5 Best iPhone Password Cracker [Full Review]
Have you ever tried to unlock your iPhone but forgot its passcode? Sounds like a nightmare? As iPhones have tight security systems, it might be difficult for you to unlock your device without remembering your passcode. Here, we’ll introduce top 5 iPhone password crackers that can help you to unlock your iPhone within minutes.
Author Avatar Joy Taylor Last Updated: Jul. 24, 2024
AnyUnlock – Crack iPhone Without Password
Forget iPhone password? AnyUnlock – iPhone Password Unlocker helps crack any iPhone passcode for you, like screen passcode, Apple ID password, screen time password, SIM lock, etc. Free download it now to unlock your iPhone without a password.
iOS users always set a password to increase the security of iPhone. But what if you are unable to remember its password? This might be pretty irritating, when you forget the password of your iPhone on a working day, you may wonder if it’s possible to crack into iPhone without password.
One of the flaws with iPhone is that it is quite easy to lock. In some cases, it is also possible that if you buy a used iPhone, it will have the activation lock turned on. Or, your iPhone can be SIM locked if you purchase it in one country and move to another. There are a variety of situations in which your iPhone may get locked. Luckily, cracking iPhone passcode allows you to access your device again. So, how do you crack iPhone password? Here are the top 5 iPhone password crackers to help you unlock your phone. To find the one you require, continue reading.
Can iPhone Passcode Be Cracked?
YES! As it is difficult to access an iPhone without a passcode, though, people will a password cracker app for iPhone to unlock their devices when forgetting the passcode. iPhone users typically create passwords and/or passcodes to secure their confidential information from unauthorized access. However, if you forget it or it gets changed accidentally until you conduct the iPhone password crack, you will not be able to use your iPhone as you were using it earlier.
It is possible to crack an iPhone without a passcode, only by using the iPhone password cracker. It is important to highlight, though, that if you unlock your iPhone without a passcode, the passcode will be removed, but all the data on the phone will be lost. Thus, you should use iPhone data recovery tools to recover your photos, videos, contacts, files, and text messages.
Here are the top 5 iPhone password crackers that can help you to unlock your phone. Choose the one according to your convenience of use.
Top 1. AnyUnlock – Crack iPhone Without Password
To assist iOS users who forgot the passcode to access their device, we’d like to introduce the most popular iPhone unlocker to you first – AnyUnlock. It is a professional password cracker for iPhone/iPad/iPod and has been widely praised and recommended for its powerful and quick iOS unlock solutions. It can assist all iOS users in removing various passcode locks, such as screen passcode, Apple ID, MDM lock, iCloud activation lock, iTunes backup password, screen time passcode, SIM lock, etc.
Key Features of AnyUnlock:
  • Removes all kinds of screen locks, whether it is numeric code, alphanumeric code, finger touch, or Face ID.
  • You only need to tap the buttons in order, and the whole unlocking can be easily completed within 3 steps.
  • It can also be used to unlock Apple ID, bypass MDM, remove iCloud activation lock, etc. in just simple steps.
  • You can simply find and see all of the passwords of your iPhone that are stored on your iOS browser so that your device never gets locked again.
Pros
  • No more than 3 steps. You can get into your iPhone at once.
  • Provide clear instructions for each step and button-clicking is enough. Anyone can operate.
  • Supports all iPhone models and iOS versions.
  • Works on both Windows and Mac.
Cons
  • Removes all data stored on your iPhone, after unlocking your iPhone.
Steps to use AnyUnlock:
Step 1. On your PC or Mac, download and install AnyUnlock, then select the Unlock Screen Passcode option from the main screen.
Choose Unlock Screen Passcode
Step 2. To receive the iOS firmware, hit the Start button and afterward hit the Download button as below.
Get a Matching Firmware
Step 3. When the download completes, press Unlock Now.
Tap on Unlock Now to Continue
Step 4. Your iPhone will be unlocked automatically in minutes.
iOS Device Unlocked Successfully
Top 2. FoneLab iOS Unlocker
Unlocking an iPhone without its password is a difficult task. As the security feature of the iPhone is almost impossible to get breached. But in some conditions, where you forgot the passcode of your iPhone, you need to look for other options that can unlock your iPhone. Fonelab iOS Unlocker is a very useful iPhone password cracker tool that can be used in such cases. And you can learn more about the features of this iOS password cracker.
Key Features of FoneLab iOS Unlocker:
  • Unlock different iPhone passcodes such as Face ID, Touch ID, passcode, etc.
  • Removes all kinds of iPhone locks.
Pros
  • Allows you to gain access to an iPhone that is broken, unresponsive, or disabled.
  • Without a password or two-factor authentication, you can unlock an iPhone.
  • Works on Windows and Mac.
Cons
  • Removes all data stored on your phone.
Top 3.  Joyoshare iPasscode Unlocker
Joyoshare is also a recommended password cracker app for iPhone. As an iPhone password cracker, it can unlock four different kinds of iOS device screen locks. You can unlock an iPhone in just three simple steps by using Joyoshare iPasscode Unlocker for any kind of iPhone lock, whether it is the password, passcode, FaceID, or finger touch ID. And here are the key features of this password cracker iPhone.
Key Features of Joyoshare iPasscode Unlocker:
  • Can be used for any kind of iPhone lock.
  • Unlocks a phone in just 3 simple steps.
  • Compatible with all the iPhones.
Pros
  • Can clear any passcode on any model of iPhone.
Cons
  • You need to connect the device to the computer as it does not respond automatically.
  • Installation of Joyoshare is a little bit complex.
Top 4. Dr.Fone – Screen Unlock (iOS)
Dr. Fone – Screen Unlock is an iPhone password cracker that can easily be used to remove any kind of iPhone lock, whether that is a screen lock, Apple ID, etc. any of the other locks. It is a very quick and user-friendly iPhone cracker that can be used by professionals or anyone else. To learn more about this password cracker for iPhone, please read below.
Key Features of Dr. Fone – Screen Unlock (iOS)
  • Can unlock all kinds of locks, such as Apple ID, MDM, screen lock, etc.
  • Removes iCloud lock as well, instantly.
Pros
  • Can work on any iPhone.
  • Easy to understand and use.
Cons
  • Deletes all the data on an iPhone.
  • Can work only on iPhone 11 or earlier versions.
Top 5. TunesKit iPhone Unlocker
To make iPhone password crack, you cannot miss TunesKit iPhone Unlocker. It is one of the most prominent iPhone password crackers. It is easily unlocked by any kind of lock of an iPhone, whether that is a numeric screen passcode or other types of screen locks of an iPhone. You can unlock your iPhone using this password cracker app for iPhone in a few simple steps.
iPhone Unlock Software - TunesKit iPhone Unlocker
iPhone Unlock Software – TunesKit iPhone Unlocker
Key Features of TunesKit iPhone Unlocker
  • Can unlock any iPhone in a small time.
  • It can also fix the disabled iPhone with iCloud or iTunes.
Pros
  • Can be used by anyone.
  • Can unlock any kind of iPhone, and lock on the iPhone.
Cons
  • Deletes all data on the phones.
  • Removes the Apple ID running on your iPhone.
Here, we have discussed the top 5 iPhone password crackers to help you unlock your phone. And if you ask for the best password cracker for iPhone, it must be AnyUnlock due to its easy operation, high unlocking speed, and super compatibility. Therefore, you can try AnyUnlock first to crack into iPhone password.
