Is your iPhone or iPad under the supervision of any organization or educational institute? Discover the 3 smart ways to remove device supervision from your iPhone or iPad without spending a dime here in this post.
If you are locked or restricted by MDM, to freely use your device, just free download AnyUnlock to 1-click to remove MDM/device supervision from iPad/iPhone without the username and password.
iPhone/iPad supervision is a security feature often used by many business organizations, educational institutes, and even parents to track and restrict the activities of an iOS device. While this could be a great feature to activate on a device, it could pose a challenge, especially for folks getting second-hand devices with device supervision on them.
Are you a victim of this? Or have a similar challenge? This is the right place to seek a solution. In this post, we will look at how to remove device supervision from any iOS device, whether iPhone or iPad. Read on, as we explore our guide!
Prior to discussing the solutions to deactivate device supervision on your iPhone or iPad, a brief on what iPhone device supervision is would be helpful.
iPhone device supervision is a security control system tucked into an iOS device to help track or monitor all activities executed on it. The function of this system also extends to restrictions from using certain apps or surfing specific websites with the device.
This security control system finds application in nearly all sectors with educational institutes and business organizations topping the list. Parents also employ the services of iPhone device supervision to monitor their wards.
Here are some of the benefits of activating the device supervision feature on your iPhone or iPad:
If you value privacy, then you should consider removing device supervision from your phone. The next section of this post will focus on how to bypass or remove device supervision from the comfort of your home.
Just as you activated the device supervision feature using a configuration profile with a passcode, you can also disable it using the corresponding passcode. However, you must have the correct passcode at hand.
If you have this at hand, navigate to the Settings panel on your iPhone and apply the stepwise guide down here to remove device supervision from your iPhone or iPad:
Remove Device Supervision from iPhone/iPad with Passcode
Most users don’t have a password when they want to remove device supervision from iPhone/iPad, and that’s when way 1 is not for you. Then at this time your savior is AnyUnlock – iPhone Password Unlocker.
AnyUnlock is one of the most sophisticated iPhone/iPad unlockers designed to help you rescue your device from any form of security challenge you may come across. It handles device supervision, also known as MDM without compromising your system.
AnyUnlock helps you remove device supervision without requesting any passcode. With the built-in security unlock algorithm, this highly professional and meticulous software can easily connect and communicate with your iOS security system to bypass MDM. It doesn’t matter whether or not the device is supervised locally or remotely, you can bank on this iOS unlocker to handle the situation.
Step 1. Free download the latest version of AnyUnlock on your computer > Connect your iOS device to the computer > Click on the Bypass MDM mode in the middle of the welcome page.
Bypass MDM Overview
Step 2. Connect your iOS device via a USB cable. You may need to enter the password to unlock the device when connected. And choose Remove MDM mode and click on the Start button.
Remove Local Device Management on your iPhone/iPad
Step 3. Here, tap on the Remove Now option.
Click on the Remove Now Button
Step 4. AnyUnlock will start to remove local device management automatically. Please wait patiently. Meanwhile, please keep your device connected during the removal process. When it is done, you can see the Removed Successfully interface below.
Local Device Management Remove Successfully
With the Apple-designed MDM bypass companion, Configurator 2, you can easily activate and deactivate your iPhone or iPad from device supervision at no cost fee. This tool rescues your iPhone/iPad from MDM/device supervision, giving you full control over the corresponding device. It works for all iDevices and connects with only macOS computers.
However, prior to using this Configurator 2 tool, you must backup your device to avoid data loss. When you use Configurator 2, all content and settings stored on your iPhone/iPad are automatically wiped.
If you’ve successfully moved or exported your data to another safe storage, and have Mac, follow the steps below to remove device supervision from your iPhone or iPad via Configurator 2:
Remove Device Supervision Using Configurator 2
Select Erase All Content and Settings
Confirming whether or not device supervision is activated on your iDevice, whether iPhone or iPad is super easy. If you own a device running on iOS 10 or later, just head to the Settings panel, and check if there’s a supervision message at the top of the screen. Should you find a message, then the iPhone or iPad is supervised.
No!
Even though device supervision is programmed to track all the activities or operations executed on your iPhone or iPad, it doesn’t extend to your browsing history. So your browsing history and chat is safe while using a device with MDM enabled on it.
Removing device supervision from any iPhone or iPad just got easier than ever now that you have the tutorial guide above at hand. We’ve revealed the 3 simple ways to bypass device supervision on an iDevice, kindly apply the solution that’s best for you.
AnyUnlock is our most preferred solution from the guide. The software handles device supervision on any iPhone or iPad model with high accuracy and precision. It works without compromising your data or the iOS. Just download AnyUnlock and have a try >>
