How to Unlock a Disabled iPad with/without iTunes
Have you forgotten your iPad’s passcode, or you see a message saying iPad is disabled connect to iTunes and are looking for ways to unlock the disabled iPad? This article will show you how to unlock a disabled iPad with or without iTunes.
Author Avatar Joy Taylor Last Updated: Sep. 26, 2022
When I switch on my iPad, the screen says – iPad is disabled connect to iTunes, but when I do, I get a pop-up screen saying my iPad is locked and entering the passcode, but the screen doesn’t change.
iPhone/iPad Locked Connect to iTunes
It is not uncommon for a gadget or electrical device to become inoperable to its owner. It is typically one of the most frustrating and perplexing emotions for any user to suddenly realize that iPad locked connect to iTunes when it was working well only a few minutes before. It’s much more depressing when you have no idea why it was disabled or when you don’t know how to unlock your disabled iPad.
This can happen to anyone, whether by chance or because someone else is trying to read your messages. However, disabling your iPad can be a significant issue, mainly if you are unfamiliar with doing so.
As a result, in today’s article, we’ll learn something new that will allow you to unlock a disabled iPad in a matter of minutes.
What Happens If Your iPad Says Connect to iTunes?
You have a disabled iPad and are utterly unable to use it. You’re being told to connect to iTunes, but you’re not sure why. In this section, we’ll explain why your iPad is disabled and show you how to cure the problem permanently!
iPad Is Disabled Connect to iTunes
If you enter your passcode incorrectly too many times in succession, your iPad will be disabled. If you input an incorrect iPad passcode too many times in succession, the following will occur.
  • Up to 5 attempts, you’re good!
  • After six attempts, your iPad will be deactivated for 1 minute.
  • After seven attempts, your iPad will be disabled for 5 minutes.
  • After eight attempts, your iPad will be disabled for 15 minutes.
  • After nine attempts, your iPad will be disabled for an hour.
  • After ten attempts, your iPad will display the message “iPad is disabled.” Connect to iTunes.”
You might be asking yourself, “Wait a minute! I didn’t mistype my passcode ten times!” That’s most likely correct. Frequently, iPads are disabled because little toddlers who enjoy touching buttons or curious acquaintances who want to read your texts and emails input the wrong passcode ten times in a row.
You might be wondering, “Can I Unlock My iPad?” Yes, it is conceivable that you will only need to connect your iPad to iTunes and restore it. Below are the easy steps on how to unlock your disabled iPad using iTunes.
Restore iPad via iTunes
  1. Pick up the just-disabled iPad and attach it to your computer using the appropriate lightning USB connector.
  2. While your iPad is connected, launch the iTunes app on your computer. The iTunes tool should recognize your device and display the device name and other pertinent information about your iPad. If it does not recognize your iPad instantly, reconnect it with a different USB cord.
  3. After successfully completing your backup process, you may now proceed to unlock the disabled iPad. You will be directed to a restore setup screen when you click the Restore iPad button, which is situated on the main screen interface under your device’s name and information.
Now, your iPad would begin to restore using your backup files, and you would be able to unlock it.
To recover and unlock your iPad, you must first sync it to your computer.
How to Fix iPad is Disabled Connect to iTunes and Won’t Connect to iTunes
It is not difficult to unlock an iPad that has been disabled. To unlock the iPad, you can use any of the methods given above. Be cautious when implementing the approaches, as a single mistake might lead to many other complications.
Fix 1. Unlock Disabled iPad without iTunes – Find My iPhone
Apple introduces a “Find My iPhone” function to iCloud, allowing you to locate, lock, and reset any iDevice with the same Apple ID to factory settings if lost or stolen. Given that you can’t use iTunes to unlock a disabled iPad, you can envision your device as the missing device and use a remote erase to unlock it.
The only cons to this feature are that you must first enable Find My iPhone on your iPad before being disabled. If you believe you did not turn it off (it is enabled by default), follow the steps below to wipe and unlock your iPad without the use of iTunes.
Unlock Disabled iPad via Find My iPhone
  1. First, on your computer, open www.icloud.com/find in the web browser.
  2. Now, log in with your Apple ID and Password linked to your iPad.
  3. Choose your iPad from the list of All Devices to see all of your Apple devices.
  4. Select Erase iPad and follow the on-screen prompts to reset the device and remove the passcode.
  5. Once the iPad has been unlocked, you have the option of restoring it from a backup or starting over again.
Fix 2. Unlock Disabled iPad without iTunes in Simple Clicks
The second method for unlocking a disabled iPad without iTunes is to use AnyUnlock to unlock the iPad screen passcode. AnyUnlock – iPhone Password Unlocker enables you to unlock Apple ID, iPhone lock screen, iTunes backup password, and Screen Time passcode. Furthermore, the software allows you to view all passwords saved on your iOS device and even export them to other password management apps.
AnyUnlock – iPhone Password Unlocker includes the following features:
  • Unlock iPhone lock screen, Apple ID, MDM lock, iTunes backup password, and Screen Time passcode
  • Passcodes may be removed in three easy steps, with no technical skills required.
  • Advanced technology that provides the highest success rate.
Step 1. Download and launch AnyUnlock on your PC and select Unlock Screen Passcode mode.
Choose Unlock Screen Passcode
Step 2. After entering the Recovery Mode using the steps shown on the interface, Anyunlock will recognize your device model automatically. Select the firmware version from the list and then click the Download button.
Get a Matching Firmware
Step 3. AnyUnlock will immediately unlock the screen passcode when you click the Unlock Now button. During the unlocking procedure, please keep your device linked to the computer via a USB cord.
iOS Device Unlocked Successfully
Passwords and passcodes help to keep our devices out of the hands of unauthorized users. However, if you enter your own iPad’s passcode incorrectly too many times, you will be the one who is locked out.
If your iPad indicates that it is disabled, it implies you are completely locked out. At this point, the only option to re-enable your iPad is to either wait (assuming you’ve been given a time limit) or reset it via your PC. If you don’t remember your password, your only choice is to reset the iPad.
To summarise, unlocking a disabled iPad is not difficult if you choose the right approach and follow the relevant procedures. We hope that this guide will assist you in getting the most out of your iPad.
AnyUnlock – Unlock iPad/iPhone Passcode
  • Unlock an iPhone without knowing the password, including iPhone 14 and more iPhone models.
  • Bypass any passcode, including numeric code, Touch ID, or Face ID.
  • Fix forgotten passcode, disabled iPhone, passcode not working, etc.
