How to Fix iPhone 12 Disabled Connect to iTunes
Is your iPhone 12 disabled connect to iTunes? If yes, we will show you how to fix this problem with detailed steps.
Author Avatar Joy Taylor Last Updated: Nov. 24, 2022
Do you ever picked up your iPhone and discovered the message “iPhone is disabled” with the option to “try again in 1 minute” or “try again in 5, 15, 60 minutes?” In the worst-case scenario, the notification pops up saying that iPhone is disabled connect to iTunes.
So, what does disabled iPhone mean, and why is iPhone disabled connect to iTunes? How to unlock disabled iPhone without computerAnd how do I get my iPhone out of Disabled mode? These are the questions most people may ask when they face this situation. Don’t worry! In this article, we will discuss the reasons for this problem and show you detailed methods to fix the iPhone 12 disabled connect to iTunes issue.
Why Is My iPhone Disabled?
Many people don’t know why iPhone is disabled connect to iTunes. So before attempting to repair the “iPhone is disabled” error, it is prudent to quickly explore the causes of this problem for a better understanding.
As part of the security feature meant to protect your data, iOS immediately disables your iPhone if you enter the incorrect passcode more than five times. To be more specific, entering the incorrect passcode six times disables your iPhone for one minute.
With each incorrect passcode try after then, the timer increases. When you enter the wrong passcode ten times in a day, your iPhone is fully disabled, and you will be told that iPhone is disabled connect to iTunes.
iPhone 12 Disabled
iPhone 12 Disabled
In order to let you better understand when iPhone says disabled connect to iTunes, here we have listed the error messages displayed after each incorrect passcode attempt:
  • 6 Failed Passcode attempts: iPhone is disabled, try again in 1 minute.
  • 7 Failed Passcode attempts: iPhone is disabled, try again in 5 minutes.
  • 8 Failed Passcode attempts: iPhone is disabled, try again in 15 minutes.
  • 9 Failed Passcode attempts: iPhone is disabled, try again in 60 minutes.
  • 10. Failed Passcode attempts: iPhone is disabled. Connect to iTunes.
Then how to fix a disabled iPhone? Or how to connect to iTunes when iPhone is disabled? Below we will show you several methods to fix iPhone 12 disabled connect to iTunes problem. All of the ways can also be applied to other iPhone models. Now keep reading to learn what to do when iPhone is disabled.
What Need to Fix iPhone 12 Disabled Connect to iTunes?
If you encounter the phrase ‘Connect to iTunes’ or, with iOS 14, ‘Connect to a Mac/PC,’ you can get into your iPhone, but you will lose all data as part of the essential recovery process. You did back up, didn’t you? If it’s any consolation, you’ll be able to recover the data from your most recent backup. If not, make a backup of your data in case you lose it. But if you encounter the iPhone disabled connect to iTunes iPhone 12 problem, to fix it, what do you need? Here they are:
What you need:
  1. A computer: If you don’t have access to a Mac or a PC, you may need to visit the Apple Retail Store or a Mac reseller to use one of their devices.
  2. Lightning to USB cable: This could be an issue if your Mac only has USB-C ports and your iPhone cable only has USB-A… In such a situation, an adapter or a USB-C to lightning cable will be required.
Fix iPhone 12 Disabled Connect to iTunes in Two Ways
If your iPhone 12 is disabled connect to iTunes, and use the two effective methods listed below. But you should remember that these two ways will erase all the data on your device. Ana the steps may be a bit complicated. If you want a more concise and quick way, you can go directly to the next part. Now let’s see how to fix the disabled iPhone.
Method 1. Restore Your iPhone with iTunes
How do you fix a disabled iPhone 12 when it says connect to iTunes? The first method you may think about is to use iTunes. It works, of course. But this way will require you to wipe all of the phone’s data. If you made a backup before being locked out of the device, this shouldn’t be a problem because you can restore your iPhone with the backed-up data after resetting the device. Now if you do not know how to restore a disabled iPhone, just follow the steps below to iPhone 12 disabled connect to iTunes.
Step 1. Connect locked iPhone to iTunes to your computer via a USB cord and click on the Summary tab.
Step 2. Once the backup is created, tap on Restore.
Step 3.  If Find My iPhone was previously enabled, you would need to disable it before proceeding with the process.
Turn off Find My iPhone from iCloud
Step 4. If it is already turned off, iTunes will ask you if you wish to restore your iPhone to factory settings.
Step 5. Finally, click on Restore and Update, and you are done!
