Want to know how to remove passcode from iPad when you forgotten? So in this short and informative guide, we’ve shown you various methods to remove passcode from iPad in case you forget it.
AnyUnlock – iPhone password unlocker helps remove passcode from iPad. Download it now to unlock your iPad without password.
iPad Passcode is set to protect security and privacy, but what if you have forgotten the password? “Forgot the Passcode.” These three words can strike fear into the hearts of iPad users everywhere. It’s an unfortunate situation that many of us have faced at some point. The good news! You don’t have to be locked out of your iPad indefinitely.
In this article, we’ll equip you with the knowledge & tools necessary to remove passcode from iPad. But before diving into those methods, let’s first clarify this. Can we remove the passcode from our iPad/iPhone when forgotten?
Removing the passcode from an iPad is possible, even if you don’t know the passcode. However, it’s important to note that all the data on your iPad will be erased during this process. This means that if you don’t have a backup, you may lose them during the process. So it’s crucial to have a recent iPad backup before attempting to remove the passcode.
Another drawback is that you require access to a computer or another device. If you don’t have such resources, it may limit your options for removing the passcode.
Now, if you are ready, the most common methods involve using iTunes or iCloud. In addition, certain third-party tools can also assist in removing the passcode from an iPad. These tools often provide more flexibility and additional features. Before jumping into the details of these methods, let’s see how to remove the iPad passcode from settings.
If you have the passcode of your iPad, you don’t need to delve into any complicated method to remove it. You can just turn off your passcode from the iPad settings. It’s a simple method that doesn’t require any technical expertise.
Here are the steps to turn off the passcode on iPad via settings.
Step 1. Find the Settings app on your iPad and launch it.
Step 2. From the left bar, scroll down and select the “Touch ID & Passcode” option.
Step 3. Enter your iPad screen passcode when prompted.
Step 4. From the various options, select “Turn Passcode Off.”
Select Turn Passcode Off
Step 5. A prompt will appear on the screen. Select “Turn Off” again.
Step 6. You’ll need your Apple ID passcode to remove the screen lock. Enter the password and tap on the “Turn OFF” button at the top right corner.
Now let’s keep the momentum going and discuss some methods to remove passcode from iPad when it’s forgotten.
One reliable solution for removing the passcode from your iPad without passcode is by using a trusted tool called AnyUnlock- iPhone Password Unlocker. It is the ultimate iOS password unlocker that is specifically designed to help iOS users when they are locked out or have forgotten their screen passcode, Apple ID, screen time passcode, etc. Learn more about the key features of AnyUnlock below.
Download AnyUnlock and follow the simple stepwise guide to remove password from iPad:
Step 1. Download and install AnyUnlock on your computer. Launch it and select Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. Connect your iPad to computer, then click on the Start Now button.
Click Start Now Button
Step 3. AnyUnlock will automatically detect your device model. Click on the Download button to download suitable iOS firmware.
Get a Matching Firmware
Step 4. Wait until AnyUnlock downloads the firmware. When it’s complete, click on the Unlock Now button.
Tap on Unlock Now to Continue
Step 5. Now AnyUnlock will start removing the screen passcode. When the process finishes, the screen passcode of your iPad will be removed. If you get any issues during the process, click here for more consultation.
Another method to remove the passcode from your iPad is by utilizing the Find My feature offered by Apple. Find My is a powerful tool designed to help locate & manage your Apple devices remotely. In addition to its tracking capabilities, the Find My tool also provides the option to erase your iPad. But you need to have enabled it beforehand.
To remove the passcode using iCloud Find My tool, follow these steps.
Step 1. Visit the iCloud website and sign in to iCloud using your Apple ID and password associated with the locked iPad.
Step 2. Once logged in, scroll down & click on the “Find My” icon.
Step 3. From the list of devices, select your locked iPad.
Select your locked iPad
Step 4. In the options that appear, choose the “Erase iPad” option. This will initiate the remote erasure process.
Step 5. A confirmation prompt will appear. Confirm the action by clicking on “Erase” again.
Step 6. Find My will now send a signal to your iPad, triggering the erasure process. This process may take time to complete and requires an internet connection.
Once the erasure is complete, your iPad will restart, and the passcode will be removed. You can now set up the iPad as new or restore it from a backup. If you still don’t succeed, here’s another method.
If you have previously synced your iPad with iTunes on a computer, you can use this synchronization to remove the passcode from your device. This method involves restoring your iPad to its factory settings, which will erase all data, including the passcode.
But before you proceed, ensure that you have the latest iTunes version installed on your computer. If not, update iTunes to the latest version.
Follow this detailed stepwise guide to remove the passcode with iTunes.
Step 1. Connect your iPad to the computer. Launch iTunes if it doesn’t open automatically.
Step 2. If your device is synchronized with this iTunes, you’ll see a small phone icon at the top left side of the interface. Click on this icon.
Step 3. In the “Summary” section of the left toolbar, click on the “Restore iPad” button. A prompt will appear on the screen for confirmation. Click on “Restore” again.
Restore iPad with iTunes
Step 4. Enter your Apple ID credentials to start your iPad when the restoration process finishes.
But a lot of people don’t have a previous synchronization or have sync problems between their iPad and iTunes. So let’s see what we can do in this case.
Recovery mode is a built-in feature on iOS devices that allows you to troubleshoot various software-related issues. It enables your iPad to communicate with iTunes on your computer, facilitating the restoration process. So even if you haven’t synchronized with your iTunes beforehand, you can take the hand of iPad recovery mode.
Here are the instructions you can follow to remove your iPad passcode via the recovery mode.
Step 1. Launch iTunes on your computer. Utilize the original connection cable to link your iPad to the computer.
Step 2. Put your iPad into recovery mode. The steps to enter recovery mode may differ depending on your iPad model. Click here to see how to put the iPad in recovery mode.
Step 3. iTunes will detect your iPad in recovery mode and display a prompt. Select the “Restore” option.
Click on Restore
Step 4. Now another prompt will appear for the confirmation. Select “Restore and Update” to continue.
Step 5. iTunes will now download the necessary software and proceed with restoring your iPad to its factory settings.
Once the restoration is complete, you can set up your iPad as new or restore it from a previous backup.
And that’s all about the methods to remove passcode from iPad when forgotten. Now before we end our guide, here are some frequently asked questions about this issue.
There are many methods to reset your iPad without the passcode. You can opt for a third-party tool like AnyUnlock to do this task. Or you can use the old iTunes or iCloud method to reset your iPad. The detail of these methods has already been discussed in this article. So try out every single method and see which one works for you.
Forgetting your iPad’s restriction passcode can limit access to certain features and settings. This includes restricting access to specific apps, preventing changes to certain settings, and disabling features like in-app purchases. It also makes it difficult to modify or remove those restrictions.
Unfortunately, there is no built-in way to recover the forgotten passcode. One option is restoring your iPad to factory settings using the methods described above. But this erases all data, so remember to have a backup before taking this step. And if you’re stuck, consider reaching out to Apple Support for further assistance.
When the passcode for your iPad is forgotten, it can lead to many difficulties for users. It’s like encountering a locked door without a key. And out of these methods, we recommend you try AnyUnlock, which is convenient and can solve any of your iOS passcode-related issues. Download AnyUnlock and have a try!
