Explore 4 methods to unlock your iPhone 7/8 iCloud activation with ease, you can use AnyUnlock, DNS, online tool… Read details in this article!
Although Apple has launched the latest 15 series, many people still choose to use iPhone 7 and 8 because they offer sufficient performance, robust design, and reasonable pricing. They retain traditional interfaces, receive the latest iOS updates, and meet basic smartphone needs without requiring frequent upgrades or replacements. However, sometimes the iCloud Activation Lock on iPhone 7 and 8 devices can be a major problem for users looking to access their phones. This guide aims to provide a comprehensive solution to perform iPhone 7 iCloud bypass effortlessly.
iPhone Activation Bypass
The iCloud Activation Lock is a security feature designed by Apple to prevent unauthorized access to an iPhone if it is lost or stolen. When enabled, this lock links the device to the owner’s Apple ID and requires correct credentials to unlock and use the phone. This can pose a challenge for buyers of second-hand iPhones who are unable to contact the original owner for iCloud credentials. In addition, for those owner who forgot their iCloud credentials or can’t access the device due to activation lock, there’s a quest to seek an unlock.
And in the following parts, we will give 4 efficient ways to tell how to enable iPhone 7/7 plus iCloud bypass.
To do iPhone 7/8 iCloud bypass, there are generally 4 ways, namely professional third-party tool AnyUnlock, DNS bypass, online tool and last, seek Apple Official for help.
AnyUnlock is one of the most popular and comprehensive iOS devices passcode unlocker. When you are stuck on the Activation Lock screen, this software would be an ideal solution to quickly solve your problem. It only takes a few minutes to remove iCloud activation lock to save you from the tedious and complicated unlock job. By using its iCloud Activation Unlocker feature, you can easily bypass iCloud Activation Lock without an Apple ID or Apple ID password.
Here’s how to easily bypass iCloud Activation Lock on your iPhone7/8. Considering the difference between Windows PC and Mac, we will discuss the exact operations in 2 guides:
How to Bypass iCloud Activation Lock on Windows PC
Step 1. First, download and install AnyUnlock. Once installed, launch the software and click on ‘Bypass iCloud Activation Lock.’
Step 2. Connect your device to the computer via USB cable and click ‘Start Now‘ in the prompt screen.
Step 3. You’ll need to jailbreak your device to allow AnyUnlock to proceed. Follow the jailbreak tutorial provided, and click ‘Next‘ once you’ve finished.
Step 4. After you click the “Next” button, you will see the interface as below. And you can view the basic info about your device. Then, please click the “Bypass Now” button.
Click Bypass Now Button
Step 5. Wait for the process to complete. Once finished, you’ll see a confirmation that iCloud Activation Lock has been successfully bypassed.
iCloud Activation Lock Is Bypassed Successfully
How to Bypass iCloud Activation Lock on Mac
Here’s how to bypass iCloud Activation Lock using AnyUnlock:
Step 1. Download and install AnyUnlock on your computer via USB cable. Run the program and select ‘Bypass iCloud Activation Lock‘ on the homepage.
Step 2. You need to connect your iOS device to the computer now, and then click on the Start Now button to the next step.
Click on the Start Now to Go On
Step 3. Then, please choose your device model and follow the instructions in the window to enter DFU mode. After entering into DFU mode, it will start Jailbreak progress.
Start to Jailbreak Your Device
Step 4. After jailbreaking is complete, click ‘Bypass Now‘ to start removing iCloud Activation Lock from your device.
Tap on Bypass Now to Start Bypassing
Step 5. Wait patiently while AnyUnlock completes the bypassing process. Once done, you’ll see a confirmation that the iCloud activation lock has been removed from your iOS device.
DNS can sometimes be used as a tool to achieve iPhone 8 Plus iCloud bypass. However, it’s not always straightforward and success rate isn’t guaranteed. Here’s how you can try it:
Step 1. Restart your iPhone 7 and on the activation screen, choose your language and country.
Step 2. Enter the following DNS server depending on your region:
Adding DNS Address
Step 3. Tap ‘Back,’ connect to your Wi-Fi network, then tap ‘Done,’ and select ‘Activation Help.’ After logging in, you should see a message confirming connection to the server.
Step 4. Tap ‘Menu,’ preview available apps, and choose one to find details about the previous owner.
If the DNS trick doesn’t work for you, another option is to use an online tool, which can be a lifesaver. Here’s how to bypass the activation lock on an iPhone 7 running iOS 11 using an online method:
Step 1. Grab your computer and fire up a web browser. Head over to the Apple iPhone Unlock website.
Step 2. Once you’re there, look for the ‘iCloud Unlock‘ link and give it a click.
Step 3. You’ll need to find your iPhone’s IMEI number. Just dial #06# on your iPhone to get it. Also, don’t forget to choose your iPhone model.
Step 4. Now, hit the ‘Remove Activation Lock‘ button and go through the checkout process to finalize your order.
Step 5. In a few days, keep an eye on your email inbox. You should receive a message from the website confirming that the activation lock has been lifted.”
If all of the above solutions fail, then you have the last resort, try to seek help from an Apple Store nearby. The experts there can provide a solution for your iCloud-locked iPhone 7 Plus.
Q1: Can I bypass iCloud Activation Lock for free?
A: While some methods like iCloud DNS Bypass are free, they offer limited functionality. Paid tools or services may provide more comprehensive solutions.
Q2: Is bypassing iCloud Activation Lock legal?
A: The legality of bypassing iCloud Activation Lock varies by jurisdiction. It’s best to consult local laws or seek legal advice if unsure.
Q3: What should I do if I forget my Apple ID credentials?
A: Use Apple’s official account recovery process or contact Apple Support for assistance in recovering your Apple ID.
Dealing with iPhone 7 iCloud bypass can be a frustrating experience, and you can try the above 4 ways! Notably, AnyUnlock is the most recommended, not only for it can achieve iPhone iCloud bypass, but also can unlock various kinds of screen passcode, Screen Time passcode, bypass MDM, etc. Try this powerful tool with your old iPhone 7/8 now!