Click on Restore and Update
This method will allow you to resolve the iPhone’s disabled error. iTunes will now download new software and repair your iPhone without the need for a passcode. You will be able to use your device after setting up the new passcode.
Method 2. Restore Your iPhone with iCloud
How do you unlock a disabled iPhone 12 without iTunes? If you’ve activated the “Find My iPhone” option on your disabled iPhone, you can also use iCloud to fix iPhone 12 disabled connect to iTunes issue. Here is the step-by-step guide on how to fix iPhone is disabled connect to iTunes with iCloud.
  1. Navigate to icloud.com/find and sign in with your Apple ID.
  2. Now tap on All Devices in the upper right-hand corner of your browser window.
  3. Select the device you want to wipe. To remove your device and its passcode, click Erase.
Tap on All Devices in iCloud
Following these actions, your iPhone will be reset and returned to the factory reset stage. You can now re-register your iPhone with a new password.
Fix iPhone 12 Disabled Connect to iTunes in One Click
If the previous methods didn’t work, how do you unlock an iPhone that is disabled and says connect to iTunes? Don’t be afraid. AnyUnlock – iPhone Password Unlocker is here to help. No matter it is that you’ve forgotten your iPhone’s passcode, the iPhone has been disabled due to multiple failed tries, or Face ID/Touch ID isn’t working for no apparent reason, AnyUnlock can help you right away.
So, here are some of its key features that you might find interesting:
  • One-click unlock any screen locks, such as numeric code, alphanumeric code, Touch/Face ID, etc.
  • Unlocking a disabled iPhone only takes a few minutes. No long wait.
  • Other unlocking issues, such as removing Apple ID and encryption settings in iTunes/Finder, can also help you out.
  • Compatible with all iPhone models, including iPhone12 and iPhone 13.
Now, download AnyUnlock, and let’s look at the steps of unlocking a disabled iPhone 12 with AnyUnlock to solve the iPhone 12 disabled connect to iTunes problem:
Step 1. Launch AnyUnlock on your computer. Connect your locked iPhone via USB cable > Click Unlock Screen Passcode as below.
Choose Unlock Screen Passcode
Step 2. Just click the Start Now button to continue. You may check the Supported Scenarios on this page.
Click Start Button to Remove Screen Passcode
Step 3. Then click the Download button to get the iOS firmware, which is for unlocking the screen passcode. When the firmware is downloaded, click the Unlock Now option.
Tap on Unlock Now to Continue
Step 4. Just in a few minutes, you will get the Screen passcode removed successfully page as below.
iOS Device Unlocked Successfully
Fix iPhone 12 Disabled Connect to iTunes [Video Tutorial]
Watch this video to fix iPhone 12 disabled connect to iTunes issue.
How to Unlock iPhone 12 with iTunes?
Unable to unlock iPhone 12? You can also unlock your device by connecting iPhone 12 to iTunes if your iTunes is available or after you’ve resolved the iPhone 12 disabled connect to iTunes issue. But please remember to back up your data because this method will wipe all your data. Here is how to unlock iPhone 12 with iTunes.
Step 1. Connect your iPhone to iTunes with a USB cable.
Step 2. Click on the iPhone icon at the top of the screen.
Step 3. In the left panel, choose Summary. And then you will see the Back Up Now button. Tap on it.
Step 4. Click on the Restore iPhone button. And you need to click Restore again to confirm your behavior. After that, you can unlock your device.
In addition to the above methods, we also collected some related questions that people often ask, and answered them one by one below.
Why my iPhone won’t connect to iTunes?
There are many reasons for iPhone not connecting to iTunes issue. The most possible reason is that you may forget to tap “Trust This Computer” alert when you connect your device to iTunes on PC. If you have clicked, please check the connection of USB cables.
What to do when iPhone won’t connect to iTunes?
If you have clicked Trust This Computer and ensured the stable connection between your iPhone and computer, then there may be some issues with your iTunes. In this case, you need to resort to a professional iTunes repair tool to fix iPhone not connecting to the iTunes issue.
How to put iPhone 12 in recovery mode while disabled?
Even if your iPhone 12 is disabled, you can still put it into recovery mode with the following steps:
Long-press the Power button until to turn off your iPhone > Connect iPhone to computer with a USB cable > Press and hold the Volume Down button. Then you will see the recovery mode screen.
That’s it! We’ve seen a variety of solutions to the iPhone 12 disabled connect to iTunes problem. If you want to unlock a disabled iPhone without iTunes easily and quickly, AnyUnlock is obviously the best option. With no effort, it can assist you in regaining access to your iPhone in a far more effective manner. So just download AnyUnlock now and unlock your disabled iPhone 12!
