Recently, many users find that iPhone requires passcode after restarting. This is frequently occurs when users bought a second-hand iPhone and perform a factory reset. If you’re the one who face the same issue, please continue scrolling to figure out how to resolve iPhone requires passcode after restarting issue even if you don’t have a passcode.
What to do if iPhone requires passcode after restarting? Don’t worry, AnyUnlock can help you unlock iPhone if you perform a factory reset but forgot screen passcode after restarting.
When your iPhone restarts, you will be asked to enter your passcode to unlock the device. This process often confuses many users, especially if they are used to quickly unlocking with Face ID or Touch ID. This is a security measure implemented by Apple to ensure that your device remains secure after the restart.
In this post, we will provide you with several solutions to solve “iPhone requires password after restart” or “iPhone requires password after restart but I don’t have it”.
iPhone Requiring Passcode after Restarting
There are many reasons why your iPhone asks for a passcode after reset. The most common reason is that the previous user’s iCloud account is connected to the device. Besides, learn other possible causes below.
If you get an iPhone as a gift from a friend, you are the second person to use the same device. Thus, after you perform a factory reset on your iPhone, you may be required to enter a passcode when it restarts. In this section, we collect several methods to fix the ‘iPhone requires a passcode after restarting‘ issue. Continue reading and you can access your iPhone again on your own.
This situation can be resolved with the help of the “trying default passcode” method if you don’t have a passcode before. The complete procedure is given below.
Many users accept that typing the default passcode works for them. However, the user must go for the default passcode that is given below. Normally, the default passcode for iPhone involves:
For 4 digit default passcode: 1234 or 0000
For 6 digit default passcode: 123456 or 000000
There are also several disadvantages of this method. Check out all that is given below.
If the user needs to completely wipe the device, he can check the iPhone’s IMEI or MEID number. Then the user needs to contact the salesperson. He will help you contact the previous owner of the iPhone and feedback on your relevant account information for the device.
If you don’t remember your passcode after your phone restarts, you can use Find My iPhone to unlock it from another device.
Steps:
If you fail to unlock your iPhone after restarting with the above method, you are highly recommended turn to some useful iPhone passcode unlocking tools. AnyUnlock is a professional iPhone unlocker designed to unlock any locked iPhone without knowing the password.
No matter if you are locked to an iPhone’s screen passcode, Apple ID, iCloud activation lock, MDM restriction, SIM lock, screen time, or iTunes backup, you can free download and try AnyUnlock to get rid of these locks.
Despite unlocking iOS passwords, AnyUnlock can also manage the passwords for you. You can use it to locate the password stored on your device, view all passwords on iPhone at once, and even export the passcodes you want. All in one click. Let’s see how can you unlock an iPhone with AnyUnlock.
Step 1. Download and install AnyUnlock on your computer. It is available for both Windows as well as Mac machines. Launch the app when it is fully installed on your computer. On the main screen, click on Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Click Start and hit the Download button to download the firmware for your iPhone model.
Get a Matching Firmware
Step 3. When the firmware is downloaded, click on the Unlock Now button to start unlocking your iPhone.
Tap on Unlock Now to Continue
Step 4. The following page will appear when the passcode is removed from your iPhone.
iOS Device Unlocked Successfully
1. Why is my iPhone asking for a 6 digit passcode after restart?
After restarting, your iPhone asks for a 6-digit passcode as a security measure. This is required because the device’s encryption keys are reloaded after a reboot, and biometric authentication methods like Face ID or Touch ID are temporarily disabled. The passcode is necessary to re-establish the encryption keys and ensure secure access to the device.
2. How do I fix my iPhone after too many passcode attempts?
If an iPhone has been disabled due to too many incorrect passcode attempts, it can be restored through recovery mode using a computer. This process involves connecting the iPhone to a computer, launching iTunes (or Finder on macOS Catalina and later), and following the prompts to restore the device. Restoring the iPhone will erase all data on the device, so it is necessary to have a backup to restore the data afterward.
3. What happens after 10 failed passcode attempts on an iPhone?
After 10 failed passcode attempts, if the “Erase Data” option is enabled in the settings, the iPhone will automatically erase all data on the device. This feature is designed to protect sensitive information in case the device falls into the wrong hands. If “Erase Data” is not enabled, the iPhone will remain disabled and require connection to iTunes (or Finder) to be restored.
In this article, we discussed the iPhone requires a passcode after restarting issue and the ways to fix this problem. This has come out after a lot of research by experts. AnyUnlock should be the best choice to unlock an iPhone during restarting. Download AnyUnlock to fix your problem now.
