If your device tells you that your iPad is disabled to connect to iTunes, what should you do? Read this article and find an answer.
From being used to playing games to watching movies, there are a handful of iPad use cases. There are times when you store your important data on an iPad that needs to be protected; in that case, you will surely set a passcode for your iPad. As a human being, you might forget the passcode, and unfortunately, you will find yourself on the error screen that reads like “iPad is disabled, Connect to iTunes.”
If you’re stuck in the same problem and wondering what to do next, you don’t need to worry as your iPad is not beyond saving. Here, we’ll teach you how to fix iPad locked connect to iTunes issue and restore your iPad with ease. But before moving forward, let’s understand why did this happen!
Why is your iPad disabled connect to iTunes? While Apple offers the users a plentiful of chances to enter the correct password but your iPad will be disabled when you exceed the total number of trials, and you will immediately encounter iPad is disabled connect to iTunes issue.
To be more precise, when you enter the wrong password more than 10 times, your iPad gets completely disabled and asks you to connect it to iTunes to restore the device.
iPad is Disabled Connect to iTunes
If you can’t remember the passcode, iPhone/iPad is disabled and iTunes can not recognize you. Therefore, you can unlock the disabled device to fix this problem. With a professional third-party tool, you can quickly fix the disabled iPad with just a few clicks. Here we recommend you to use AnyUnlock – iPhone Password Unlocker.
AnyUnlock removes the iPad screen passcode with three simple steps. No technical knowledge is required. And in addition to removing the passwords, the tool can also help you get rid of the MDM restrictions, remove Apple ID from iOS devices, and find/view/export iOS passwords, etc.
Now, you can download AnyUnlock and learn how to unlock disabled iPad with AnyUnlock:
Step 1. Launch AnyUnlock on your PC, then choose Unlock Screen Passcode.
Choose Unlock Screen Passcode
Step 2. Connect your iPad to the PC via USB cable and head to Start.
Connect Your Device and Click Start
Step 3. Click the Download button to get the matching firmware. After the matched firmware is downloaded successfully, click the Unlock Now button.
Tap on Unlock Now to Continue
Step 4. Wait for a few seconds, and you’ll see the screen passcode removed successfully page as below.
iOS Device Unlocked Successfully
You were just five steps away from fixing the disabled iPad with AnyUnlock- iPhone Password Unlocker! Follow the steps appropriately for best results.
If you don’t want to get involved in the hassle of installing a third-party tool, then you can try fixing the iPad is disabled connect to iTunes problem by restoring your iPad via iTunes. Restoring your iPad via iTunes backup will erase your iPad’s existing data and settings, and it will restore the data from the last backup you have made.
Note that you cannot preview iTunes backup data before restoring it, and sometimes the data is overwritten as well. If you don’t know how restoring an iPad works, then refer to the guide below:
Restore iPad with iTunes
If your iTunes backup is encrypted, you need to enter the password to restore the iPad from encrypted data.
If the above fix didn’t help you solve your issue, get it solved with Recovery Mode. Here’s how this method works:
Step 1. Connect your iPad to the PC and run iTunes or Finder. In macOS Catalina or later, open Finder, and in macOS Mojave or earlier, open iTunes.
Step 2. Next, put your iPad into recovery mode by following the steps as under:
Step 3. Now, choose your iOS device and tap on Restore iPad. Here, iTunes or Finder will start downloading the related iOS version for your iPad.
Unlock iPad with Recovery Mode
After the restoration process is completed, you will be asked to enter your Apple ID, password, or device passcode.
iPad locked connect to iTunes is no longer a frustrating issue with these solutions above. In case you want a quick fix, then AnyUnlock will unlock your disabled iPad in just a few clicks. So, install AnyUnlock now and bring your iPad back to life!
