Have you wondered what you should do if your iPhone passcode is expired? Do you still have access to your iPhone if this ever happens? Find your answers in the article below.
On your Apple device, have you ever seen a notification prompt that says, “Passcode Expired: Your iPhone unlock passcode has expired?” This message has been confusing for many users, as you may wonder: isn’t the iPhone passcode supposed to be valid forever? How could it be expired?
Further Reading: How to Change Apple ID Password and Lock Screen on iPhone >
The answers are in the sections below. In this article, you will learn about why your iPhone passcode expires, how to fix this problem and unlock your iPhone, and how to make your passcode longer and safer.
To understand why your iPhone notifies you about passcode expiration, you need to understand the following two questions:
iPhone passcode should be valid for your device as long as you don’t change it. Therefore, if your iPhone tells you that the passcode is expired, it’s most likely caused by some third-party apps or email sign-ins. Many apps or email accounts will remind you to change your password occasionally for security reasons. On your iPhone, these apps or accounts use the iPhone passcode for access control. Therefore, when it’s time to update passwords for them, they will prompt the “Passcode Expired” notification.
In some other scenarios when you are using a work phone, there may be configuration profile settings that require passcode updates. In this case, you need to contact your IT department for support on this issue.
iPhone passcode is a crucial security verification for accessing your device. On your iPhone, you will be using this passcode to access all kinds of private information, such as emails, personal notes, financial data, etc. Therefore, constantly updating your iPhone passcode provides more protection to your device, as other people won’t easily know your passcode. This action efficiently prevents information leaks.
If your device stays on this passcode expired page, then a little is very annoying. You surely want to solve this problem quickly. Luckily, this section will teach you how to fix this problem. Let’s check them out!
The easiest way to solve this problem is to change the expired passcode on your iPhone. Updating your iPhone passcode is easy in Settings and here’s how:
Now, your expired passcode is updated, and your apps should be saved from loading.
Change Passcode in Settings
If for some reason, you can’t change your passcode in Settings, you can reset passwords with iCloud. With iCloud, you can erase all content and settings on your iPhone, including the passcode. You can then reset a new passcode on your iPhone after the erase.
However, if you don’t have a proper backup, there may be data loss during this process. So, you need to be careful to check the backup of your iPhone before proceeding with the following steps. Sign in to your iCloud account and follow the steps below.
Erase iPhone via iCloud
After the erase is complete, go to Settings to set up a new passcode on your iPhone.
If you want to reset your password to fix the passcode expired problem, but you forgot your previous password. Then AnyUnlock is here for you. As an all-in-one iPhone unlocker, it can help you remove any passcode on your iPhone easily and quickly.
Step 1. Free download AnyUnlock and launch it on your computer. Then select Unlock Screen Passcode option from the homepage.
Choose Unlock Screen Passcode
Step 2. Connect your iPhone to a computer with the USB cable > Tap the Start Now button.
Click Start Now Button
Step 3. After device information is detected, click the Download button to download the firmware.
Get a Matching Firmware
Step 4. When the firmware is downloaded, click Unlock Now and AnyUnlock will start the unlocking process automatically. Please do not disconnect your device until it restarts.
Tap on Unlock Now to Remove Screen Passcode
Step 5. When the recovery process is completed, you will see the Screen passcode removed successfully interface as below.
If you don’t happen to have a recent backup or if you don’t want to erase your iPhone, another method you could try is to update iOS to the latest version via iTunes. This update may help you resolve the passcode expiration issue.
Here’s how to update the iOS version via iTunes:
Check for Update
This process may take a while, but your iPhone will be updated to the latest version of iOS. Afterward, check to see if this update resolves your passcode expiration issue.
When neither of the above methods works for you, force restarting your iPhone is always a last resort. It’s not guaranteed to work, but it never hurts to try. The ways to force restart an iPhone differ based on different versions of an iPhone. Find out how to force restart your iPhone below:
For iPhone X, 11, or 12:
For iPhone SE (2nd generation), 8, 7, or 6:
For iPhone SE (1st generation), 5, or any version earlier:
Restart Different Modes of iPhone
When you fix the passcode expiration issue and successfully get into those apps or accounts, it’s important to keep in mind that these apps or accounts may contain sensitive information that you want to keep private. Therefore, making your iPhone passcode longer and harder to guess becomes essential.
You can simply make your iPhone passcode longer by selecting the Custom Alphanumeric Code format during the passcode setup. With this format, your passcode will be a combination of numbers and letters and will be in any length you want.
Choose Custom Alphanumeric Code as Passcode Format
The passcode is an important protection for your devices. Therefore, it’s crucial to make it complex for others yet easy to remember for yourself. It’s also recommended to update your passcodes occasionally to add more security for your devices. But even if you accidentally forget your screen password, don’t worry, AnyUnlock can help you in the first place! If you have any other relevant questions about your passcodes, please feel free to comment below.
