode Process
Step 4. Minutes later, you will get an iPhone without a Restriction passcode. And you are able to reset your restriction passcode on your iPhone now.
Successfully Removed Screen Time Passcode
If you cannot recall your Restrictions passcode, one of the ways to reset that is to erase your device. You do not need to use an app to do this as your iPhone has a built-in option to remove all settings and data from your phone. So will the Restrictions passcode.
Reset iPhone in Settings to Erase All Passwords
You can then set up your iPhone as a new device and even restore an iTunes or iCloud backup on it. The Restrictions passcode should now be removed from your phone and you can check it for yourself by accessing the feature on your device.
Those of you who prefer to use iTunes for their everyday iPhone tasks would be glad to know that you can use your all-time favorite app to reset your iPhone as well. You can use the iTunes app to restore your device and that, in turn, will reset the Restrictions passcode on your phone. The following are the steps on how to perform this on your iPhone.
Restore Your iPhone with iTunes
Regardless of why you want to reset the Restrictions passcode on your iPhone, there are several easy ways to do that on your device. Once the passcode is reset, you are then free to set up a new passcode of your liking. AnyUnlock provides an easy and efficient method to help you reset your restriction passcode, just give it a try.
