How to Unlock iPhone Passcode without Losing Data 2024
“Is there any method to unlock iPhone passcodes without losing data?” The answer is yes. This article will tell you how to reset an iPhone passcode without losing data.
Author Avatar Joy Taylor Last Updated: Sep. 24, 2024
AnyUnlock – Unlock iPhone and Reset Passcode
Download AnyUnlock to unlock 4-digit or 6-digit numeric code, custom numeric code, custom alphanumeric code, Touch ID, or Face ID on iPhone. Reset your iPhone passcode in easy steps.
“I forgot my iPhone’s password. There are some essential files on the device that I need to view right now. Is it possible to unlock my phone without losing data?”
When it comes to iPhone passcodes, the solution is not that easy. The device is equipped with a variety of security features, and the meaning of a passcode might vary. A screen passcode, a screen time passcode, and an Apple ID passcode are all available. So, to understand how to change an iPhone passcode without deleting data and to solve the problem when forgetting iPhone passcode without erasing read the article below.
Further Reading: How to Fix iPhone Passcode Not Working >
Can I Unlock iPhone Passcode without Losing Data?
Yes, it’s possible to unlock iPhone passcode without losing data. There are 2 ways to achieve it.
  • When you are running iOS 17 and later on your iPhone. You can use the previous passcode to unlock your iPhone if you forget the newly changed one.
  • If you have synced your iPhone to iTunes on your computer, you can restore your iPhone in iTunes.
However, if it’s not the above cases, you cannot unlock iPhone without data loss. No matter which is the situation you are in, you can check the following ways to unlock iPhone without losing data or erase iPhone without passcode.
1. How to Reset iPhone Passcode with iTunes
If you forgot the iPhone passcode and wanna know how to unlock forgot iPhone passcode without erasing or how to reset iPhone password without losing data. Before using this method, You must back up your iPhone’s data to iTunes. Once the iPhone passcode and the device have been wiped, you will be prompted to select a new passcode. Here’s a more in-depth explanation.
  • First, open “iTunes” and connect your iPhone to the computer using a lightning cable.
  • Now, on the iTunes window, tap on “iPhone” and then hit “Restore Backup.”
  • Click Restore Backup in iTunes
  • The next window displays a list of backups. Select the most recent and press the “Restore” button. If you are prompted for a password, enter the one from your encrypted backup.
Enter Your Encrypted Backup Password
  • After this, you will be asked to turn off “Find My iPhone”. At this moment, you must enter your iPhone into Recovery Mode.
  • Hold the buttons down until you see the “Recovery Mode” screen as shown in the image below.
Put Your iPhone into Recovery ModePut Your iPhone into Recovery Mode
  • On iTunes, a restore notification will appear; click “Restore and Update” and wait for the procedure to finish, and you are good to go!
2. Safest Way to Unlock iPhone and Reset Passcode [100% Work]
How to unlock forgot iPhone passcode safest? Whatever the lock is, AnyUnlock can save your disabled iPhone with simple steps. For example, it can unlock iPhone lock screen, Apple ID, MDM lock , iCloud activation lock, iTunes backup password, Screen Time passcode, etc.
AnyUnlock is a one-stop iPhone unlocker that is designed to unlock any password. With this tool, you can unlock your iPhone that is running any version of iOS. And when you can access your phone, you may reset a new passcode. See the main features of AnyUnlock below:
AnyUnlock – iPhone Password Unlocker
  • Bypass screen passcode and get access to iPhone with a few clicks.
  • View and get back your iOS passwords on your phone.
  • Remove an Apple ID from your iOS devices with one click.
  • Remove passcodes with simple steps, no password is required.
Now, follow the steps below to unlock your iPhone.
Step 1. Download and launch AnyUnlock on your computer > Click on the Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. Click Start and hit the Download button to download the firmware for your iPhone model.
Get a Matching Firmware
Step 3. When the firmware is downloaded, click on the Unlock Now button to start unlocking your iPhone. You should be able to see the live progress on your screen.
Tap on Unlock Now to Remove Screen Passcode
Step 4. The following message will appear when the passcode is removed from your iPhone.
3. How to Reset iPhone Passcode with iCloud
This is simpler than using Finder or iTunes. This approach, however, is only applicable if the locked iPhone is connected to Wi-Fi or mobile data.
Step 1. First, go to ” iCloud.com” on your PC and “Sign in” with your Apple ID.
Step 2. Now tap on “Find iPhone”, and then select your Device.
Tap on Find iPhone and Select Your Device in iCloud
Step 3. Next, tap on “Erase” iPhone” and just after that, enter your Apple ID password.
Tap on Erase iPhone in iCloud
Step 4.  Finally, when the iPhone is erased, set up the Device and check if it is working.
What to Do After Erasing Your iPhone
We’ve already touched on what to do if your iPhone gets wiped. Here’s some additional information.
  • Set up your device: After deleting it, you would definitely want to configure your iPhone to use it. The setup procedure involves many things. It’s rather simple. Simply read what is displayed on the screen and follow along. If you are stuck here, check this tutorial to fix stuck on setting up Apple ID.
  • Restore backups: You will see a screen called Apps & Data throughout the setup procedure. You can restore your iCloud data or PC backups from here. Make sure to select the most recent backup.
  • Re-download apps and other data: Once inside your iPhone, go to the App Store and download the apps you require. If you restore the app backup, the app will begin downloading automatically.
Bonus tip: How Do I Unlock My Disabled iPhone without Losing Data?
Here’s a bonus tip you can use to unlock iPhone passcode without losing data that Apple doesn’t officially give. So, while there is no assurance that it will always work, it is still worth a shot. Since Apple updates its iOS frequently to address security flaws, this method is only applicable to iOS 8.0 to 10.3. With that in mind, here’s a step-by-step guide on using Siri to unlock your iPhone’s passcode.
Unlock iPhone Passcode with Siri
  1. First, press the “Home Button” for a few seconds until Siri activates.
  2. Now, make a random request to Siri, respond and initiate the unlocking process.
  3. Now, on the main screen, you will see a reminder, just press and hold until you see “Select All,” once you see it tap on it.
  4. Then, use SMS to spread the word. When the message screen displays, put anything in the To field and then return to the previous screen.
  5. Then, click the “+” sign and choose Create New Contact.
  6. Go to your gallery by clicking Add Photo. Scroll through your gallery before pressing the Home button.
  7. Finally, your iPhone will now be unlocked in no time.
This is how to unlock iPhone passcode without losing data and how you can reactivate your iPhone if you’ve forgotten your password. Among all the methods above, we recommend you download and use AnyUnlock to reset your iPhone passcode without losing data. We hope the information in this guide proved helpful.
