You may fall victim to loss or forgotten passcode, and the need to remove the passcode from your iPhone arises. To remove passcode from iPhone without hassles, kindly select any of the three DIY techniques shared in this post.
Presently, the Apple iPhone is one of the most fantastic devices. iPhone is endowed with all the wonderful features you want in any smartphone, from the sleek design to the high-resolution camera, gorilla screen, and more. Another fascinating feature that makes this device stand out is the rigid security system.
The Apple iPhone has a complex security system that’s very difficult for intruders or hackers to bypass. While this is a great thing to be happy about, you might encounter some challenges with it when you forget your passcode or other related issues.
Regardless of how the challenge may come, you can opt to remove the passcode on your iPhone. Many techniques have been devised, however, not all are helpful. Here we will describe the best 3 ways to remove the passcode from any iPhone.
Prior to discussing the various ways to remove the passcode on your iPhone, let’s explore how to activate and deactivate passcode requests on your iPhone. Check the appropriate guide down here:
Check out the directions to enable passcode requests on your iPhone:
Step 1: Go to Settings menu.
Step 2: Depending on your iPhone model, kindly scroll to where you have Face ID & Passcode (for iOS devices with Face ID) or Touch ID & Passcode (for iOS devices with the Home button), and click on the corresponding icon.
Step 3: Click on the blue Turn Passcode On or Change Passcode button to proceed. Enter a strong passcode that you can easily recollect, and click on the appropriate button to save your entry.
Set up Face ID and Passcode on iPhone
Here is the detailed stepwise guide to deactivating the passcode request from your iPhone:
Step 1: Go to your iPhone Home Screen and hit the cogwheel ⚙️ button to open the Settings menu page.
Step 2: Scroll down and hit the Face ID & Passcode, or Touch ID & Passcode button, depending on your iPhone model, and the corresponding page will come up.
Step 3: Select Turn Passcode Off to deactivate or stop your iPhone from requesting a passcode each time you want to access it.
Turn Passcode Off
If you’ve enabled your device to request a passcode in the past and want to turn it off for reasons best known to you, it’s crucial you enter the corresponding passcode used in unlocking it. This is mandatory, as Apple needs to verify you are the owner of the device. Failure to provide this can hinder your action.
Now let’s proceed to how to remove your passcode from your iPhone in case you forgot it. Please use any of the 3 simple hacks below to do this:
iPhone Unlocker like the AnyUnlock software is one of the most versatile tools suitable for bypassing screen locks on your iPhone. This software helps you remove 4-6 numeric passcodes from any iPhone, whether old or new models.
AnyUnlock simplifies screen unlock operations using the most recent unlock algorithm to update your firmware package, so you can successfully regain control of your device. This software guarantees a safe screen unlock process ensuring your data files are preserved with zero quality loss throughout the whole process.
Key Features
Step 1. Free download AnyUnlock and launch it on your computer, click Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to the computer, and wait until AnyUnlock has detected your iPhone. Click Start Now.
Click Start Now Button
Step 3. Download on the iOS firmware package page. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now
Step 4. And when the recovery process is completed, you will see the Screen passcode removed successfully interface.
Apple iTunes is an all round utility well known for streaming music on iOS device and Mac computer systems. You can leverage this tool to help you remove passcode from your iPhone without stress. However, mind you, there are some preconditions you must fulfill for you to successfully remove passcode from iPhone via iTunes. Some of them are listed here:
Once you have the above in place, use the steps down here to remove passcode from your iPhone using iTunes:
Step 1: Open the iTunes app on your computer system (Please ensure you are using the latest version of the app to avoid issues), and connect the locked iPhone using the most appropriate USB cable.
Step 2: On the left sidebar of the iTunes page, locate your iPhone icon, and click on it to access the flyout menu options. Select the Summary tab from the options, and a new interface displaying your phone details will come up on the right hand panel. You should have something of this nature on your screen:
Step 3: Now tap on the blue Restore iPhone button. A prompt to verify your click will come up. Kindly click Restore to proceed with restoring your iPhone. When the restoration is over, your iPhone will go blank with zero data on it. You can try to restore backup so as to bring back your previous data.
Restore iPhone Using the iTunes App
Limitations
Do you have the Find My feature enabled on your iPhone? If so, and you are looking to remove passcode from your iPhone, you can do that with Apple ID. The Find My feature provides an avenue for you to restore your iPhone by simply signing in the Apple ID and clicking on the appropriate buttons.
This technique is super easy, fast and costs nothing. But your data will be lost. If this is fine with you, check the directions given down here to remove passcode from iPhone with Apple ID:
Unlock iPhone Screen Passcode via iCloud
Limitations
If you want to get rid of the other types of security protection features such as Face ID, and Touch ID, you can do so by removing your Apple ID. You can follow the steps below:
This solution will be handy if you still have control over your home screen, this means that you can easily bypass screen lock. Once you meet this condition, you can remove other passcodes by signing out your Apple ID from the device via Settings.
Use the step down here to accomplish this:
Step 1: Find the ⚙️ icon on your Home Screen, click on it and a new interface labeled Settings will immediately come up.
Step 2: Tap on your profile and select the red Sign Out button when the next page shows up.
Step 3: Validate your selection by clicking on the corresponding button. After that, your Apple ID will be removed from the device, and the other passcode will be off.
Of course besides the above ways to remove Apple ID, you can also use AnyUnlock to remove it more easily. If you encounter MDM lock, iTunes backup lock, iCloud activation lock, etc., seeking AnyUnlock‘s help is also the fastest and most successful way!
Whether you are struggling to turn off the screen passcode feature or can’t recollect the passcode associated with your iPhone, this guide should come in handy. We’ve looked at the top 3 ways to remove passcode from your iPhone. Choose the one that suits you to unlock your phone today.
We do recommend the AnyUnlock software for the quick removal of passcode from your iPhone. The software provider and free and effortless approach to bypass screen lock, and other types of iOS lock restrictions you may encounter. You should download, install and try it out now!
