Is your iPad displaying the iPad unavailable screen? If yes, don’t worry! In this article, we have discussed the reasons for this issue as well as some proven ways to fix iPad unavailable.
What to do if my iPad says iPad unavailable? Don’t worry! Free download AnyUnlock, an one-stop iOS unlocker, to bypass the iPad unavailable screen in 1 click, even without passcode. No technical requirements. Support all iPad and iPhone running iOS 5 and above.
If you receive the iPad unavailable message, you might have entered the wrong passcode on your iPad several times. This means that your iPad will get locked, and you won’t be able to enter the passcode for several minutes or hours.
iPad Unavailable Message
This can be frustrating, especially if you want to use your iPad for something instantly or you have a wailing kid waiting to get back to their game. Then, how to unlock iPad unavailable? In this article, we have put together 4 proven ways to solve this problem. So, let’s get started! But before we get to the solutions, let us explain why iPad says unavailable.
If you get the “iPad unavailable” message on the screen, it means you enter the wrong passcode several times consecutively and you will get locked out of it for a whole minute for unauthorized use
Similarly, the more times you attempt to enter the wrong passcode, the longer it will remain locked. And at one point, you will find iPad unavailable permanently and it will disable the option to enter the passcode for good. Besides, sometimes iPad says iPad unavailable after factory reset as well.
To summarize, iPad unavailability can bring different degrees of inconvenience and trouble to personal, work and life, especially the higher the degree of dependence and frequency of use, the greater the impact it may bring. Then, iPad unavailable how to fix? If you want to avoid all this drama, just read on and we have 4 proven ways to fix the iPad Unavailable issue.
What to do if my iPad says unavailable? AnyUnlock is exactly what you need. As its name suggests, it is a professional iPhone unlocker specially built for iOS devices, and can help you unlock the iPad unavailable screen immediately, even if you forgot the correct password. And anyone can use this tool with ease because of its easy operation. Besides, AnyUnlock can also quickly unlock any other iOS locks, such as Apple ID, iCloud activation lock, SIM card, iTunes encrypted backup, MDM lock, etc. Below are some key features of AnyUnlock.
Now you can free download the latest version of AnyUnlock and follow the steps below to fix the iPad unavailable issue and unlock your device.
Step 1. Launch AnyUnlock on your PC/Mac, and select the Unlock Screen Passcode from the interface.
Choose Unlock Screen Passcode
Step 2. Connect your iPad to your PC with a USB-to-Lightning cable, and click Start Now.
Click Start Now Button
Step 3. Select your iPad model and iOS version from the drop-down menu > click Download Now to get the firmware. Then click Unlock Now.
Tap on Unlock Now
Step 4. Once the screen lock passcode is removed, your iPad will reset, and you can set it up as new.
iPad unavailable how to reset? If you don’t want to use a third-party app, you can also rely on the Erase iPad feature to fix iPad unavailable. It is also easy and convenient to use, which allows you to bypass the iPad unavailable message directly from your iPad without computer or other tools. Here’s how to fix iPad unavailable without computer.
Step 1. When you see the “iPad Unavailable” message on your screen, click on the “Erase iPad” option at the bottom of the screen.
Click on Erase iPad Option
Step 2. You will get a prompt to “Erase All Content & Settings.” Click “Erase iPad” to confirm your selection.
Step 3. Enter your Apple ID and password to sign out of your account. This will erase your iPad; you can set it up as new when it restarts.
How do I fix iPad unavailable with no erase option? Another way to fix iPad unavailable error is by restoring it in recovery mode via Finder or iTunes. However, you must have a macOS PC or a Windows PC with the latest version of iTunes. This method can remotely restore your iPad through iTunes or Finder on your PC. Now, let’s see the steps to fix iPad unavailable.
Step 1. Power off your iPad and put it in Recovery Mode.
Step 2. Now connect your iPad to your PC, and launch Finder or iTunes. You will see a pop-up box with 3 options. Click on “Restore.”
Click on Restore
This option will restore your iPad to its factory version, and you can set it up as new.
How do I unlock an unavailable iPad without iTunes? You can also fix iPad unavailable through the iCloud Find My feature. Like all other methods discussed earlier, this is also relatively easy; however, it will only work if you remember your Apple ID and password and your iPad has the Find My feature enabled. And below are the steps to bypass the iPad unavailable screen.
Step 1. Launch the Find My app on another iPhone signed in with the same Apple ID as your iPad.
Step 2. Click on “Devices” and select your iPad.
Step 3. Click on “Erase this Device.”
Click on Erase This Device
This will fix the “iPad Unavailable” issue by resetting your device.
Now that you know the 4 proven fixes to resolve the iPad security lockout issue, let’s answer some related common queries.
Hope you have fixed iPad unavailable with the above methods. And we also list some other related questions below and answer them one by one.
Q. How to reset an iPad that says unavailable?
If you see the “iPad Unavailable” message on your iPad, you can reset it via iTunes, iCloud Find My feature, by erasing it using the “Erase iPad” feature on the screen, or by opting for a third-party app like AnyUnlock to reset it for you.
Q. How long does iPad unavailable last?
The “iPad Unavailable” option lasts depending on how often you have attempted to unlock it with the wrong passcode. For instance:
Numerous attempts to unlock an iPad with the wrong passcode can trigger the iPad unavailable error. Fortunately, you can use these 4 proven methods to fix this issue. And among these methods, AnyUnlock is obviously the best choice for you, because it can unlock your iPad and fix iPad unavailable with only simple clicks and a few minutes, so you can access your iPad immediately. Why not try AnyUnlock for free first?
