“I happened to find my old iPhone 6 and I’d like to check if it’s working now, but the screen lock passcode prevented me from unlocking it. How can I bypass the lock screen passcode on my spare iPhone 6?” – A user asked online.
Being locked out of your iPhone 6 can be a frustrating experience. Whether it’s due to multiple failed attempts, a forgotten passcode, or inheriting a locked device, many users need a way to bypass the screen passcode. This guide will walk you through various methods to bypass the iPhone 6 screen passcode, ensuring you can regain access to your device. While some methods may result in data loss, we will also explore options to preserve your data where possible.
Before diving into the methods, it’s crucial to understand that bypassing the iPhone 6 passcode without losing data is challenging and depends heavily on the specific circumstances. Here are some situations where users might want to bypass the passcode without data loss:
Unfortunately, most official methods involve erasing the device to remove the passcode. However, certain workarounds might help you access your data or even unlock your device under specific conditions.
One potential workaround for older iPhone models, including the iPhone 6, is Siri. This method leverages a vulnerability in iOS that can sometimes allow users to bypass the lock screen. Here’s how to do it:
Unlock iPhone with Siri
While this method can work on iOS 8 to iOS 10.1 only, you may fail to bypass iPhone 6 screen passcode with Siri if you are not running another iOS version. Don’t worry, the following methods are available to use for more devices.
Also read: How to fix “Hey Siri” not working on iPhone
To bypass iPhone 6 screen passcode, using an iPhone unlocker can be more straightforward. AnyUnlock is an all-in-one iPhone password unlocker designed to unlock various types of iPhone locks, including the screen passcode. Here’s how to use it:
Step 1. Download and install AnyUnlock on your Windows or Mac computer.
Step 2. Open the software and select the “Unlock Screen Passcode” option. Then use a USB cable to connect your iPhone 6/6S.
Choose Unlock Screen Passcode
Step 3. Follow the on-screen instructions to download the appropriate firmware for your device. It is the preparation for unlocking your iPhone 6.
Get a Matching Firmware
Step 4. Once the firmware is downloaded, click “Unlock Now” to begin the unlocking process.
Tap on Unlock Now
Once the process is complete, your iPhone 6 should be unlocked. When it restarts, you can set it up and use it as a new one.
Note that using AnyUnlock will erase all data on the device. Ensure you have a backup before proceeding if data retention is important.
Using iTunes to restore your iPhone 6 is a common method to bypass the screen passcode, but it will erase all data on the device. Here’s how to do it:
This process can take some time. Once complete, your iPhone will restart without a passcode. Restoring via iTunes will erase all your data. However, if you have a backup, you can restore your data after the process is complete.
If you have enabled Find My iPhone, you can use iCloud to erase your iPhone 6 remotely, thus bypassing the passcode. Here’s how:
Erase and Remove the iPhone from the Account
Using iCloud to bypass the passcode will erase all data on the device. Ensure you have a backup to restore your data afterward.
Bypassing the iPhone 6 screen passcode can be done through various methods, each with its advantages and disadvantages. Methods like using Siri or third-party tools like AnyUnlock offer potential solutions but may come with data loss. Restoring via iTunes or using iCloud’s Find My iPhone feature is more reliable but will erase all data on the device. Always ensure you have a recent backup to avoid data loss in such scenarios. If you find yourself locked out of your iPhone 6, try these methods to regain access and continue using your device without interruption.
